>FFE8
42 replies to this topic
#1 senior_falcon OFFLINE
senior_falcon
  • 1,223 posts
Posted Thu Sep 21, 2017 8:09 PM
In XB there are 24 bytes from >FFE8 to >FFFF that are not used by Extended BASIC.  Why are these bytes reserved?  Is there any reason they cannot be used as a mailbox to pass information between different XB programs?
Edited by senior_falcon, Fri Sep 22, 2017 6:08 AM.
#2 RXB OFFLINE
RXB
  • 3,254 posts
Posted Fri Sep 22, 2017 3:52 AM
Many years ago I read something about >FFE8 to >FFFF being assigned to a TI memory expansion concept mentioned in the XB ROM source that I lost.
It did not explain anything about it or how it worked. But it did mention a DEBUGGER CARD being used to demo the use.
#3 senior_falcon OFFLINE
senior_falcon
  • 1,223 posts
Posted Fri Sep 22, 2017 1:25 PM
It was reserved for some purpose and that makes as much sense as anything.  Load interrupt uses >FFFC and >FFFE, but that's the only use I can see in that area.
#4 acadiel OFFLINE
acadiel
  • 1,407 posts
  • www.hexbus.com
Posted Fri Sep 22, 2017 6:56 PM
Corcomp Load Interrupt Card. I had modded it a while back to remove the 5V from the sidecarts I was dumping. LOL. Power up, go into Mini Mem, give the side car 5V, and the dump the DSR and 32K space :-)
If you used it as intended, and pressed the button, it would go to >FFFC and jump to that address’ contents, I believe.
#5 Ksarul OFFLINE
Ksarul
  • 4,700 posts
Posted Fri Sep 22, 2017 8:18 PM
I think the RAM Trap used that space as well. . .
#6 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,163 posts
Posted Fri Sep 22, 2017 11:22 PM
Millers Graphics documentation doesn't show any use for that space.  I wonder if the space below the load interrupt vector was used in an older version of XB, or for some specific future function that was never implemented.
I use memory from >A000 up as my mailbox space in many programs.  For example, my BBS software uses >a000->a500 (just over 1k) for various buffers and information passing.  Since upper memory usage is determined by program size plus numeric variable run-time space, it is relatively easy to ensure my program 'modules' never cross into that area.
#7 ralphb OFFLINE
ralphb
    Dragonstomper
  • 569 posts
Posted Sun Sep 24, 2017 5:58 AM
According to Thierry: "As mentionned above, the five registers of the floppy disk controller map in the memory area >FFF0-FFFF. The addresses are different for read operations than for write operations".
#8 senior_falcon OFFLINE
senior_falcon
  • 1,223 posts
Posted Sun Sep 24, 2017 6:53 AM
That must be a misprint.  The assembly code examples on that page all show the registers stored at >5FF0 to >5FFF.  Which makes sense because the disk system will work without memory expansion.
#9 Lee Stewart OFFLINE
Lee Stewart
  • 3,701 posts
Posted Sun Sep 24, 2017 6:57 AM
I always wondered why TI Forth (and fbForth by inheritance) stayed clear of >FFF2 – >FFFF.  The 82-byte Terminal Input Buffer (>FFA0 – >FFF1) is the highest memory used.  Perhaps this is the reason—or not (per Harry's post above).
...lee
[Edits in this color.]
#10 Lee Stewart OFFLINE
Lee Stewart
  • 3,701 posts
Posted Sun Sep 24, 2017 7:06 AM
That makes even more sense in light of the table immediately following that statement.  When I first read it, that disparity puzzled me.
...lee
#11 senior_falcon OFFLINE
senior_falcon
  • 1,223 posts
Posted Sun Sep 24, 2017 10:12 AM
...lee
Plus, if you do a search for >5FF it occurs 41 times on that page with instructions like:
           MOVB @>5FF0,R6   Read FDC status register
RDY   MOVB R0,@>5FF8   Send command to FDC command register
etc.
#12 Airshack ONLINE
Airshack
    Dragonstomper
  • 764 posts
Posted Sun Sep 24, 2017 7:35 PM
Which Millers Graphics docs? Link?
Sent from my iPhone using Tapatalk Pro
#13 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,163 posts
Posted Sun Sep 24, 2017 8:37 PM
I thought I typed the reference.  Ah well.  It was Millers Graphics The Smart Programmer monthly newsletter. I was reading the real, printed document.
Edit:  Just got back home; the memory layout I looked at is in the March 1984 issue.
Edited by InsaneMultitasker, Sun Sep 24, 2017 10:06 PM.
#14 Lee Stewart OFFLINE
Lee Stewart
  • 3,701 posts
Posted Sun Sep 24, 2017 9:53 PM
...on the WHTech site under ..\magazines\smartprogrammer.
...lee
#15 RXB OFFLINE
RXB
  • 3,254 posts
Posted Mon Sep 25, 2017 8:28 AM
...lee
Hmm I told you guys it was for a future expansion paged memory created by TI, but never made it past set up stage.
It was mentioned on the side notes handwritten from my old XB ROM source I got from TI.
Edited by RXB, Mon Sep 25, 2017 8:30 AM.
#16 Airshack ONLINE
Airshack
    Dragonstomper
  • 764 posts
Posted Tue Sep 26, 2017 10:45 AM
Hey Rich, Are these handwritten notes scanned and archived anywhere? I can't remember reading this anywhere else? -j
#17 RXB OFFLINE
RXB
  • 3,254 posts
Posted Tue Sep 26, 2017 10:45 PM
I hand typed in all 5 inches of pages of the source including the handwritten notes and uploaded them to GENIE and the KEEP and other BBS.
I also mailed copies to numerous people after they asked for them on DISKs.
My computer SCSI Hard drive crashed and I lost all copies but to make matter worse I loaned the original hard copy to a buddy that lost them in a Portland Oregon flood.
So no unless someone has them from these copies I made we no longer have this source.
Edited by RXB, Wed Sep 27, 2017 8:27 PM.
#18 senior_falcon OFFLINE
senior_falcon
  • 1,223 posts
Posted Wed Sep 27, 2017 8:12 AM
That's discouraging!  Do you still have the original hard drive?  I had a hard drive crash and lost some pictures.  I was lucky-it was the circuit board on the drive that failed.  I got an identical drive on ebay and swapped out the board and was able to retrieve the pictures.
#19 Airshack ONLINE
Airshack
    Dragonstomper
  • 764 posts
Posted Wed Sep 27, 2017 3:57 PM
Wondering if those files are sitting around on some internet archive somewhere?
#20 RXB OFFLINE
RXB
  • 3,254 posts
Posted Wed Sep 27, 2017 8:30 PM
Sorry no I have extensive software on the Mac and Windows side to recover drive data and it was totally gone or corrupted beyond recovery.
#21 RXB OFFLINE
RXB
  • 3,254 posts
Posted Wed Sep 27, 2017 8:31 PM
I have repeatedly asked the community to search archives for it including WHT FTP that had a copy uploaded to it.....no replies.
#22 sparkdrummer ONLINE
sparkdrummer
    Dragonstomper
  • 932 posts
  • Status? I don't need no stinkin' status!
Posted Wed Sep 27, 2017 8:54 PM
Any idea of the file names Rich?
#23 RXB OFFLINE
RXB
  • 3,254 posts
Posted Thu Sep 28, 2017 3:01 AM
Yea all of them named XBROMSRC1 and 2 or XBROMS1 and 2.
#24 sparkdrummer ONLINE
sparkdrummer
    Dragonstomper
  • 932 posts
Posted Thu Sep 28, 2017 7:04 AM
Well, I looked in all my stuff for those files - I came up empty.
I came across some files that say IMYXB3 text and dsks - which are in a folder entitled RXB v2001 source - I don't suppose these are what you're looking for.
#25 RXB OFFLINE
RXB
  • 3,254 posts
Posted Thu Sep 28, 2017 8:24 AM
Sorry no this was done just before I released RXB 2001, at the time I think it was RXB version 5.55 released.
Edited by RXB, Thu Sep 28, 2017 8:25 AM.
