Floppy Emu on a 2c
14 replies to this topic
#1 BydoEmpire OFFLINE
BydoEmpire
  • 2,862 posts
Posted Sun Sep 17, 2017 2:44 PM
So as far as I can tell, the Floppy Emu is pretty much worthless with a Apple //c on rom v3.  My only thought is to use disk copy to copy files from the floppy emu to a real blank 5 1/4" disk and run from there.  Seems like it should work if the games aren't heavily protected.
Anyone else have good solutions?
I've heard there's some jumper you can add to make it boot to the external floppy drive, but I haven't found any directions.  Anyone try this?
#2 Polymorph OFFLINE
Polymorph
    Space Invader
  • 45 posts
Posted Sun Sep 17, 2017 5:50 PM
Sounds like you need this:
https://github.com/mgcaret/rom4x
#3 BydoEmpire OFFLINE
BydoEmpire
  • 2,862 posts
Posted Sun Sep 17, 2017 8:02 PM
Oooh, that looks perfect!
#4 towmater OFFLINE
towmater
    Dragonstomper
  • 552 posts
Posted Mon Sep 18, 2017 8:06 AM
"Now you will need a 65C02 cross assembler. The current codebase is developed using ca65 from the cc65 project. (Note: The code was developed originally using xa).
Finally you will need Ruby and Rake."
I gather fear of the wrath of Apple has prevented the author from providing the ROM directly?
#5 BydoEmpire OFFLINE
BydoEmpire
  • 2,862 posts
Posted Mon Sep 18, 2017 8:14 AM
Maybe, but if an enterprising individual were to offer a rom for sale at a nominal fee I suspect I'd be inclined to take advantage.
#6 thorr OFFLINE
thorr
    Chopper Commander
  • 163 posts
Posted Mon Sep 18, 2017 12:07 PM
I have the Floppy Emu on my Apple 2c and it is AWESOME.  What I did was purchase the Apple Disk Drive A/B Switch and Cable and ran a floppy cable from the internal floppy connector through the back aux/monitor port above the port connector and below the plastic, connected it to the switch, and back to the internal drive.  Then I also connected the Floppy Emu to the switch, and I can very easily switch between the internal drive and the Floppy Emu.  If I want to use it in Smart Port mode, I move it to the external floppy connector on the back with the provided adapter.  It meets all of my needs.  For the cables running through the back, they are both longer, and on the Floppy Emu I used the short internal one that came with the IIc.
#7 7800 OFFLINE
    Dragonstomper
  • 663 posts
  • Miserable SOB
Posted Sun Mar 4, 2018 1:36 PM
Or if you only need one drive... the floppy emu, open up your //c, disconnect the original floppy drive from the motherboard, and plug in the floppy emu. Run the ribbon cable right out of the back where the alternate disk drive port is. I like the AB Switch idea though.
#8 BydoEmpire OFFLINE
BydoEmpire
  • 2,862 posts
Posted Sun Mar 4, 2018 2:03 PM
FWIW, that's what I did and it worked great.  It took all of about 15 minutes.  I haven't used my floppy drive since, but nice to know it's ready to go if I want it.
#9 thorr OFFLINE
thorr
    Chopper Commander
  • 163 posts
Posted Mon Mar 5, 2018 3:37 PM
Glad to help!  This information wasn't available when I took the plunge and I wanted to get the word out there for others.  The FloppyEmu is a great solution for Apple IIc owners in this configuration.  It also works with my Mac LCIII and allowed me to get that going along with a SCSI2SD, so it was worth double for every penny.  Since I bought it, it now also supports 3.5" drive support on the IIc. I am hoping that one day it will emulate multiple daisy chained drives at the same time.  Not that I really need this, but it would be cool.
#10 c0op3r OFFLINE
c0op3r
    Chopper Commander
  • 120 posts
Posted Tue Mar 6, 2018 7:48 PM
Im a little confused by your statement the Floppy EMU works great on a IIc.
have you put some images on the SDcard?  If so just catalog the disk and run the disk/file.
If you want it as your main drive someone already suggested open the machine and put the cable from the EMU directly to the board. no need for a ROM 4x (even though its a really cool mod, I have the %x in my Apple IIc Plus).
#11 thorr OFFLINE
thorr
    Chopper Commander
  • 163 posts
Posted Wed Mar 7, 2018 6:23 PM
He has since figured it out (see the later posts in this thread).  I had not heard of the ROM 4x before.  I googled it and it looks to be very awesome.  Do you know of a way I could get this created for me without having to build it and program the ROM chip myself?  I don't really *need* it, but it sounds worth pursuing anyway.
#12 c0op3r OFFLINE
c0op3r
    Chopper Commander
  • 120 posts
Posted Wed Mar 7, 2018 7:44 PM
Join the Facebook group: https://www.facebook.com/groups/5251478676/     the creator of the ROM is in the group and there are several that will burn you a ROM and ship it for about 10$
#13 thorr OFFLINE
thorr
    Chopper Commander
  • 163 posts
Posted Sat Mar 10, 2018 11:12 PM
Thanks, but the link isn't working.
Edited by thorr, Sat Mar 10, 2018 11:25 PM.
#14 thorr OFFLINE
thorr
    Chopper Commander
  • 163 posts
Posted Sun Mar 11, 2018 6:35 PM
Found it: https://www.facebook...56329719908677/
#15 7800 OFFLINE
    Dragonstomper
  • 663 posts
  • Miserable SOB
Posted Thu Mar 15, 2018 6:37 AM
Unrelated... But I recently bought a minty //c external disk drive from ebay. Obviously it's plugged into the Drive B port. What I didn't realize until after messing around with it, is that both drive ports are part of the same "SLOT". I was getting confused with slots and ports. LOL!
So Slot 6 is for the disk drives and apparently the computer recognizes which one is Drive A and Drive B. So now that I figured that out... I decided that I'm going to get some disks, copy GEOS (A GUI OS for the //c) from my emu on to a disk, and boot from it on Drive A. From there, I should be able to open other disks from Drive B via GEOS. I guess the whole point of GEOS is to theoretically make it easier and more interactive as opposed to using BASIC commands.
I do think it's kinda cool using and GUI and a mouse with a computer that was ultimately designed to mainly function from BASIC.
Reply to this topic
