TheMitcher Posted September 2, 2017 Share Posted September 2, 2017 So I took the plunge and tried to install the following composite video mod on my 4-switch 2600. Ugh... it did not end well. http://www.ebay.com/itm/Atari-2600-7800-Composite-Video-Mod-Upgrade-Kit-DIY-/300592126324?hash=item45fcafd974:m:mjyZk3U_a7jYA4o6YoJN0Cg I've successfully soldered a number of electronic devices over the years (mostly guitar effect pedals and a few other gadgets), but it's been a while. My 2600 had a pretty poor picture on my 42" Vizio, but after the mod, it won't display a picture at all. In fact, I can't tell if the TV is receiving any signal from the console whatsoever. To my untrained eye, it looks like the solder joints are good, and the traces look intact, so nothing looks obviously wrong. I could try to undo everything and redo it, but I'm considering trying to find someone I can ship the unit to and pay them to troubleshoot and fix my mistakes. Any recommendations for folks who do that kind of work? Thanks! Quote Link to comment Share on other sites More sharing options...
numbski Posted September 2, 2017 Share Posted September 2, 2017 Might help if we knew where approximately you are located... Quote Link to comment Share on other sites More sharing options...
TheMitcher Posted September 3, 2017 Author Share Posted September 3, 2017 I'm in the United States, in Pennsylvania. Quote Link to comment Share on other sites More sharing options...
H454 Posted September 4, 2017 Share Posted September 4, 2017 Have tried another tv or running in thru a vcr? Quote Link to comment Share on other sites More sharing options...
the_crayon_king Posted September 24, 2017 Share Posted September 24, 2017 So I took the plunge and tried to install the following composite video mod on my 4-switch 2600. Ugh... it did not end well. http://www.ebay.com/itm/Atari-2600-7800-Composite-Video-Mod-Upgrade-Kit-DIY-/300592126324?hash=item45fcafd974:m:mjyZk3U_a7jYA4o6YoJN0Cg I've successfully soldered a number of electronic devices over the years (mostly guitar effect pedals and a few other gadgets), but it's been a while. My 2600 had a pretty poor picture on my 42" Vizio, but after the mod, it won't display a picture at all. In fact, I can't tell if the TV is receiving any signal from the console whatsoever. To my untrained eye, it looks like the solder joints are good, and the traces look intact, so nothing looks obviously wrong. I could try to undo everything and redo it, but I'm considering trying to find someone I can ship the unit to and pay them to troubleshoot and fix my mistakes. Any recommendations for folks who do that kind of work? Thanks! Well if you took a bunch of screen shots we could probably find the issue. Could be something simple like lack of ground on the RCA output. Quote Link to comment Share on other sites More sharing options...
mobiusstriptech Posted October 3, 2017 Share Posted October 3, 2017 I have seen that circuit cause issues before on some 2600's. That is a pretty common circuit that will generally work, but it's not technically correct. Usually what happens is the output is not properly attentuated and the tv you are hooking into is sensitive to the signals being off. In those cases, the console might work on some tv's and not others or display in the wrong colors. Quote Link to comment Share on other sites More sharing options...
R.Cade Posted October 3, 2017 Share Posted October 3, 2017 Yes, this mod is generally bad. It's cheap and sometimes works, but usually doesn't look to good. There are better ones out there that are worth the extra money. Quote Link to comment Share on other sites More sharing options...
shear_xear Posted November 1, 2017 Share Posted November 1, 2017 Did you get any sound when you turned it on? Frogger is a good test cart as there is immediate music when the 2600 is turned on. Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted November 2, 2017 Share Posted November 2, 2017 As others have stated, we need to see some pictures of the mod board and where you made the connections...etc before we can provide any additional input. Quote Link to comment Share on other sites More sharing options...
