Text in Game
3 replies to this topic
#1 EvoMikeUK OFFLINE
EvoMikeUK
    Space Invader
  • 38 posts
Posted Tue Sep 19, 2017 4:45 AM
Hi All,
What is the best way to deliver text-to-screen on the Atari?
Just a couple of short words here and there. I'm thinking using a few sprites but obviously this will lead to flicker.
A previous post eludes to the title-screen kernel, but I want to avoid using that.
Kind thanks,
Mike
Edited by EvoMikeUK, Tue Sep 19, 2017 4:47 AM.
#2 atari2600land ONLINE
atari2600land
    Channel F Viewer
  • 11,217 posts
Posted Thu Sep 21, 2017 3:42 PM
Well, if you don't want to use a score, you could use the score for it. You could also use the pfblocks.
#3 EvoMikeUK OFFLINE
EvoMikeUK
    Space Invader
  • 38 posts
Posted Fri Sep 22, 2017 6:42 AM
Is there a way, to alternate every, 3-5 seconds between score and a piece of text?
#4 atari2600land ONLINE
atari2600land
    Channel F Viewer
  • 11,217 posts
Posted Fri Sep 22, 2017 9:04 AM
It really depends on how much text you want to have. If you use the score, that means you'd be using all the numbers 0-9, which means that you'd only have A-F characters available to display messages and stuff. I was thinking without the score, you'd have 0-9 to work with whatever text you'd want. For instance, to make the letter D, you'd only need three of the 8 pixels, so that would help a little. An E would only need 2. So you could make a message "DE" using only 7 of the 8 pixels (counting spaces).
