sprite help - clarifying how the command works
13 replies to this topic
#1 digdugnate OFFLINE
digdugnate
  • 1,053 posts
Posted Fri Aug 4, 2017 7:31 PM
Apologies in advance if this has been answered before, but I can't quite get my hands around how the CALL SPRITE command works.
I have a 4x4 block of characters defined (so 4 strings per 'line', 4 lines tall) and would like to move the entire thing as a sprite (like diagonally across the screen).
here's my pseudocode:
* Define character sets
A$="hex" through P$="hex"
* Color character sets (with example colors)
CALL COLOR(9,7,12)
CALL COLOR(10,7,12)
* Display character sets (with examples)
CALL VCHAR(12,16,96) :: CALL CHAR(96, A$)
CALL VCHAR(12,17,97) :: CALL CHAR(97, B$)
(and so on until 4 rows across and 4 rows down are defined)
So... according to the XB manual i want to do something similar to CALL SPRITE(#1, 96, 5, 124), but instead where it takes my entire 16 block 'graphic' and moves it across the screen, but I can't quite figure out *how* to make it work.
Thanks in advance!
Edited by digdugnate, Fri Aug 4, 2017 7:32 PM.
#2 arcadeshopper OFFLINE
arcadeshopper
  • 2,832 posts
Posted Fri Aug 4, 2017 7:37 PM
Call motion
Sent from my LG-H830 using Tapatalk
#3 digdugnate OFFLINE
digdugnate
  • 1,053 posts
Posted Fri Aug 4, 2017 7:43 PM
ok- i've got my book out.
CALL SPRITE(#1,33,5,96,124)  - would define it
FOR XVEL=-16 TO 16 STEP 2
FOR YVEL=-16 TO 16 STEP 2 - sets values for motion of sprite
DISPLAY AT (12,11):XVEL;YVEL - displays current values of motion of sprite
CALL MOTION(#1, XVEL, YVEL) - sets sprite in motion
NEXT XVEL - completes the loops
NEXT YVEL
so the next question i have is that if i've defined characters like 96 - 110 how to i get them all to move 'at once'?
#4 RXB OFFLINE
RXB
  • 2,904 posts
Posted Fri Aug 4, 2017 9:22 PM
Hmmm CALL MOTION automatically moves SPRITES.
100 CALL CLEAR :: CALL MAGNIFY(2) :: CALL SCREEN(15)
110 FOR S=1 TO 28
120 CALL SPRITE(#S,64+S,INT(RND*16)+1,20+S,50+S,INT(A(RND*1))*INT(RND*32),INT(A(RND*1))*INT(RND*32))
130 CALL MOTION(#S,INT(RND*99),INT(RND*99))
140 NEXT S
150 GOTO 150
You seem to think you have to move the sprites yourself, you can do that using CALL LOCATE(#sprite,row,col)  so see XB manual.
By the way Sprite row is 1 to 192 and sprite column is 1 to 256
Edited by RXB, Fri Aug 4, 2017 9:23 PM.
#5 Tursi OFFLINE
Tursi
  • 4,965 posts
  • HarmlessLion
Posted Sat Aug 5, 2017 4:08 AM
The XB sprite commands allow you to repeat the parameters for a little more speed (ie: CALL MOTION(#1,10,10,#2,10,10,#3,10,10) works to move sprites 1-3). The problem is that the interpreter is still too slow. You can usually get away with moving two sprites together if you only set the motion once, but more often than not more than that, or any updates, will just cause them to drift apart. Of course, you could try accounting for the motion lag with the initial position, it would probably work most of the time (ie: offset by a pixel or so based on the gaps you observe ;) ).
#6 mizapf OFFLINE
mizapf
  • 2,893 posts
Posted Sat Aug 5, 2017 5:07 AM
Could it help to inhibit sprite motion with the flag byte (83C2) until all motions are set?
#7 digdugnate OFFLINE
digdugnate
  • 1,053 posts
Posted Sat Aug 5, 2017 6:35 AM
thanks all :) i have what i think i need now.
#8 Tursi OFFLINE
Tursi
  • 4,965 posts
  • HarmlessLion
Posted Sat Aug 5, 2017 3:22 PM
It might, though then you are requiring 32k so CALL LOAD is available. Not a huge limit in this day and age. ;)
#9 digdugnate OFFLINE
digdugnate
  • 1,053 posts
Posted Sat Aug 5, 2017 4:30 PM
that shouldn't be a super big deal- i have a PEB with the 32k :)
I was disheartened, somewhat, because i was halfway through my program and i pressed fn-= instead of shift for the 'plus' sign.
I went and took care of laundry instead ;)
#10 RXB OFFLINE
RXB
  • 2,904 posts
Posted Sat Aug 5, 2017 10:36 PM
RXB starts out with the QUIT KEY DISABLED, in order to use the Quit Key in RXB you have to use:
CALL QUITON
Turns on quit key.
and
CALL QUITOFF
Turns quit key off.
Edited by RXB, Sat Aug 5, 2017 10:36 PM.
#11 Tursi OFFLINE
Tursi
  • 4,965 posts
  • HarmlessLion
Posted Sun Aug 6, 2017 12:29 AM
I did worse once, and learned about ghost keys the hard way.
After several hours of coding and fighting bugs, with it not working, I slapped the keyboard in frustration. It retaliated by resetting. I tested afterwards, and yes, there are combinations of many keys that get misread as FCTN-=.
Don't slap your TI. ;)
#12 RXB OFFLINE
RXB
  • 2,904 posts
Posted Sun Aug 6, 2017 12:45 AM
Other combinations do not work for Quit in RXB I turned off the CRU access to get that number from keys.
(And if you find one that does work tell me and I will fix it.)
#13 apersson850 OFFLINE
apersson850
    Moonsweeper
  • 469 posts
Posted Sun Aug 6, 2017 5:49 AM
But isn't the thing asked here about how to move a graphic block that's not defined as a sprite, or several sprites, but just as normal graphics? That's completely different.
#14 digdugnate OFFLINE
digdugnate
  • 1,053 posts
Posted Sun Aug 6, 2017 6:33 AM
it is.. but in a roundabout way i figured out what i needed for my program- not withstanding me quitting my program by miskeying, lol
