[BETA]Astronomer wip
63 replies to this topic
#26 kdgarris OFFLINE
kdgarris
    Chopper Commander
  • 216 posts
Posted Sat Sep 30, 2017 10:21 AM
Do you have the readpaddle kernel option set?
#27 kdgarris OFFLINE
kdgarris
    Chopper Commander
  • 216 posts
Posted Sat Sep 30, 2017 10:25 AM
And, yes, you can definitely make an 8K game or larger with bB. Check out the romsize option on RT's page. If all you did is set romsize to 8K,and put a " . bank 2" line at the end of your source, it would automatically put the display kernel and graphics in bank 2, freeing up lots of space in bank 1 without even having to do any manual bankswitching.
#28 Coolcrab OFFLINE
Coolcrab
    Star Raider
  • 55 posts
Posted Sat Sep 30, 2017 10:35 AM
Yes, I have this at the top. And I'm following this example: http://www.randomterrain.com/atari-2600-memories-batari-basic-commands.html#pfpixel
I must be doing something wrong but I can't seem to find it.
 set kernel_options no_blank_lines readpaddle
 currentpaddle = 0
 drawscreen
#29 Coolcrab OFFLINE
Coolcrab
    Star Raider
  • 55 posts
Posted Sat Sep 30, 2017 12:48 PM
Ok I'm getting there as it now responds to the paddle and can move around. However as soon as I limit the value of paddle tot 29 (Or whatever other number) it gets stuck at one value and does not respond anymore. Am I missing something with how the paddle works? As far as I can see it should have a value between 0 and 77 so it should be easily capped if I say 'if x > 29 then x = 29' right?
#30 bogax OFFLINE
bogax
    Dragonstomper
  • 724 posts
Posted Mon Oct 2, 2017 8:12 PM
  Here I've rearranged your code some.
I added some code to test if any of the joy0 RLDU are pressed and
skip the line drawing if not
joy0 is bits 7..4 of SWCHA and a bit reads 0 if it's active
so it inverts SWCHA, masks for bits 7..4 and loops back if none are 1
I used variables p and q and let p range from 0..75 and q 0..20
p is then scaled by 13/32 to get 0..31 for x
and q is divided by 2 to get 0..10 for y
that's just to to show one way of dealing with a range of 0..77
and I added a test to see if x, y have changed no need to draw the (same) line again if not
I added a test to end the line when we've reached the right point in the major direction
not sure you'll always be at the right spot in the minor direction
initializes ea to 1/2 the delta for better accuracy and symmetry
added a custom point plotting bit to improve the speed
added a custom routine to clear the playfield
I rewrote the line drawing for better speed but it still goes over time on long lines
if you're also doing the score so I split the line drawing, putting x,y in the score
and reading joy0 among different frames
  drawscreen
  dim ea = a
  dim dy = b
  dim dx = c
  dim state = w
  dim x1 = temp1
  dim x0 = temp2
  dim y1 = temp3
  dim y0 = temp4
  dim ep = temp3
  dim xinc = temp4
  dim yinc = temp5
  dim delay = h
  dim rand16 = z
  dim xpos = k
  dim ypos = l
  dim sc1 = score
  dim sc2 = score + 1
  dim sc3 = score + 2
  x = 0
  y = 0
  t = 0
  player0:
  %11000000
  %11000000
  %00000000
  %00000000
  %00000000
  %00000000
  %00000000
  %00000000
end
  player1:
  %11110000
  %11110000
  %11110000
  %11110000
  %00000000
  %00000000
  %00000000
  %00000000
end
  COLUPF = $62
  scorecolor = $2A
  state = 1
mainloop
  COLUP0 = $1C
  COLUP1 = $B4
  drawscreen
  on state goto readjoy drawline doscore     ; drawing the line just about takes all of one frames worth of program time
  goto mainloop
readjoy
  temp1 = (SWCHA ^ $FF) & $F0                ; tests for joy0 RLDU active
  if !temp1 then mainloop                    ; predicate true iff temp1 = 0  goto not needed if we're within 128 bytes (and it's the only statement)
  if joy0up    && q >  0 then q = q - 1
  if joy0down  && q < 20 then q = q + 1
  if joy0left  && p >  2 then p = p - 3      ; p is meant to emulate a paddle (sort of) increments by 3 for speed of movement
  if joy0right && p < 75 then p = p + 3      ; which with the scaling makes the movement a little jerky
  x1 = (((p/4 + p)/4 + p)/2 + p)/4           ; scales p by 13/32 to get 0..31
  y1 = q/2                                   ; and has the effect of slowing the movement ie 2 frames/q's to change y by one
  if x1 = x && y1 = y then goto mainloop     ; no need to draw the line if x and y haven't changed
  x = x1 : y = y1
  state = 1 : goto mainloop
doscore
  temp6 = x : gosub leftsc                 ; puts x in the left three digits of score
  temp6 = y : gosub rightsc                ; puts y in the right three digits of score
  state = 0
  goto mainloop
drawline
  x0 = 14 : y0 = 9 : x1 = x : y1 = y
  gosub clpf
setup_line
  if x0 < x1 then f{2} = 1 : dx = x1 - x0 else f{2} = 0 : dx = x0 - x1
  if y0 < y1 then f{1} = 1 : dy = y1 - y0 else f{1} = 0 : dy = y0 - y1
  xpos = x0 : ypos = y0
  if dx > dy then xmajor
  ; initializes ea to 1/2 for better accuracy, symmetry
  f{0} = 0 : xinc = xinc_tbl[f] : yinc = yinc_tbl[f] : ea = dy/2 : ep = y1
  goto yentry
yloop
  ypos = ypos + yinc
  temp1 = ea
  ea = ea - dx
  if temp1 < ea then ea = ea + dy : xpos = xpos + xinc
yentry
  ;  plots a pf pixel
  temp1 = xpos/8
  temp1 = ypos * 4 | temp1
  temp2 = xpos & $0F
  var0[temp1] = var0[temp1] | setbyte[temp2]    ; setbyte is the kernel table for setting playfield bits
  if ypos <> ep then yloop                      ; loops if not at end in major direction in this case y but not sure it wont miss its x
  state = 2 : goto mainloop
xmajor
  f{0} = 1 : xinc = xinc_tbl[f] : yinc = yinc_tbl[f] : ea = dx/2 : ep = x1
  goto xentry
xloop
  xpos = xpos + xinc
  temp1 = ea
  ea = ea - dy
  if temp1 < ea then ea = ea + dx : ypos = ypos + yinc
xentry
  ;  plots a pf pixel
  temp1 = xpos/8
  temp2 = xpos & $0F
  if xpos <> ep then xloop
  data yinc_tbl
  $FF, $FF, $01, $01, $FF, $FF,$01, $01
end
  data xinc_tbl
  $FF, $FF, $FF, $FF, $01, $01, $01, $01
end
pf
  playfield:
end
  return
  ;  fastest way to clear playfield
clpf
  var0=0:var1=0:var2=0:var3=0:var4=0:var5=0:var6=0:var7=0:var8=0:var9=0:var10=0:var11=0:var12=0:var13=0:var14=0:var15=0:var16=0:var17=0:var18=0:var19=0:var20=0:var21=0:var22=0
  var23=0:var24=0:var25=0:var26=0:var27=0:var28=0:var29=0:var30=0:var31=0:var32=0:var33=0:var34=0:var35=0:var36=0:var37=0:var38=0:var39=0:var40=0:var41=0:var42=0:var43=0
  return
leftsc
   sc1 = 0 : sc2 = sc2 & 15
   if temp6 >= 100 then sc1 = sc1 + 16 : temp6 = temp6 - 100
   if temp6 >=  50 then sc1 = sc1 +  5 : temp6 = temp6 -  50
   if temp6 >=  30 then sc1 = sc1 +  3 : temp6 = temp6 -  30
   if temp6 >=  20 then sc1 = sc1 +  2 : temp6 = temp6 -  20
   if temp6 >=  10 then sc1 = sc1 +  1 : temp6 = temp6 -  10
   sc2 = (temp6 * 4 * 4) | sc2
  return
rightsc
   sc2 = sc2 & 240 : sc3 = 0
   if temp6 >= 100 then sc2 = sc2 +  1 : temp6 = temp6 - 100
   if temp6 >=  50 then sc3 = sc3 + 80 : temp6 = temp6 -  50
   if temp6 >=  30 then sc3 = sc3 + 48 : temp6 = temp6 -  30
   if temp6 >=  20 then sc3 = sc3 + 32 : temp6 = temp6 -  20
   if temp6 >=  10 then sc3 = sc3 + 16 : temp6 = temp6 -  10
   sc3 = sc3 | temp6
  return
busy
  COLUP0 = $1C
  COLUP1 = $B4
  drawscreen
  goto busy
Edited by bogax, Mon Oct 2, 2017 8:48 PM.
#31 Coolcrab OFFLINE
Coolcrab
    Star Raider
  • 55 posts
Posted Tue Oct 3, 2017 1:36 AM
  drawscreen
  dim ea = a
  dim dy = b
  dim dx = c
  dim state = w
  dim x1 = temp1
  dim x0 = temp2
  dim y1 = temp3
  dim y0 = temp4
  dim ep = temp3
  dim xinc = temp4
  dim yinc = temp5
  dim delay = h
  dim rand16 = z
  dim xpos = k
  dim ypos = l
  dim sc1 = score
  dim sc2 = score + 1
  dim sc3 = score + 2
  x = 0
  y = 0
  t = 0
  player0:
  %11000000
  %11000000
  %00000000
  %00000000
  %00000000
  %00000000
  %00000000
  %00000000
end
  player1:
  %11110000
  %11110000
  %11110000
  %11110000
  %00000000
  %00000000
  %00000000
  %00000000
end
  COLUPF = $62
  scorecolor = $2A
  state = 1
mainloop
  COLUP0 = $1C
  COLUP1 = $B4
  drawscreen
  goto mainloop
readjoy
  x = x1 : y = y1
doscore
  state = 0
  goto mainloop
drawline
  gosub clpf
setup_line
  goto yentry
yloop
  ypos = ypos + yinc
  temp1 = ea
  ea = ea - dx
yentry
  ;  plots a pf pixel
  temp1 = xpos/8
  temp2 = xpos & $0F
xmajor
  goto xentry
xloop
  xpos = xpos + xinc
  temp1 = ea
  ea = ea - dy
xentry
  ;  plots a pf pixel
  temp1 = xpos/8
  temp2 = xpos & $0F
  data yinc_tbl
end
  data xinc_tbl
end
pf
  playfield:
end
  return
clpf
  return
leftsc
  return
rightsc
   sc3 = sc3 | temp6
  return
busy
  COLUP0 = $1C
  COLUP1 = $B4
  drawscreen
  goto busy
Wow this is great! I'll play around with it when I'm home tonight. Amazing how smooth it runs
#32 Coolcrab OFFLINE
Coolcrab
    Star Raider
  • 55 posts
Posted Tue Oct 3, 2017 12:12 PM
Ok I understand most of your code, but I was wondering how you came up with the equation for limiting p between 0-31. Is there a reason that its all div 2 and div4 instead of 53p/128? I assume there is some limit to the math the atari can do?
The code you gave is perfect, apart from the fact that the y position is changed with up and down. I want to add 3 if statements that make it go down in y when it reaches 0,0 and the player still presses left and the same for (31,0). Sothat you can swoop the entire border with just 2 directions. (soon to be paddles hopefully.)  But since the range for x1 needs to be extended from 0-31 to 0-47 he equation you gave is not correct. 5p/8 should do the trick but it doesn't. Should I write this as something with only two's?
I've tried to recreate your process in my code and it works reasonably but I get catastrophic failure if I split the movement like this.
enter
 xpos=14 :  ypos=9
 pfpixel xpos ypos on
 x0 = xpos : y0 = ypos
 if x < 8 then x1 = 0 : y1 = 8-x
 if x> 7 && x < 37 then x1 = x-8  :  y1 = 0
 if x > 36 && x < 44 then x1=29 : y1=36-x
 if x> 45 then x1 = 29 : y1 = 8
 gosub setup_move
 goto pf
However it just jumps all over the place and even makes sound if i got off screen far enough. :P I'll keep puzzling, but if anyone sees anything stupid please tell me.
Edited by Coolcrab, Tue Oct 3, 2017 12:34 PM.
#33 SpiceWare ONLINE
SpiceWare
    Draconian
  • 11,673 posts
  • Medieval Mayhem
Posted Tue Oct 3, 2017 1:21 PM
While the 6502 can add and subtract, it does not have multiply or divide instructions. It does have bit shifting instructions, which are the equivalent to times two (shift left) or divide by two (shift right).
Those instructions are ASL and ROL for shift left,  LSR and ROR for shift right.
In my tutorial I cover how you would multiple by five by converting
X * 5
to:
X * 2 * 2 + X
#34 bogax OFFLINE
bogax
    Dragonstomper
  • 724 posts
Posted Tue Oct 3, 2017 7:19 PM
oops, yup I started with 13/32 but decided on more accuracy and forgot to change the comments when I went to 53/128
You're working with 8 bit bytes which limits you to integers 0..255.  Any fractional part gets truncated.
so the idea is to keep the partial products as large as possible and not throw anything away before you need to
(with out having them too large, the first partial product is 5/4 before the second division by 4 so would overflow
for anything larger than 4/5 * 255 ie  205/4 + 205 = 256, too big)
You could do what you want with if statements but I'd just have a variable that ranged 0.. 50 (or what ever) and look up
x, y in a table it wouldn't take much more space and it would be a lot faster and it would be much more flexible.
Not sure what you're doing but in the changed code the set up and line drawing are no longer subroutines
although they could be if that was useful but I figured it would be faster if they weren't
#35 Coolcrab OFFLINE
Coolcrab
    Star Raider
  • 55 posts
Posted Sun Nov 12, 2017 10:59 AM
I finally got some time to spend on this again. :) I managed to make the line move smooth from lower left to lower right and added in a star that the player needs to track. But its too fast and flies horizontally now.
I was wondering if it is possible to make payer0 rotate around a certain coordinate. Preferably some star appears somewhere in the lower left corner with a random y coordinate and then rises and sets around say the lower central point. (where the telescope is.)
Other than that, as far as I understand I can draw 2 stars at a time. Player1 and 2. Is it possible to draw any more if they behave the same anyway?
#36 Coolcrab OFFLINE
Coolcrab
    Star Raider
  • 55 posts
Posted Sun Dec 3, 2017 6:07 PM
Thanks to some very useful tips from Bogax I've gotten a new version of the game out. (Download on main post)
Feedback and suggestions welcome!
#37 Keatah OFFLINE
Keatah
  • 18,936 posts
Posted Sun Dec 3, 2017 6:18 PM
The actual rom should be appended with a version and/or a date.
#38 Coolcrab OFFLINE
Coolcrab
    Star Raider
  • 55 posts
Posted Mon Dec 4, 2017 1:30 AM
I added a .bin to the main post
#39 Keatah OFFLINE
Keatah
  • 18,936 posts
Posted Mon Dec 4, 2017 2:12 AM
What's the difference between the two .bin files?
#40 Coolcrab OFFLINE
Coolcrab
    Star Raider
  • 55 posts
Posted Mon Dec 4, 2017 3:51 AM
default.bin.bas is the first version, kept for nostalgia? astronomer.0.4 is the current version.
Is it customary to remove old versions? I can do that. :P
#41 Keatah OFFLINE
Keatah
  • 18,936 posts
Posted Mon Dec 4, 2017 3:54 AM
Not really. old versions are just fine I'm sure.
#42 Coolcrab OFFLINE
Coolcrab
    Star Raider
  • 55 posts
Posted Mon Dec 4, 2017 4:15 AM
I guess that the name can be confusing.
I was also thinking of changing the score mechanics as to give you X points, and make them go down when observing the star. With each successful observation you need to work away more points and maybe the cloud moves faster.  What do you think? (assuming that you tried it)
#43 Coolcrab OFFLINE
Coolcrab
    Star Raider
  • 55 posts
Posted Mon Dec 4, 2017 2:16 PM
New version added to main page. You now got to get the score down from 1000 to 0 before the healthbar runs out. If you manage then you get the health back and score gets rest.
Next step is to make the health lower and score higher for each iteration and perhaps add a second score for #levels.
I think that this can be seen as a demo.
Feedback welcome :D
#44 chavert OFFLINE
chavert
    Moonsweeper
  • 348 posts
Posted Tue Dec 5, 2017 1:30 PM
I will test that tomorrow
Edit :  It works well on real hardware, good continuation.
#45 Coolcrab OFFLINE
Coolcrab
    Star Raider
  • 55 posts
Posted Wed Dec 6, 2017 4:26 PM
V0.5 is out! I added basic sound and changed the score mechanics.
The cloud now starts to move faster with each level and the star moves to a random location. (to simulate the selection of a new star)
I have a problem with the sound though, as it still keeps buzzing if you move the yellow beam off of a star or cloud. Any tips on fixing this?
Other feedback welcome!
#46 Random Terrain OFFLINE
Random Terrain
    Visual batari Basic User
  • 28,335 posts
  • Controlled Randomness
    Replay Value
    Nonlinear
Posted Wed Dec 6, 2017 11:27 PM
You don't seem to have any REMS and you are using some plain old non-descriptive variables, so it's hard to know what is happening in the program. Things like "if !j" and "if !n" don't tell me anything.
#47 Coolcrab OFFLINE
Coolcrab
    Star Raider
  • 55 posts
Posted Thu Dec 7, 2017 5:28 PM
I tried to fix the variables but the code is not working, so I'll try again in the weekend. :P But the important part is this I think. So if it collides with the star it plays sound 3, if it collides with the cloud then it plays sound 1. These sounds keep going unless you put in a stop sound. (as far as I understand) So I added an if for when the fire button is not pressed. But the sound still plays if you keep it pressed and move away from the star.
  if collision(player0,playfield) && !collision(player1,playfield) && joy0fire then j = j - 1 : AUDC0 = 3
  if collision(player1,playfield) && joy0fire then n=n-1 :  AUDC0 = 1
  if !joy0fire then AUDC0 = 0
#48 Random Terrain OFFLINE
Random Terrain
  • 28,335 posts
    Replay Value
    Nonlinear
Posted Thu Dec 7, 2017 9:17 PM
Looks like sound is happening in two lines below that too, so maybe the problem could be there.
#49 Coolcrab OFFLINE
Coolcrab
    Star Raider
  • 55 posts
Posted Sat Dec 9, 2017 5:13 AM
I solved the sound problem, I had to add a sound stop when the beam didn't touch anything.
I also updated the game script to have descriptive variables, which helps I think.
The current change I am trying to make is to add paddle support when the left difficulty switch is set to A. I based it on RT's paddle example and tried to make the beam move as the paddle. However it still has some bugs that I didn't spot yet. (for some reason it goes to a game over when the paddle is all the way on the right)
Also it doesn't seem to work in paddle mode on the emulator (and I did change the control settings and reset the emulator. Could someone confirm?)
However it does work on my starpath supercharger so thats a way to test it. :P
Also how can I check how much space there is left on the 4k cart? I think that I might be reaching it.
Edited by Coolcrab, Sat Dec 9, 2017 5:16 AM.
#50 Random Terrain OFFLINE
Random Terrain
  • 28,335 posts
    Replay Value
    Nonlinear
Posted Sat Dec 9, 2017 8:20 AM
It won't compile for me. There is a mysterious verbose error message, but I can't find it.
