Flying Shark
288 replies to this topic
#51 Asmusr OFFLINE
Asmusr
  • 3,149 posts
Posted Sun Oct 1, 2017 1:38 PM
If you want avoid the effect, you could use just two waves 4 pixels tall, going back and forth. Probably the best would be add a black line under the 3 lines now used for the first two waves.
If you can spend more time and tiles on the issue, the rule more or less would be that the crests of the waves plot a sine wave animated across the sea tiles.
I'm not sure what you are suggesting. I have tried different versions and none of them really works well.
#52 artrag OFFLINE
artrag
  • 1,286 posts
Posted Sat Oct 7, 2017 2:50 AM
I have attached the 8 frames of animation of a single sea tile 8x8.
The proposal is to depict two sea waves "waving" in opposite directions
One across the left border of the tile, the other across the left right border of the tile
The first file has taller waves, the second smalls waves
Edited by artrag, Sat Oct 7, 2017 2:57 AM.
#53 Asmusr OFFLINE
Asmusr
  • 3,149 posts
Posted Sat Oct 7, 2017 4:31 AM
Thanks. The problem is that moving the waves every frame is way too fast for a pleasant result. This is what I have come up with in the meantime after several attempts. It is moving two lines at a time every 4 frames, only one pixel back and forth .
Attached File  ani.png   258bytes   7 downloads
#54 Asmusr OFFLINE
Asmusr
  • 3,149 posts
Posted Wed Oct 18, 2017 3:13 PM
I have been agonizing over execution speed: Should the game scroll faster (30 or 20 frames per second (FPS)) when the graphics are simple, or scroll at a constant speed of 15 FPS and perhaps waste a lot of clock cycles? This decision has to be taken early because even though I have fixed the game loop at 30 FPS there's still the coordination with the background to consider. I ended up deciding in favor of the fixed frame rate with the hope that some of the clock cycles may be spent on sprite handling rather than busy waiting.
Anyway, a few more features and a few more enemies now. You can be hit but you respawn right after. Edit: and you get points for the few enemies there are.
Code is on GitHub now:
https://github.com/R...-M/Flying-shark
#55 fabrice montupet OFFLINE
fabrice montupet
    Moonsweeper
  • 497 posts
Posted Wed Oct 18, 2017 3:41 PM
Great job! I'm impressed!
#56 ti99iuc ONLINE
ti99iuc
  • 1,665 posts
Posted Thu Oct 19, 2017 3:31 AM
Rasmus you are going to do one of the best classic shoot'em up never seen on a TI-99/4A, it is great !
Thanks !!
#57 Iwantgames:) ONLINE
Iwantgames:)
  • 2,490 posts
Posted Thu Oct 19, 2017 4:28 AM
Wow this looks amazing!
#58 Asmusr OFFLINE
Asmusr
  • 3,149 posts
Posted Sat Oct 28, 2017 2:41 PM
I now have a VGA to HDMI converter and a EZCAP 280 video capture device, which has allowed me to record this video from real hardware.
#59 Vorticon OFFLINE
Vorticon
  • 3,792 posts
Posted Sat Oct 28, 2017 3:30 PM
Beautiful graphics and very smooth. Fantastic! One observation: on a few instances, there was a noticeable slowing down of the background music when the screen got busy. Is this fixable?
#60 LASooner OFFLINE
LASooner
    Moonsweeper
  • 411 posts
Posted Sat Oct 28, 2017 3:35 PM
#61 Asmusr OFFLINE
Asmusr
  • 3,149 posts
Posted Sat Oct 28, 2017 3:52 PM
Yes apparently my "interrupt" routine runs over the frame. If I can't make it runs faster I need to call the sound player twice. The sound was just added today, so this is all experimental.
#62 Tursi OFFLINE
Tursi
  • 5,667 posts
  • HarmlessLion
Posted Sat Oct 28, 2017 5:53 PM
I still hope to get the CPU usage of the player down too... it's too expensive. But, that's a ways off yet.
#63 globeron OFFLINE
globeron
    Dragonstomper
  • 850 posts
Posted Sun Oct 29, 2017 3:15 AM
very nice!
#64 sometimes99er OFFLINE
sometimes99er
  • 4,231 posts
Posted Sun Oct 29, 2017 8:05 AM
Looking good. Adding more color and animation to the ZX game really adds a few nice dimensions.
The video capture is so crisp, that I assume the "real hardware" has the modern F18A replacing some of the original steel. ;)
Edited by sometimes99er, Sun Nov 5, 2017 3:34 AM.
#65 fabrice montupet OFFLINE
fabrice montupet
    Moonsweeper
  • 497 posts
Posted Sun Oct 29, 2017 3:27 PM
So Great!
#66 Asmusr OFFLINE
Asmusr
  • 3,149 posts
Posted Fri Nov 3, 2017 4:06 PM
I found the cure for the slow-down in the music although I don't fully understand the reason. I just had to call the sound player before my main wait for vsync if and only if an interrupt has already occurred. Apart from that this version only includes a few new sound FXs.
#67 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,468 posts
Posted Fri Nov 3, 2017 4:22 PM
Very cool!  The water level reminded my a bit of another favorite, 1942.  :)
#68 fabrice montupet OFFLINE
fabrice montupet
    Moonsweeper
  • 497 posts
Posted Tue Nov 7, 2017 1:18 PM
It's better and better! Thanks! :-D
Alas, I have no time to build a 512Kb pcb cartridge and I would like so much to use a real hardware for the demo. So, Ramus could you propose a floppy disk version? Thank you by advance !
#69 Asmusr OFFLINE
Asmusr
  • 3,149 posts
Posted Tue Nov 7, 2017 10:23 PM
A floppy disk version would require SAMS, and I'm not planning to go down that route. But when the game is finished it will be available on cartridge.
#70 Asmusr OFFLINE
Asmusr
  • 3,149 posts
Posted Sat Nov 11, 2017 5:39 PM
I have been working on a title image based loosely on the arcade version. I don't think it's bad but I'm not satisfied either. Damn TI colors.
#71 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 14,031 posts
Posted Sat Nov 11, 2017 6:04 PM
Like the FG99.  Quite a few people own that cartridge now.
#72 digdugnate ONLINE
digdugnate
  • 2,440 posts
Posted Sat Nov 11, 2017 6:06 PM
i loaded it to my FG99 for funsies and it's a really slick game.  love the music!
#73 Asmusr OFFLINE
Asmusr
  • 3,149 posts
Posted Fri Nov 17, 2017 4:11 PM
Glad you like it, the music is just a proof of concept by now. All credits go to Tursi's audio player.
Here in the weekly version. New title screen, more enemies on level 1, life display, and some bug fixes.
Placing those enemies in the same way as the ZX Spectrum version takes forever, but I think it's worth it compared to random madness.
#74 sometimes99er OFFLINE
sometimes99er
  • 4,231 posts
Posted Sat Nov 18, 2017 12:26 AM
Oh, I didn't know about the arcade. I think you somehow need to use more black, but then the original is also kind of muddy (without that much contrast). ;)
Incredible times when we went from Pac-Man in 1980 to stuff like Flying Shark in 1987. The first comparable to the TI-99/4A and the latter to the Amiga.
Edited by sometimes99er, Sat Nov 18, 2017 12:37 AM.
#75 ti99iuc ONLINE
ti99iuc
  • 1,665 posts
Posted Sat Nov 18, 2017 4:37 AM
Really I Like the how the game is updating ! thanks Rasmus !
I also watched some comparing videos and i must say that this version has lot of power compared at some other conversions.
The best one of the exist conversion of this game i think is the C64's one, i like the music and sound effects really near to the original arcade version.
about sound effects on the TI99 i think that the airplane gun's sound could be changed in something similar to a gun for an old airplane, the current FX remember me a laser, but it is not important anyway just my impression :P
