New tiny project: KEYCON keyboard adapter for XL/XE
Keyboard XL XE adapter
63 replies to this topic
#1 tf_hh ONLINE
tf_hh
    Dragonstomper
  • 788 posts
Posted Sun Sep 24, 2017 10:21 AM
Hi,
I´ve made a little tiny project which may not has a really amount of usage for standard user, but some tinkerer could found it useful. I call it simply "KEYCON" - a small adapter PCB for Atari XL or Atari XE keyboard connectors. First let´s take a look of the thing:
The PCB is 0.8mm thick and fits also in the original keyboard connector found on all XL/XE mainboards (except 1200XL and XEGS). There are several possibilities to attach a new keyboard connector or directly solder some wire connected to the keyboard. The KEYCON PCB can be used in an Atari XL or Atari XE. Of course you must use a XL keyboard when connected to a XL computer (and same for XE) like usual ;)
For diagnostic issues (for example using the Super SALT cartridgdes) the most needed keys are seperate located on the KEYCON PCB. So you can use endless loop tests and quick diagnostics with SALT without connecting a keyboard. This saves the mylar cables from breaking and so on. For each system (XL or XE) you will found the keys RESET, OPTION, SELECT, START and BREAK.
For already defective mylar keyboard cables, the main problem is always... how to connect ANY type of substitute to the genuine keyboard connector? Without using direct soldering or many glue it´s not a working solution for a long time. Some time in the past I also use ribbon cables and solder the cables directly to the pads on the mainboard, removing the keyboard connector before. Or, another solution is to use some single row pin heades, they can plugged into the genuine keyboard connector also, but must be fixed.
KEYCON can be used for a quick test (just plug the whole PCB with the front side into the existing, genuine connector on the XL/XE) or as a continuous replacement for defect keyboard connections.
Below this text you will fine some examples of usage.
I will only ship, for interested people, the bare PCB. Everybody has different needs and wishes, and all parts (IDC header connector, single row male header and so on) are easy to get in any electronics store. Tipp: sometimes they´re extremly cheap at shops selling accessoires for Arduino & Raspberry Pi solutions.
The final version will have ENIG (immersion gold finish) contacts, will be a little smaller than now (actual: 61x69 mm) and will fit better using an Atari 800XL. I have made a little wrong measurement, final version will fit perfectly.
Price for one bare PCB will be from 6 up to 9 Euros, depending on the amount of orders. Please show your interest (with quantity you want) here in this thread or by PN. I will collect responses until October, the 4th (2017-10-04) and then sent infos of final price and order details.
Shipping for up to 5 pieces worldwide is 5 Euros.
And now some pictures... Please read also the comments between the pics :)
KEYCON plugged into the genuine keyboard connector (Atari 800 XL mainboard)
Genuine keyboard connector replaced by a female row precision header.
KEYCON plugged into the replacement header. The five "XL" keys are in the same order (except BREAK) like on any standard XL keyboard. With this prototype layout, the PCB can´t be fit into a cased 800 XL. Of course final version will do.
This pictures shows ALL pads on the KEYCON PCB used. This is not mandatory of course. For example, if you install KEYCON permanently, the desoldered genuine keyboard connector isn´t useful placed at KEYCON. If you want to use a standard 50 pin ribbon cable as the new keyboard cable, then the IDC male header is needed, otherwise leave these pads empty. It´s on you how you want to use it. Also the tactile momentary switches for the keys named above must not installed, if not really needed. You can break this part of the KEYCON PCB away, if you want. There´s no electronics and special thing on KEYCON.
KEYCON plugged into the genuine keyboard connector (Atari XE mainboard)
KEYCON plugged into the replacement header. The five "XE" keys are in the same order (except BREAK) like on any standard XE keyboard.
In post o. 2 of this thread I will collect all interests and amounts.
Best regards, Jurgen
#2 tf_hh ONLINE
tf_hh
    Dragonstomper
  • 788 posts
Hi,
this 2nd post will be used to list all interests and amounts and will be regulary updated by me.
BR Jurgen
List of interests - 2017-10-04 9:00 pm (germany time)
Interest poll phase has ended. All interests got a PN with order and payment details.
SenorRossie                 2x
venom4728a                  1x
KlasO                       2x
Level42                     1x
erichenneke                 1x
Firedawg                    2x
Mathy                       2x
rdea6                       1x
Gandor                      2x
NISMOPC                     1x
remowilliams                2x
orpheuswaking               2x
olix                        2x
ivop                        1x
yenzee                      2x
mr_gw454                    1x
TemplarXB                   2x
toddtmw                     1x
dl7ukk                      5x
RodLightning                2x
Markk                       1x
#3 venom4728a OFFLINE
venom4728a
    Dragonstomper
  • 617 posts
Posted Sun Sep 24, 2017 9:44 PM
I would like one
#4 KlasO OFFLINE
KlasO
    Star Raider
  • 51 posts
Posted Mon Sep 25, 2017 11:29 AM
Two, please.
Kind regards,
Klas
#5 Level42 OFFLINE
Level42
  • 2,602 posts
Posted Mon Sep 25, 2017 12:20 PM
Dude, that is f-ing brilliant !!! You do NOT want to know how often I have been inserting that fragile flexible edge into open machines the last weeks....and then carefully ballancing the keyboard supported by something and praying it would not crash onto something and ripping the flex....and then trying to press some of the function keys....hah, it was more like a circus-act ! :)
Definitely need one please !  :thumbsup:  :thumbsup:  :thumbsup:  :thumbsup:  :thumbsup:  :thumbsup:
When they're done, kindly step into your DeLorean and deliver it to me about 3 months.ago......thank you ! :)
Edited by Level42, Mon Sep 25, 2017 12:20 PM.
#6 Firedawg OFFLINE
Firedawg
    Dragonstomper
  • 529 posts
Posted Mon Sep 25, 2017 2:01 PM
Very much needed for testing and repairing as I have several XLs without working keyboards. Jurgen I'll take two please.
#7 Mathy OFFLINE
Mathy
  • 2,940 posts
Posted Mon Sep 25, 2017 4:54 PM
Hello Jürgen
Two for me please!
Sincerely
Mathy
PS will they be ready on the 28th of October?
Edited by Mathy, Mon Sep 25, 2017 4:55 PM.
#8 tf_hh ONLINE
tf_hh
    Dragonstomper
  • 788 posts
Posted Tue Sep 26, 2017 1:30 AM
I will have them ready for ABBUC general annual meeting, yes.
Jurgen
#9 rdea6 OFFLINE
rdea6
  • 2,813 posts
Posted Tue Sep 26, 2017 4:03 AM
I would also like to have one KEYCON.
#10 Gandor OFFLINE
Gandor
    Moonsweeper
  • 395 posts
Posted Tue Sep 26, 2017 12:39 PM
I’m interested in 2
Sent from my iPhone using Tapatalk
#11 NISMOPC OFFLINE
NISMOPC
    Moonsweeper
  • 430 posts
Posted Tue Sep 26, 2017 2:26 PM
I would like one please...
THANKS!!
#12 remowilliams OFFLINE
remowilliams
  • 10,609 posts
Posted Tue Sep 26, 2017 10:23 PM
Excellent idea for a number of reasons, interested in two :)
#13 orpheuswaking OFFLINE
orpheuswaking
  • 5,820 posts
  • Lone Raider Time!
Posted Wed Sep 27, 2017 8:06 AM
I'll take two
#14 olix OFFLINE
olix
    Space Invader
  • 46 posts
Posted Wed Sep 27, 2017 8:51 AM
Ich würde zwei Stück nehmen.
Oliver
#15 ivop OFFLINE
ivop
    Dragonstomper
  • 912 posts
Posted Wed Sep 27, 2017 8:55 AM
I would like one, too!
Regards,
Ivo
Edited by ivop, Wed Sep 27, 2017 8:55 AM.
#16 yenzee OFFLINE
yenzee
    Space Invader
  • 16 posts
Posted Wed Sep 27, 2017 9:55 AM
Hallo Jürgen!
Ich nehme auch 2 !
Viele Grüße,
Jens.
#17 mr_gw454 OFFLINE
mr_gw454
    Star Raider
  • 63 posts
Posted Wed Sep 27, 2017 10:18 AM
Please add me to the list for one unit.  Thank you!
#18 TemplarXB OFFLINE
TemplarXB
    Star Raider
  • 69 posts
Posted Sat Sep 30, 2017 2:52 AM
I'm in for 2.
#19 toddtmw OFFLINE
toddtmw
    Dragonstomper
  • 563 posts
Posted Sat Sep 30, 2017 8:34 PM
#20 dl7ukk OFFLINE
dl7ukk
    Space Invader
  • 33 posts
Posted Mon Oct 2, 2017 12:07 PM
Hello tffh,
please 5 pieces for me.
Regards
#21 Level42 OFFLINE
Level42
  • 2,602 posts
Posted Mon Oct 2, 2017 1:27 PM
So, I assume that because of the thin PCB size it is still possible to insert the original keyboard mylar after using KEYCON for those systems that are still original ?
#22 RodLightning OFFLINE
RodLightning
    Dragonstomper
  • 757 posts
Posted Mon Oct 2, 2017 10:21 PM
Hi Jurgen,
Please add me to the list for two (2) boards.  Thank you!
LOL, almost missed the deadline.  :)
#23 Markk OFFLINE
Markk
    Combat Commando
  • 5 posts
Posted Tue Oct 3, 2017 2:40 AM
Hallo Jürgen
Ich würde 1 nehmen
gruss Mark
#24 Sikor OFFLINE
Sikor
  • 1,471 posts
Posted Tue Oct 3, 2017 3:22 AM
Why separately XL and XE function keys? One set will be enought, I think...
#25 tf_hh ONLINE
tf_hh
    Dragonstomper
  • 788 posts
Posted Tue Oct 3, 2017 5:40 AM
You´re right... when I draw the PCB I don´t mention that these momentary push buttons have two independend ways.
Thanks for that idea, it will make the final version much smaller!
Jurgen
Also tagged with one or more of these keywords: Keyboard, XL, XE, adapter
1 user(s) are browsing this forum
0 members, 1 guests, 0 anonymous users
