GoTek USB Floppy Emulator Questions
Gotek
19 replies to this topic
#1 pismire OFFLINE
pismire
    Combat Commando
  • 8 posts
Posted Sat Aug 5, 2017 8:17 AM
Hello.I am stumped on this and hoping someone who has used one of these before can guide me to the promised land?
I recently purchased the beige gotek USB floppy emulator, with the LCD readout and two button control on the front panel.
I have a straight through floppy ribbon cable, a 3.5" power cable, and a usb stick.
I've installed the unit in my PEB using the original TI disk controller. The ribbon cable is connected to the interior port.
The drive powers up and the LCD reads Ldr.
On my pc i've installed the HxC emulation software, and formatted my usb stick to  FAT32 as instructed.
I copied one of the 3 .cfg files they supply to my stick.
At this point, I was hoping that meant I could power it up and access the usb stick as if it was, for example, DSK1.
Right from TI Extended Basic for example.
With the stick inserted into the drive, the GoTek LCD flashes 004 over and over again while the stick's led is solid red.
Using their emulator utility I created a SSDD 320k 5.25" disk image and copied that to usb drive. It has no files in it, just an empty image.
Same issue... GoTek displays 004 flashing over and over.
I can't seem to find a manual for this GoTek nor a model# and the paper work I received doesn't mention it. It was purchased on recommendation from these forums from ArcadeShopper and he's been very helpful but I don't want to keep bothering him :)
I am no expert on this stuff and was looking for a cheap / quick way to replace the broken 5.25 in my PEB - not even really caring at this point to transfer images to/from the PC, more just waned a drive solution for my TI itself.
Any and all replies welcome and appreciated, even mean ones ;)
Thanks!
#2 arcadeshopper OFFLINE
arcadeshopper
  • 3,397 posts
Posted Sat Aug 5, 2017 8:42 AM
If you have a gotek standard 1 or 2 digit numeric display and two buttons you have to use indexed mode:
- "Indexed" mode. Selection based on the file image name : DSKA0000.HFE,
DSKA0001.HFE, DSKA0002.HFE... (IMG Extension also supported).
No extra software or config tool needed.
The lcd display they speak of for normal mode is a 3 line alpha numeric lcd.. and 3 button mode, there's a modification for this but no real graceful way to mount it in your pbox.. I have one I kludged together but it aint pretty
Greg
#3 arcadeshopper OFFLINE
arcadeshopper
  • 3,397 posts
Posted Sat Aug 5, 2017 8:47 AM
also these threads are applicable:
http://atariage.com/...ek#entry3678991
http://atariage.com/...ernative-gotek/
http://99er.net/blog...-on-my-ti-994a/
http://99er.net/blog...ti-994a-part-2/
#4 pismire OFFLINE
pismire
    Combat Commando
  • 8 posts
Posted Sat Aug 5, 2017 1:45 PM
Thanks Greg. Is there any documentation that would tell me what the 004 error code means?  (I dropped the indexed config on it, and a pre-created image from the chicago ti user group fair, renamed using the DSKA0000.HFE and still have same issue.
Starting to wonder if its my cable.
I purchased a twisted cable and cut it before the twist...
#5 Sinphaltimus OFFLINE
Sinphaltimus
  • 2,495 posts
  • Distracted at the Keyboard
Posted Sat Aug 5, 2017 3:20 PM
Did you purchase the GoTek with the HxC firmware or purchase and flash separately?
#6 klrw111-78 OFFLINE
klrw111-78
    Space Invader
  • 40 posts
Posted Sat Aug 5, 2017 8:20 PM
I just recently setup my Gotek.  A straight ribbon cable connected to the internal male connector on the TI Disk Controller to the Gotek makes it DSK2.  I had to make the "TI-twist" to get it to work as  DSK1. I didn't see where I could change jumpers to do it.  Did the serial bridge install the HXC firmware loader on the Gotek ?  It took two tries for me to get it loaded.  It should show hXc on the 7-seg LEDs on power up with no jump drive installed.  The config file must be the first file copied to the usb stick after it is formatted.  Initially I grabbed a 1440 sector HFE file from WHTECH instead of the 720 sector (180k) needed for my DSSD for my TI controller.
Don't know if any of the above may help, but this was my learning experience.
#7 arcadeshopper OFFLINE
arcadeshopper
  • 3,397 posts
Posted Sat Aug 5, 2017 8:26 PM
or you could move the jumper for disk select..
#8 klrw111-78 OFFLINE
klrw111-78
    Space Invader
  • 40 posts
Posted Sat Aug 5, 2017 8:32 PM
I never do things the easy way.....
#9 Jeff_HxC2001 OFFLINE
Jeff_HxC2001
    Chopper Commander
  • 106 posts
Posted Sun Aug 6, 2017 12:14 AM
This means that the gotek is not completely flashed with the firmware. It is looking for an upd file on the usb stick to finish it and didn't found it on the usb stick.
You can found the upd files into this archive :
http://hxc2001.com/d...ta_firmware.zip
#10 eightbit OFFLINE
eightbit
  • 3,290 posts
Posted Sun Aug 6, 2017 12:25 AM
I wonder the same thing. I think you have to pay $10 for the HxC firmware right?
#11 Sinphaltimus OFFLINE
Sinphaltimus
  • 2,495 posts
Posted Sun Aug 6, 2017 4:46 AM
Yes unless the person who sold it had an agreement with Jeff to preinstall or paid to have it installed before the sale.
#12 arcadeshopper OFFLINE
arcadeshopper
  • 3,397 posts
Posted Sun Aug 6, 2017 7:51 AM
Thanks for that I am in the process of moving and didn't have everything unboxed yet.
Sent from my LG-H830 using Tapatalk
#13 arcadeshopper OFFLINE
arcadeshopper
  • 3,397 posts
Posted Sun Aug 6, 2017 10:48 AM
if this is who I think it is (usernames <> real names) he bought it from me, and I did the header mod and then flashed the bootloader and sent it to him without doing that second step. I'll make sure I do that on future drives.  It's just loading that file on the drive and letting it flash and then it should read disks fine
Greg
#14 pismire OFFLINE
pismire
    Combat Commando
  • 8 posts
Posted Fri Aug 11, 2017 3:21 PM
Greg
Yes Greg, I am who you think it is. I was away for a bit but just got through all these replies. Thanks to everyone for their input. I will try this 2nd step and see what happens.
#15 arcadeshopper OFFLINE
arcadeshopper
  • 3,397 posts
Posted Fri Aug 11, 2017 3:26 PM
Ok good, lmk how it goes. Sorry with my move I got a little ahead of myself and shipped it before that step. Done moving now finally.
Greg
#16 pismire OFFLINE
pismire
    Combat Commando
  • 8 posts
Posted Sun Aug 13, 2017 8:22 AM
Update...
Using the udp file, my GoTek now displays the hxc logo on the led on start up (with usb stick in or not).
I removed the udp file from the usb drive, placed the indexed config file on the drive, and a 40-track single-sided .hfe disk named DSK0002.hfe
When this drive is in the gotek, the drive's light slowly blinks.
The GoTek continues to read hxc.
Pressing the two drive select buttons seemingly does nothing.
TI Disk Em2 locks up on the title screen.
From TI EB, if I try to save to DSK1 or DSK3 I get an I/O error 66.
If I try to save to DSK2 however, the small round LED above the disk selector buttons goes solid green, and the pen drive led goes solid.
After a 1s or so pause, I get the same I/O 66 error.
I *think* 66 = error saving, device not connected.
Still wondering if my issue is cable-related.
If I don't want to use somebody's .hfe file, could I not create an empty .hfe disk that I could simply save/load programs to/from from TI EB?
And if anyone still reading, does anyone have a known working floppy cable they'd part with :)   ??
#17 arcadeshopper OFFLINE
arcadeshopper
  • 3,397 posts
Posted Sun Aug 13, 2017 9:18 AM
Update...
you don't have your cable reversed do you? pin 1 on the drive is usually closest to the power connector and on the TI it should be keyed/obvious.
Greg
#18 pismire OFFLINE
pismire
    Combat Commando
  • 8 posts
Posted Sun Aug 13, 2017 1:19 PM
Greg
I flipped the end around on the gotek- seemed i had 1 on the other side. Still get the same i/0 66 error but now TI DM2 doesn't lock up. It does give me a disk error 16 however if i try to catalog dsk1, 2, or 3. optimistic baby steps it seems in the right direction
#19 rcamp48 OFFLINE
rcamp48
    Space Invader
  • 28 posts
Posted Thu May 10, 2018 8:22 PM
I have a question: I too have a Gotek flashed with FF not HXC , I bought the HXC program a while ago but has an LCD hooked up to it, when I took out the two blue and yellow connector out I saved them for later and now to flash HXC seems to be that I need to hook up the 3 segmnet LED but Ihave no idea where thoe 4 wires go on the LED part, I have figured out the other end on the board, thats no problem...
Russ Campbell
#20 RickyDean OFFLINE
RickyDean
    Dragonstomper
  • 868 posts
Posted Fri May 11, 2018 5:49 AM
Russ Campbell
Here is a place you might find an answer at.   http://99er.net/blog...-on-my-ti-994a/
Also tagged with one or more of these keywords: Gotek
