MIDI Interface
458 replies to this topic
#1 ivop OFFLINE
ivop
    Dragonstomper
  • 922 posts
Posted Wed Aug 23, 2017 7:58 AM
Hi,
I have decided to build myself a MIDI Interface for the Atari XL/XE. Based upon an old schematic from Elektronika Praktyczna (6/98), I came up with this:
It's 5cm x 5cm and supports MIDI IN/OUT/THRU. The device is turned on/off by the Motor Control Line.
Now the question is, would anybody else be interested in this and, if so, what would you like? PCB only, PCB+parts, or fully build? (all excl. SIO cable)
Note that I have not build anything yet, although some parts are on their way.
Regards,
Ivo
#2 David_P OFFLINE
David_P
    Dragonstomper
  • 939 posts
Posted Wed Aug 23, 2017 8:13 AM
Midimaze...
#3 Kyle22 OFFLINE
Kyle22
  • 4,095 posts
  • Call my BBS! telnet://broadway1.lorexddns.net
Posted Wed Aug 23, 2017 9:08 AM
Is this compatible with Midi Track III?
#4 ivop OFFLINE
ivop
    Dragonstomper
  • 922 posts
Posted Wed Aug 23, 2017 10:18 AM
It depends on what Midi Track supports. As far as I can see there are two different types of interface. Some use an external crystal to clock Pokey at exactly 31250 (i.e. Midimate) and the others use a Pokey frequency which is close enough. All seem to use Motor Control to enable and disable the device and free the SIO bus again.
Edited by ivop, Wed Aug 23, 2017 10:18 AM.
#5 Van OFFLINE
Van
    Moonsweeper
  • 285 posts
Posted Wed Aug 23, 2017 10:47 AM
Would be interested in bare board. A suggestion, add 3 pin header footprints under the DIN sockets to allow panel mounted sockets instead of board mounted DINs.
Yogi
#6 ivop OFFLINE
ivop
    Dragonstomper
  • 922 posts
Posted Wed Aug 23, 2017 11:16 AM
Added 3 pin headers as suggested by Van.
#7 Brentarian OFFLINE
Brentarian
    Moonsweeper
  • 479 posts
Posted Wed Aug 23, 2017 12:04 PM
I'd be interested in one board. Maybe two or more if it works with MidiMaze. 😀
#8 ndary OFFLINE
ndary
    Dragonstomper
  • 525 posts
Posted Wed Aug 23, 2017 4:24 PM
Hi Ivo,
what software support this interface?
Nir
#9 Mathy OFFLINE
Mathy
  • 2,957 posts
Posted Wed Aug 23, 2017 5:20 PM
Hello Ivo
Wouldn't it be easier in use if all three DIN plugs would be on the same side?  Or if somebody wants to build the interface into a larger case?
Sincerely
Mathy     (who already has three MIDI interfaces, all MIDI-Mate compatible except for the missing sync ports.  Fully MIDI-Mate/MIDI-Maze compatible)
#10 mono OFFLINE
mono
    Chopper Commander
  • 109 posts
Posted Wed Aug 23, 2017 5:51 PM
I'm interesting in fully build device.
#11 ivop OFFLINE
ivop
    Dragonstomper
  • 922 posts
Posted Thu Aug 24, 2017 3:43 AM
These should definitely work:
MIDIPlay v1.3 by Ireneusz Kuczek
MIDIRec v1.2 by Ireneusz Kuczek
MIDI PatternEditor MPE v.2.3 by Radek Sterba
MIDI Sequencer 1.15 by Maciej Sygit
Possibly more, I don't know. This is my first venture into the 8-bit MIDI world.
I decided on a 5x5 board mainly because of the price, but I also like the small form factor. Having IN and THRU at opposite sides reminds me of guitar stompboxes. The pin headers I just added as per Van's suggestion is meant for panel mounted DIN connectors and larger cases. But, nothing is set in stone yet. The PCB is pretty full at the moment, so I guess if any other features need to be added, I'll upgrade to 5x10cm.
Regards,
Ivo
#12 Stormtrooper of Death OFFLINE
    Moonsweeper
  • 455 posts
Posted Thu Aug 24, 2017 6:32 PM
I might be interested aswell. In a fully build. Would be fun to make some small programs that play midi music , controlled by good old Atari 8bit.
#13 orpheuswaking OFFLINE
orpheuswaking
  • 5,833 posts
  • 1088XLD in progress
Posted Fri Aug 25, 2017 7:02 AM
I'd likely purchase a PCB + Parts
#14 tuf OFFLINE
tuf
    Chopper Commander
  • 245 posts
Posted Fri Aug 25, 2017 1:16 PM
Interested in one assembled.
#15 k-Pack ONLINE
k-Pack
    Star Raider
  • 59 posts
Posted Fri Aug 25, 2017 8:30 PM
I would be interested in a couple of boards. Having a parts list would be of great help also.
I had downloaded some files from CompuServe and took a look at them a couple of months back.  One of the files is:
MIDIDR.DOC (MIDIDR.XMO)
MIDIMate Software Interface Documentation 5/21/1985
By Hybrid Arts, Inc.
If you haven't seen it,  the .atr holding this file  and can be downloaded from this blog entry.  There is also a MIDI handler that can be used with BASIC and should work with your interface.  In case someone wants to program the next MidiMaze game.
http://atariage.com/forums/blog/572/entry-13705-a8-midi-and-the-atari-age-of-rediscovery/
#16 Matej OFFLINE
Matej
    Moonsweeper
  • 429 posts
Posted Fri Aug 25, 2017 11:25 PM
I would take 2x fully assembled devices.Also I will do 3d printed cases for them and make them opensource...
#17 StaxX28 OFFLINE
StaxX28
    Chopper Commander
  • 203 posts
Posted Sat Aug 26, 2017 5:29 AM
Interesting, that is works on A8 with dual pokey board?
#18 ivop OFFLINE
ivop
    Dragonstomper
  • 922 posts
Posted Sat Aug 26, 2017 5:56 AM
Yes, it's a SIO device. Dual Pokey should be no problem. It could actually be beneficial if one were to write a piece of software to use the Atari as a sound module. You lose channel 3+4 of the first for MIDI communication, but you could use channel 1+2 and the second pokey's channel 1+2 and 3+4 for three 16-bit audio channels in total.
Update: I'm going to order the PCBs tomorrow. I'll start with a batch of 10. More than enough components coming in the following weeks for 10 complete units.
@pack007, I checked the Fig-Forth code in your ATR and uses the external clock line, which this device does not support. I also glanced over the Midimaze ROM, and it does the same. But, I don't think it'll be too hard to "fix" them for this device. Perhaps somebody already did that "back in the day"?
#19 StaxX28 OFFLINE
StaxX28
    Chopper Commander
  • 203 posts
Posted Sat Aug 26, 2017 6:48 AM
Thanks ivop !
Maybe i'll buy one, depending of the price...
#20 Van OFFLINE
Van
    Moonsweeper
  • 285 posts
Posted Sat Aug 26, 2017 10:06 AM
I was also thinking this the other day about a dual Pokey set-up :)
Yogi
#21 Mr.Bacardi OFFLINE
Mr.Bacardi
    Star Raider
  • 95 posts
Posted Sun Aug 27, 2017 12:44 PM
Would be also interested in one assembled device.
#22 Blues76 OFFLINE
Blues76
    Moonsweeper
  • 432 posts
Posted Sun Aug 27, 2017 1:15 PM
I'm interested in a fully build
#23 Sikor OFFLINE
Sikor
  • 1,476 posts
Posted Sun Aug 27, 2017 1:55 PM
I'm interested fully build. What is cost?
#24 ivop OFFLINE
ivop
    Dragonstomper
  • 922 posts
Posted Mon Aug 28, 2017 11:08 AM
All components and the PCBs (10 pieces) have been ordered. As for the price, probably somewhere between  €10,= and €15,=. First I want to build one and verify its working before I take orders. But I have a ballpark estimate now as for the amount of interest there is. Thanks for that. I'll get back to you when I have built one successfully :)
#25 Xebec OFFLINE
Xebec
    Moonsweeper
  • 388 posts
Posted Mon Aug 28, 2017 11:28 AM
Midimaze...
I think i've read Midimaze on the 8bit can network with the ST via midi?  or only other 8bits?
