BillC Posted August 8, 2017 Share Posted August 8, 2017 (edited) Thanks. For some reason I was thinking the second schematic was using a direct connection to the Atari SIO port and the signaling you gave was confusing me. I can see that it likely is RS232 instead. Now it makes more sense. I also originally thought the second schematics was for SIO, but once I thought about it realized that RS232 serial was more likely. It might even be able to work with SIO using different firmware. From the instruction sheet provided the device you have appears to be the parallel to parallel version, the top schematic Richard posted, which adds a buffer to an existing parallel printer interface. Edited August 8, 2017 by BillC Quote Link to comment Share on other sites More sharing options...
Dropcheck Posted August 12, 2017 Author Share Posted August 12, 2017 Hi Richard, Just wanted to check in with you on the inventory process. Quote Link to comment Share on other sites More sharing options...
Bryan Posted August 12, 2017 Share Posted August 12, 2017 Also, Kevin might be interested in interviewing you! https://ataripodcast.libsyn.com/ http://atariage.com/forums/topic/236768-the-atari-interview-discussion-thread/ 3 Quote Link to comment Share on other sites More sharing options...
Dropcheck Posted September 10, 2017 Author Share Posted September 10, 2017 Does anyone have the ApeFace rom file? Quote Link to comment Share on other sites More sharing options...
