some more 15 pin gameport pc to 5200 adapters
104 replies to this topic
#1 bohoki OFFLINE
bohoki
  • 1,559 posts
Posted Sat Aug 5, 2017 10:52 PM
got a little batch of my old ones
$11 shipped anywhere in the usa
$12 for one with 2 plug shields
these work with most  analog controllers and many gamepads i like using them with the original gravis gamepad
they have a start button but you must plug in a 5200 controller for keypad use
they have been tested on  my system and work but realize they are shoddily constructed and experimental devices so use at your own risk
#2 CRTGAMER OFFLINE
CRTGAMER
    Dragonstomper
  • 603 posts
Posted Sun Aug 6, 2017 12:14 PM
Sent you a PM,
Interested in two cables with shields, I can pay thru Pay Pal. Is it possible to include a shield for the 5200 end as well?
Edited by CRTGAMER, Sun Aug 6, 2017 12:23 PM.
#3 CRTGAMER OFFLINE
CRTGAMER
    Dragonstomper
  • 603 posts
Posted Sun Aug 6, 2017 5:31 PM
Just sent payment for two adapters with shield covers on the controller side.
Thankyou!
#4 bohoki OFFLINE
bohoki
  • 1,559 posts
Posted Sun Aug 6, 2017 6:20 PM
all ones with grey shields sold thank you for your purchases
#5 phattyboombatty OFFLINE
phattyboombatty
  • 1,175 posts
Posted Sun Aug 6, 2017 10:17 PM
I am glad you started this thread Bohoki. I received one of your gadgets in pickup here in the SD area last year. The guy is a fellow AA'er who was liquidating his collection. He explained to me all about this little doo-dad at the time, but his Gravis D-Pad was filthy, so I put both items away for a while until such time that I could give them a good scrubbing.
This item is IDEAL! Such a simple little device, and I had NO idea that 15-pin PC gamepads would WORK with the Atari 5200! The Gravis D-pad RULES and has transformed my Atari 5200 experience 100%. Using this Y-adapter makes for perfect harmony with the stock CX-52 controller.
Thanks for making these. I highly recommend!
And yes, go for that cheap Gravis D-pad. If they had made these in the 80s...
#6 CRTGAMER OFFLINE
CRTGAMER
    Dragonstomper
  • 603 posts
Posted Mon Aug 7, 2017 8:12 AM
A bump on the adapter, potential Atari 5200 (PC Gameport) controllers pictured.
There are tons of inexpensive PC Gameport controllers at the thrift stores!
#7 ave1 OFFLINE
ave1
    Moonsweeper
  • 499 posts
Posted Mon Aug 7, 2017 9:31 PM
Here is my presentation with some of my favorite controllers for use with this adapter (go to 1 minute 49 seconds in):
#8 CRTGAMER OFFLINE
CRTGAMER
    Dragonstomper
  • 603 posts
Posted Tue Aug 8, 2017 7:02 AM
Great video, have you found that most PC controllers work with bohoki's adapter?
That Barracuda along with the Barracuda 2 is unique for PS1 pre-analog stick games. The Barracuda can be set so the analog stick emulates the DPad in the older PS1 games!
Edited by CRTGAMER, Tue Aug 8, 2017 7:04 AM.
#9 ave1 OFFLINE
ave1
    Moonsweeper
  • 499 posts
Posted Tue Aug 8, 2017 8:05 AM
I have found that around 60 percent of them work. The ones that require software to be installed won't work, so avoid those.
Yeah, the PS1 Barracuda controller has some very unique features, and it's a great tool to have in the arsenal!
#10 bohoki OFFLINE
bohoki
  • 1,559 posts
Posted Tue Aug 8, 2017 3:29 PM
i'm surprised you only had a 60% rate but i understand the older sticks are often harder to find than the newer sticks as they break become obsolete and thrown away
my basic rule of thumb is that the driver based joysticks were made after 1995
its almost like the "you might be a redneck jokes"
if your controller has more than 6 buttons you might be a driver based joystick
if your controller is analog and doesnt have trim tabs or centering dials you might be a driver based joystick
if your controller was made by microsoft you might be a driver based joystick
if your controller came with a usb adapter you might be a driver based joystick
if your controller has a yellow plug you might be a driver based joystick
the original standard is 4 axes and 4 buttons
but within  those limitations
2 of the axes can be used as as 2 buttons so that can be a 6 button gamepad or combat stick
with flight sticks one axis can be used as a pov hat button  or a throttle slider and the other axis can be rudder pedals
the gameport was enhanced with windows 95 to allow it to be a serial device but it had a dirty secret that it still used an irq line that often would reduce cpu speed by around 20%
back to basics even when you find a joystick that should work it could have problems with "old pot syndrome" or just "crappy pot syndrome" where it would act like trying to play breakout with jittery paddles
i love the old Kraft sticks they work well but their button placement is often not from the ergonomic age
suncom made some neat sticks but they often added an autofire that draws too much current and can cause a pulsing jitter even when the autofire is off (the beige starfighter stick does not work with my adapter ) if you have some skill say you have the fx2000 you can unscrew the bottom and just cut pin#1 on the 555 chip and it will work fine
there are some sticks that have a keyboard cable to allow it to have more buttons for flight sims and stuff those are always the old type so will work  the thing with the flight type sticks is they have so much throw and have so many buttons on the stick they are not good for action arcade games its great for star wars and missle  command
its kind of odd back then we would have different controllers for different games like when i bought my gravis gamepad it came with commander keen and that game would be hard as hell using a flightstick
#11 7800fan OFFLINE
7800fan
  • 5,606 posts
Posted Tue Aug 8, 2017 9:49 PM
The original PC joystick was 2 buttons not 4.  Back then, you could have a Y adapter to get 2 players  or one player only 4/6 button joystick. if you used those with the Y adapter, the extra buttons aren't passed through.
#12 ave1 OFFLINE
ave1
    Moonsweeper
  • 499 posts
Posted Wed Aug 9, 2017 9:26 PM
... it might be 70 percent. I just know I had a run of bad luck for a while with some joysticks/flightsticks and joypads (A Microsoft and a Saitek pad)... but I've managed to come acrossed a few in the past year (including a Wico Command Control joystick for the PC and the Makopad PC which worked amazingly well).
#13 phattyboombatty OFFLINE
phattyboombatty
  • 1,175 posts
Posted Thu Aug 10, 2017 6:49 PM
Phenomenal, informative video. Thanks for producing!
#14 Maxwell Zorin OFFLINE
Maxwell Zorin
    Space Invader
  • 18 posts
Posted Mon Aug 14, 2017 3:33 PM
Thank you Bohoki for this great adapter. Works perfectly, and has breathed some life into my 5200's play time. I wanted to take a break from playing Popeye and Dig Dug and say how happy I am with it! 5200 brotherhood here i come!
#15 bohoki OFFLINE
bohoki
  • 1,559 posts
Posted Wed Aug 16, 2017 4:51 PM
still got 5 left
i do not endorse these sellers but these are a couple fun controllers
http://www.ebay.com/...d-/202017532711
http://www.ebay.com/...0-/201778033710
http://www.ebay.com/...t-/162281151636
http://www.ebay.com/...D-/182517477488
http://www.ebay.com/...B-/332334184362
http://www.ebay.com/...r-/263114072791
#16 0078265317 OFFLINE
0078265317
  • 6,308 posts
Posted Wed Aug 16, 2017 8:17 PM
You still sell on ebay?
#17 Lynxpro OFFLINE
Lynxpro
  • 3,688 posts
Posted Wed Aug 23, 2017 7:53 AM
I hope someone tries a PC Steering Wheel set-up with the adapter to see if Pole Position will work out of the gate with it...
#18 bohoki OFFLINE
bohoki
  • 1,559 posts
Posted Wed Aug 23, 2017 12:37 PM
ive experimented with 3 one was the n64 type hand wheel and it works but its not fun because shifting requires up and down which the controls is on the bottom in the form of a back and forth type trigger i was steering with my right hand so i was holding the gas pedal which was button a with my left thumb and had to shift with my left index finger so to replicate that just grab a remote controlwith your left hand press a button with your thumb now take your index finger and imagine pressing it upward under the bottom
another wheel i had was i think called grandprix it had paddle shifters  behind the wheel so left paddle was up and right paddle was down it worked ok but i had to mount the wheel to a surface with suction cups which is sometimes hard to find a super slick surface  so i had a sheet of glass springclamped to a tv tray and even with the suckers moist they one would let loose and the tv tray was rocking as i was pushing the unit back down  all while having to hold down the A button which was under my right thumb
the third wheel i think was called the gasser had pedals so now you are thinking wow neato well no
because you still are driving pressing A for gas this one had a on the left side b on the right so i am pressing A with my left thumb the whole time and to shift up i have to hit the gas pedal and to down shift i press the brake also this one used a clamp  so i had to find a surface with an overhand that the clamp could grasp so there i am with a wheel clamped to a coffee table about a foot off the ground so there i am humped over on the couch stomping pedals and moving the wheel like i am driving a kiddie power wheel vehicle
now i dont know about you but i like gaming barefoot well these pedals have some slightly sharp corners  and little spiky treads believe it or not it kind of hurts  so now i got to go put on some shoes well socks and shoes because if i dont wear socks my shoes will be ruined (i learned that i would swampfoot out a pair of vans in a couple weeks if i didnt wear socks)
also if you are thinking why didnt you clamp it to the tv tray well i clamped it on then i steered and the little clips that hole the tv tray to the legs would pop lose so no i steering  attached to  plank with limp dangling spider legs as i am trying to find the controller attached to the y adapter to press pause as i go flying around that one corner into that one gotdang red billboard
#19 CRTGAMER OFFLINE
CRTGAMER
    Dragonstomper
  • 603 posts
Posted Mon Nov 13, 2017 11:35 PM
AVE1 posted a video using your adapter with an additional PSX/N64 adapter. Who would have though so many more controller options over just the 5200 Wico setup  :-D
PS1 PS2 and N64 controllers 5200 games - http://atariage.com/...s/#entry3880324
#20 thegamezmaster OFFLINE
thegamezmaster
  • 2,410 posts
Posted Tue Nov 14, 2017 3:27 PM
Are
are any still available? PM me if so, thanks.
#21 bohoki OFFLINE
bohoki
  • 1,559 posts
Posted Tue Nov 14, 2017 11:02 PM
i sold them all maybe i'll make another batch ,i'll probably need to since i just sold one of my personal ones i used for controller 2 robotroning to some guy
i got parts ordered but they take a while
Edited by bohoki, Tue Nov 14, 2017 11:41 PM.
#22 fandenivoldsk OFFLINE
fandenivoldsk
    Chopper Commander
  • 189 posts
Posted Thu Nov 16, 2017 2:09 PM
I would like to buy four of these, if you make another batch.
Edited by fandenivoldsk, Thu Nov 16, 2017 2:09 PM.
#23 thegamezmaster OFFLINE
thegamezmaster
  • 2,410 posts
Posted Thu Nov 16, 2017 2:53 PM
Me too!
#24 bohoki OFFLINE
bohoki
  • 1,559 posts
Posted Tue Dec 5, 2017 1:57 AM
made a few more if your pc joystick has a plastic shroud you will probably need to loosen the plug handle a little to allow it to connect firmly
$12 each pm for dets
us shipping only
#25 0078265317 OFFLINE
0078265317
  • 6,308 posts
Posted Thu Dec 7, 2017 8:47 PM
us shipping only
I will take one.  I found a good pc 15 pin stick today.
