Purchased a working Atari 130XE with (possible?) unfinished mod?
ColecoGamer
As the title states, I recently purchased a working Atari 130XE. What I noticed right away is that someone had cut a hole on the backside of the case. Feeling curious, I decided to open the machine. What I found was a series of wire leads soldered to two different chips on the motherboard. These wires are all connected to what appears to be a passthru/power connector of some kind.
I am posting some photos hoping that someone here can indentify what this mod (or unfinished mod?) could be. It looks clean, but there is no electrical tape holding the wires in place, and I am worried about them eventually coming loose.
I also recently purchased a 130XE with a smililar mod. Mine has the pink and purple wires. The computer does not work at all. I can't see any other problems with the motherboard. The power light does not come on but I checked the switch with a multimeter and it shows 5.3 volts coming in.
Pink and purple wires are factory hoo-doo and many have them
and they all used to work. Does the 5+ make it onto the board
at the middle switch contact though? Switches do go bad with
oxidized contacts such that they appear to work but do nothing
electrically. They can be taken apart and contact cleaner shot
past the ball socket internally to work magic in a can but often the
entire switch is just replaced instead. Taken apart for this switch
means spreading the flat side springs that hold the plastic rocker in
place, removing the plastic rocker to reveal the external guide pin
and exterior ball portion of the ball and socket. Push inward on the
ball and shoot contact cleaner past it such that the liquid can get
inside. Using small pliers on the guide pin, work the switch carefully
until it clears the crud internally and begins to work as it did before
time degraded it. Switch is available from Best Electronics but he has
a 50 dollar minimum order amount and likely doesn't do overseas
shipments willingly. WD-40 would work for contact cleaner if you
don't have any handy.
http://www.best-electronics-ca.com/
Page 93
65XE / 130XE On/Off Switch CO61913 / CO61022 / CO70006 - $1.25
no working link sorry - he wants you to call him and order it
verbally anyway.
Temp test for switch would be to short middle leg to lower leg with
screwdriver shank. If the power light comes on now then it's the
switch in need of attention.
Glad to find out that the pink and purple wires are factory. You nailed it with the switch info. Turns out that my switch was bad, cannabilized a non-working 800XL and the 130XE is ok except for keyboard, some dead keys. If cleaning doesn't work, I will get another from Best.
