Which MOSFET for Atari Lynx I & II?
12 replies to this topic
#1 ATLynxer OFFLINE
ATLynxer
    Space Invader
  • 45 posts
Posted Tue Sep 12, 2017 9:51 AM
Hi, the original mosfet for the Lynx I & II, Motorola, cod. MTD3055E and ALSO its replacement, ST, cod. STD12N06 are out of production
I found STD12NF06L mosfet. In production at the moment.
Does it fit for the purpose, in your opinion?
Here the datasheets:
MTD3055E: http://www.alldatash...A/MTD3055E.html
STD12N06: http://www.alldatash...S/STD12N06.html
STD12NF06L: http://www.alldatash...STD12NF06L.html
#2 karri OFFLINE
karri
  • 2,305 posts
Posted Tue Sep 12, 2017 12:45 PM
Sounds ok to me. Get the one with suffix T4.
#3 ATLynxer OFFLINE
ATLynxer
    Space Invader
  • 45 posts
Posted Tue Sep 12, 2017 2:40 PM
Thanks for your opinion karri...and off course the t4 to-252 :thumbsup: :)
#4 Stephen Moss OFFLINE
Stephen Moss
  • 1,062 posts
Posted Wed Sep 13, 2017 1:23 AM
Towers lists SMD15N05 as a replacement if that is still in production as my copy of Towers is date 1994!
The NTD3055L104G NTD3055L104T4G appear to be direct replacements and still in production.
#5 -^CrožBow^- ONLINE
-^CrožBow^-
  • 6,023 posts
  • Collector of Fine Atari and Sega Antiquities!
Posted Wed Sep 13, 2017 7:24 AM
This should be all you need:
https://console5.com...power-jack.html
#6 ATLynxer OFFLINE
ATLynxer
    Space Invader
  • 45 posts
Posted Wed Sep 13, 2017 1:51 PM
I talked with some electronic experts here in Italy. We compared the datasheets (for the Lynx expressly) and they told me that STD12NF06L is better than the original mosfet....
i've ordered a couple and I will try it...
Edited by ATLynxer, Wed Sep 13, 2017 1:53 PM.
#7 ATLynxer OFFLINE
ATLynxer
    Space Invader
  • 45 posts
Posted Sun Sep 17, 2017 8:32 AM
I confirm you it works great! :thumbsup:
#8 GadgetUK OFFLINE
GadgetUK
  • 1,927 posts
Posted Mon Sep 18, 2017 6:11 AM
Great =D  I've ordered some too.  Next we need to find a better replacement for the zenner!  I guess just uprating the current capability should do there.
#9 cowdog360 OFFLINE
cowdog360
    Moonsweeper
  • 282 posts
Posted Mon Oct 23, 2017 11:10 AM
I'm now using a 2SK2231 MOSFET.  Modern, more available, a LOT more efficient.. burns less power.
#10 Level42 OFFLINE
Level42
  • 2,105 posts
Posted Tue Oct 24, 2017 11:31 PM
Best option is getting rid of the entire 9V to 5V section....
#11 karri OFFLINE
karri
  • 2,305 posts
Posted Wed Oct 25, 2017 2:26 AM
I wonder if there is some modern powerpacks that would fit in the Lynx cover?
USB power sockets are everywhere so you would just need a small cable to charge the powerpack.
Perhaps a powerpack with dual output would work (one for the Lynx, one for McWill screen). These powerpacks seem to deliver up to 2A per port.
#12 icemanxp300 OFFLINE
icemanxp300
  • 4,545 posts
Posted Fri Dec 29, 2017 10:26 PM
Can you send me a link to what you purchased? I need a new mosfet. Mine would not power on so I watched a YouTube video about bypassing it by running a wire from battery negative to headphone jack ground. Yes it did work and the Lynx powered on but I also had smoke coming out LOL. I opened it up to see the insulation on the wire had been burning off. I guess ide wire is not good for this application. At any rate I know what the problem is now.
#13 karri OFFLINE
karri
  • 2,305 posts
Posted Sat Dec 30, 2017 7:20 AM
The age of the Lynx is killing the capacitors as well. So I would suggest to change the whole set. My White Lynx died recently and just changing the largest capacitor brought it back.
http://atariage.com/...-mod/?p=3776590
I still have a set in case you want one.
