Text to Speech program?
13 replies to this topic
#1 VicViper OFFLINE
VicViper
    Dragonstomper
  • 591 posts
Posted Tue Sep 5, 2017 4:41 PM
quick question, just want to find a program that i can run in my FinalGROM that will let me do text to speech with the voice synth, didn't see anything in the dump thread.
#2 blackbox OFFLINE
blackbox
    Star Raider
  • 68 posts
Posted Wed Sep 6, 2017 12:24 PM
TI Extended Basic allows you to use a built in vocabulary but that isn't true text to speech.
To say anything- read a text file say- it may seem bizarre but you need the Terminal Emulator 2 (TE2 or TI-II) module, PHM3035.
Choose and load the module into your FG99 and having selected the module, THEN choose TI Basic, then you can say anything from the command line or a basic program.
You will need the manual, at ftp://ftp.whtech.com/games/Texas%20Instruments/Terminal_Emulator_II_Manual.zip
#3 RXB OFFLINE
RXB
  • 2,875 posts
Posted Wed Sep 6, 2017 9:38 PM
Hmm the XB Text to Speech disk can do anything the TE2 cart can do?
#4 blackbox OFFLINE
blackbox
    Star Raider
  • 68 posts
Posted Thu Sep 7, 2017 2:40 AM
True, but PHD5076  requires a disk system which the OP didn't mention. You also had to have the  32k ram.  Loading the code and database from the TI disk took quite a wait- over two minutes. And used up some XB program space in memory. Probably faster with todays solid state disk replacements (timing anyone?)
Notes with sample code. on the TI Text to Speech disk at http://www.ninerpedi...=Text-to-Speech
I can't recall anyone selling PHD5076 in the UK?
Using TE2 you opened the device (OPEN) and PRINTed to it, see
http://www.ninerpedi...nal Emulator II
and of course the TE2 manual.
To be a completist perhaps mention should be made of the almost forgotten and barely usable SPEECH EDITOR module (did anyone actually use it?).
And there was the separate but rare  MBX Unit which supported speech without the speech synth- but you couldn't use it for your own speech so that's outside the scope of the original query!
Stephen
Edited by blackbox, Thu Sep 7, 2017 2:48 AM.
  • RXB likes this
#5 VicViper OFFLINE
VicViper
    Dragonstomper
  • 591 posts
Posted Thu Sep 7, 2017 4:01 AM
Thanks for the replies guys!
#6 RXB OFFLINE
RXB
  • 2,875 posts
Posted Thu Sep 7, 2017 8:23 AM
Stephen
Personally I have a SCSI card with 2 Hard Drives so I edited it to run from WDS1.SE.SPEAK
This loads a file that calls a file I made using RXB copy of the Lower 8K into RAM, then runs the XB program.
#7 sparkdrummer OFFLINE
sparkdrummer
    Dragonstomper
  • 807 posts
  • Status? I don't need no stinkin' status!
Posted Fri Sep 8, 2017 9:24 AM
Attached File  TEXTSPEECH.DSK   90KB   12 downloads
Text to Speech, runs out of Extended Basic - Requires 32k and Speech Synthesizer.
PHRASE_OLD - Original XB program that loads in DF/80 Assembly programs - load time over 1 minute.
PHRASE_NEW - Using the fantastic SYSTEX by Barry Boone - load time 10 seconds.
#8 RXB OFFLINE
RXB
  • 2,875 posts
Posted Fri Sep 8, 2017 10:48 AM
attachicon.gifTEXTSPEECH.DSK
RXB using CALL BLOAD does it faster then Systex and bonus can load 960K of SAMS also if needed.
#9 CamTheBridge OFFLINE
CamTheBridge
    Space Invader
  • 16 posts
Posted Sat Dec 30, 2017 7:10 PM
This is super cool, but I can only get it to work some of the time.  Do you know why that might be? Sometimes it loads up no problem, other times it says that it can't find the subprogram "sload." Have you had this issue too?
  • RXB likes this
#10 RXB OFFLINE
RXB
  • 2,875 posts
Posted Sun Dec 31, 2017 10:49 AM
Yea I had this issue all the time.
RXB has CALL BLOAD("DSK#.FILENAME") and CALL BSAVE("DSK#.FILENAME") that save lower 8K in Program Image Format.
I have converted all my programs to RXB as they load faster and do not crash. Besides works with SAMS too.
#11 CamTheBridge OFFLINE
CamTheBridge
    Space Invader
  • 16 posts
Posted Sun Dec 31, 2017 2:12 PM
My only issue with using RXB is that I want to be able to run my programs on my actual hardware and let other be able to run it on actual hardware easily.  It seems like RXB is like another cartridge?
#12 Ksarul OFFLINE
Ksarul
  • 4,297 posts
Posted Sun Dec 31, 2017 2:45 PM
RXB is another cartridge, like standard Extended BASIC, but with a lot of extras too. It can be run from a GRAM device, a Final GROM cartridge, or using an UberGROM cartridge. The UberGROM is a perfectly standard cartridge with the program permanently installed, which is good for programming types. I build those, as does Arcadeshopper. If you go the FinalGROM toute, you can get one of those from Ralph Benzinger.
#13 Casey OFFLINE
Casey
    Chopper Commander
  • 174 posts
Posted Sun Dec 31, 2017 5:21 PM
I would just echo what has been said above.  RXB works great on real hardware from a FinalGROM.  There's lots to it that I haven't explored, but it definitely works great.
#14 RXB OFFLINE
RXB
  • 2,875 posts
Posted Sun Dec 31, 2017 5:43 PM
Hmm what other cartridge is that?
Sorry they answered that for me.
Edited by RXB, Sun Dec 31, 2017 5:44 PM.
