repetto74 Posted September 15, 2017 Share Posted September 15, 2017 I have modded today the 6 switch Atari 2600 with the small PCB adapter provided by TheFuturewas8Bit (thanks to them ). I do have an output with color and sound but I would like to be sure that this is the best result I can have with composite. I did the mod following instructions closely, so removed the RF modulator, resistors, transistor and the red coil then wired everything up. As per the pictures taken from an LCD and a CRT TV I can see that colors are a little bit too bright and that there are those annoying vertical shadows lines across the screen. Can this be fixed to improve image or maybe someone can suggest me to check the mod if something may be not correct? There is a resistor I can tweak with a screwdrive I think to adjust color. Thanks Rick Quote Link to comment Share on other sites More sharing options...
repetto74 Posted September 16, 2017 Author Share Posted September 16, 2017 That's solved then. I had to turn the color pot full counterclockwise position and now the video is cleared from shadows ? Quote Link to comment Share on other sites More sharing options...
