Tutorvision games - Interest check
263 replies to this topic
#51 JoeM_Intellivision OFFLINE
JoeM_Intellivision
  • 1,232 posts
Posted Tue Sep 26, 2017 3:35 AM
Hi pimpaul69,
Thanks for the reply & info mich appreciated. I would definitely be willing to have that done but have no tech skills to speak of lol:-) Maybe when time comes you or someone can mod this for me as I sure as hell won't be able to do it:)
#52 mr_me OFFLINE
mr_me
  • 4,178 posts
Posted Tue Sep 26, 2017 5:18 AM
This is the highest serial number for model 3504 A in the database and it's branded "INTV System III".
A 171447 Canada Steve Jones
I always thought that even if they were to use the same tutorvision mainboard in these Intellivisions there was a chance these boards might be jumpered to disable the extra gram. I'm not sure if there is such a jumper. And I'm not sure if they were aware of the incompatibility with extra gram; it affected very few cartridges. There also seems to be some evidence that some INTV systems had Intellivision II execs in them. I always wondered what that board looked like.
Looks like a couple have been found and noted here. https://docs.google....#h.htb2mb9zmtq7
Also it looks like the default title screen text is on the grom chip and not the exec chip. That means an Intellivision could have the updated titlescreen but not the tutorvision exec. One of the two systems found was like that. The other had the tutorvision exec according to that document. Both have the tutorvision mainboard.
Edit: Serials found: A-8644, A-031118
Hi pimpaul69,
Swapping an Intellivision mainboard only requires a philips screwdriver; just be carefull with the ribbon cable.
Edited by mr_me, Tue Sep 26, 2017 5:55 AM.
#53 freewheel OFFLINE
freewheel
  • 3,131 posts
Posted Tue Sep 26, 2017 6:46 AM
Well, one. You need the WBEXEC *and* new GROM to play these games, no?
It would be cool for someone to whip up a "what Intellivision do I have" ROM. Just plug your LTO Flash! in, and see the details. I would suggest based on serial numbers that either a) Rev might have a compatible one, or b) it's going to be entirely random :P
#54 mr_me OFFLINE
mr_me
  • 4,178 posts
Posted Tue Sep 26, 2017 6:54 AM
You don't need the new grom to play tutorvision games. You do need the tutorvision exec. If you don't have the tutorvision exec you might be able to add it through the cartridge port. You do need the tutorvision mainboard to play tutorvision cartridges.
There is a rom image that identifies execs. For tutorvision it might show as not identified. To test for a tutorvision mainboard you can play Worm Whomper, assuming there isnt a gram jumper.
#55 intvsteve OFFLINE
intvsteve
  • 3,393 posts
Posted Tue Sep 26, 2017 10:00 AM
I wonder if any of those SuperPro or other shells containing TutorVision hardware were repaired systems? I.e. a busted system was sent for repair and the only things left were those boards.
Or, conversely, what if "a bunch" (say 100) of these were made, but people thought they were defective because of graphics glitches e.g. Worm Whomper or other games displayed incorrectly. Those could have been sent in for repair and had their Tutorvision boards pulled out.
#56 Lathe26 OFFLINE
Lathe26
  • 3,942 posts
Posted Tue Sep 26, 2017 12:40 PM
It is my understanding that there is a 3rd component to the Tutorvision, besides the new EXEC and changed GROM. It had the ability to display a 2nd font (a proportional font) across the entire screen.
Originally, I had assumed this font was a high-resolution overlay (similar to the Keyboard Component's 2nd font). However, from photos online, it appears that the letters were still 8 pixels high and are aligned vertically to tiles (not horizontally, of course).
Thus, my suspicion is that the Tutorvision's 3rd upgrade was to have 4x the standard amount of GRAM. This would require solder work on a standard Intellivision (not upgradable via the cartridge port). They might have upgraded the STIC video chip, but I haven't seen anything that would require that yet.
#57 mr_me OFFLINE
mr_me
  • 4,178 posts
Posted Tue Sep 26, 2017 2:01 PM
Yes, there is a slight change with the STIC. It now displays 160 horizontal pixels instead of 159. So with a game like Major League Baseball or NHL Hockey you can easily tell if that extra pixel is there on the right. That should be a foolproof way to detect the presence of the tutorvision board. All other tests have a chance of failing, although I think the titlescreen test might do it.
The narrow font comes from new routines on the exec chip, I believe. There's also extra 16-bit ram so someone could write a program to detect that. Everything you want to know about the tutorvision can be found here. https://docs.google....1uc/mobilebasic
And what's the difference between Super Pro and INTV System III intellivisions. Their bottom labels look identical and their serial numbers appear mixed. I thought I read that brand was created at the request of a retailer. The Super Pro brand was never advertised in the INTV direct order catalogs. I also thought I read that the system stopped when they stopped supplying retailers due to INTV signing a developer licensing deal with Nintendo. Is there any reason not to check INTV System III for tutorvision boards.
Edited by mr_me, Tue Sep 26, 2017 2:10 PM.
#58 the1hatman OFFLINE
the1hatman
  • 1,279 posts
Posted Wed Sep 27, 2017 8:38 PM
Um...
...so what does this mean now?
#59 freewheel OFFLINE
freewheel
  • 3,131 posts
Posted Wed Sep 27, 2017 8:43 PM
Neat :D It means you have the Tutorvision GROM. Next step is to try to play Worm Whomper on it. Apparently the worms won't look right, if you have the full board.
Also weren't the Tutorvision ROMs released on one of these threads? Couldn't a person just put them on an LTO Flash! and see what happens?
#60 the1hatman OFFLINE
the1hatman
  • 1,279 posts
Posted Wed Sep 27, 2017 8:47 PM
If needed, I can open the case and check the chipset when I get home tomorrow. Not sure what to look for as I am not well versed in INTV hardware.
#61 cmart604 ONLINE
cmart604
    Intellivision Hoarder
  • 12,491 posts
  • Running out of things to buy.
Posted Wed Sep 27, 2017 9:24 PM
More importantly, yay, youre alive! :)
#62 freewheel OFFLINE
freewheel
  • 3,131 posts
Posted Wed Sep 27, 2017 9:39 PM
Try some Tutorvision games on it :)
Seriously, no one else has tried this yet? What else do you people do other than play Intellivision? :mad:
#63 the1hatman OFFLINE
the1hatman
  • 1,279 posts
Posted Wed Sep 27, 2017 11:57 PM
As soon as one of the 2 or 3 people on Earth with a Tutorvision cartridge sends me one, I promise I'll fire it up  ;)
Edited by the1hatman, Wed Sep 27, 2017 11:58 PM.
#64 JasonlikesINTV OFFLINE
JasonlikesINTV
  • 9,791 posts
Posted Thu Sep 28, 2017 12:02 AM
Woohoo, you hit the jackpot! Nice to see you drop in for a visit. Hopefully life is treating you well :thumbsup:
#65 the1hatman OFFLINE
the1hatman
  • 1,279 posts
Posted Thu Sep 28, 2017 12:03 AM
#66 mr_me OFFLINE
mr_me
  • 4,178 posts
Posted Thu Sep 28, 2017 1:34 AM
Yes, the title screen means you have the grom.  It's possible, probably unlikely, to have that grom on a regular intellivision.
The worm whomper test will indicate extra gram and a tutorvision board.  However it might be possible that you have a tutorvision board but the extra gram is disabled (jumpered) and worm whomper worms look right.
Play NHL Hockey.  On a regular Intellivision board the left corner is rounder then the right corner.  On a tutorvision board the extra pixel will make it symmetrical (with or without extra gram or tutorvision exec/grom).
Finally, to test for the tutorvision exec play a tutorvision game.  Or run the attached exec check sum utility that tells you which exec you have.  A tutorvision exec should have a checksum of "e151aab2" for $400-$4ff (haven't tested on real hardware).
If you open it up, a tutorvision board will have a big square chip on top and the board is marked "INTV 1988".  Check the dates on the square chip, exec, and grom.
edit:
Tutorvision cartridge rom files posted here:  http://atariage.com/...ames/?p=3727487
Try them with a flash/memory cart.  Still waiting for Geo Graphics.
The serial number is very close to one of the others:  A 8644, A 031118,  and now A 031240
Edited by mr_me, Thu Sep 28, 2017 2:26 AM.
#67 m-crew OFFLINE
m-crew
  • 5,389 posts
Posted Thu Sep 28, 2017 3:13 AM
Oh the excitement of one possibly being found... Lucky you hatman.!!!
Edited by m-crew, Thu Sep 28, 2017 4:02 AM.
#68 mr_me OFFLINE
mr_me
  • 4,178 posts
Posted Thu Sep 28, 2017 4:01 AM
Actually, I'm not sure why the checksum at $400 changes.  The new tutorvision exec parts are suppose to be at $2000-$2fff, and its checksum shows as "43c145e1" in jzintv.  That's where the ECS rom sits, so an ECS might not work with a tutorvision exec.
Edited by mr_me, Thu Sep 28, 2017 4:07 AM.
#69 Lathe26 OFFLINE
Lathe26
  • 3,942 posts
Posted Thu Sep 28, 2017 10:13 AM
Would the "INTV Corporation" in the title screen mean that the1hatman has the Tutorvision EXEC (aka REX, for Revised EXec) or did the "INTV Corporation" text show up in EXECs before the Tutorvision?
We do know his unit definitely does no have the original Mattel EXEC from the Intellivision I or II (those said "Mattel Electronics").
#70 mr_me OFFLINE
mr_me
  • 4,178 posts
Posted Thu Sep 28, 2017 10:35 AM
You'd have to open it up and look at the date code printed on the grom chip. The only one I've seen has a date code of 8927 (mid 1989). The "INTV Corporation presents" text comes from the grom chip. Remember there are some exec routines on the grom chip. The serial numbers aren't making sense so far.
#71 intvsteve OFFLINE
intvsteve
  • 3,393 posts
Posted Thu Sep 28, 2017 12:08 PM
Yeah - looks like the revised EXEC there, since IIRC that's where the boilerplate copyright logic lives.
:-o  :-o  :-o  :-o  :-o
#72 mr_me OFFLINE
mr_me
  • 4,178 posts
Posted Thu Sep 28, 2017 1:15 PM
You guys should open up a grom file in a hex editor and you'll see the title screen text in there. Then try mix and matching exec files and grom files in an emulator and you'll see the titlescreen comes from the grom file.
Edit: And the tutorvision exec isnt really revised. The first 4k is identical to the original Mattel exec. There is a second 4k of tutorvision routines and data that's been added.
Edited by mr_me, Thu Sep 28, 2017 1:19 PM.
#73 Lathe26 OFFLINE
Lathe26
  • 3,942 posts
Posted Thu Sep 28, 2017 2:11 PM
I'd forgotten all about the snippet of code that was in the GROM and was thinking all code was held in the EXEC ROM.
Regarding calling it REX, this is the official name of the Tutorvision EXEC and the letters stand for "Revised EXec". http://intellivision...ook-tutorvision
#74 mr_me OFFLINE
mr_me
  • 4,178 posts
Posted Thu Sep 28, 2017 2:38 PM
Right, and what you're seeing in thehatman's screenshot is the original mattel exec behaviour. You'd have to do more tests to see if the REX extensions are in there as well.
#75 the1hatman OFFLINE
the1hatman
  • 1,279 posts
Posted Thu Sep 28, 2017 5:41 PM
When I open the case and look directly at the chips will they look like the following if it is a Tudorvision? (pics taken from the Tudorvision google docs page linked above):
GROM
WBEXEC
CPU
I'm thinking I can locate these or their equivalents in my Super Pro system once I open it.
