Tutorvision games - Interest check
261 replies to this topic
#101 grips03 OFFLINE
grips03
  • 3,805 posts
Posted Sat Oct 7, 2017 11:59 AM
he posted screen shot on post #58
#102 JasonlikesINTV OFFLINE
JasonlikesINTV
  • 9,579 posts
Posted Sat Oct 7, 2017 12:03 PM
I tested both of my Super Pro Systems and neither were Tutorvisions. I think I only have one System III and will try that one out this weekend.
#103 nanochess ONLINE
nanochess
    Processorus Polyglotus
  • 5,797 posts
  • Coding something good
Posted Sat Oct 7, 2017 12:18 PM
We cannot be sure the Super Pro systems are using the Tutorvision font.
Here is the program for testing for extra GRAM.
You should get trash in a normal Intellivision console, but a meaningful image in a system with the expanded GRAM
#104 freewheel OFFLINE
freewheel
  • 3,108 posts
It's very simple to check them, you don't need to open the console.
Just put in any game and look for the tutor vision font set on the title screen of any regular game.
Hatman you don't need a multicart to check yours. Just put in a regular game and post a pic of the title screen. ;)
Hm... I wonder if anyone has a WBEXEC but not the GROM. And would the games even play in that configuration.
Nanochess, someone smarter than me should come up with a ROM to test all things - the EXEC, GROM, and extra GRAM. Who knows what kinds of weird combos exist out there.
#105 nanochess ONLINE
nanochess
  • 5,797 posts
Posted Sat Oct 7, 2017 12:22 PM
Not possible, because the GROM contains the charset for all the letters used in the Intellivision games.
I could believe an expanded Intellivision exists without the WBEXEC, and the only way would be to open each one, but now you need only to put the cartridge in each system and test.
#106 JasonlikesINTV OFFLINE
JasonlikesINTV
  • 9,579 posts
Posted Sat Oct 7, 2017 12:24 PM
Keep in mind that I'm understanding only 10% if all this, but if there are consoles with only parts of what would be needed for full Tutorvision functionality could we theoretically cannibalize and Frankenstein them into a working one?
Edit: I might also test Worm Whomper on the Super Pro Systems. My original test was only checking for the font difference.
Edited by JasonlikesINTV, Sat Oct 7, 2017 12:49 PM.
#107 nanochess ONLINE
nanochess
  • 5,797 posts
Posted Sat Oct 7, 2017 12:26 PM
If some consoles have the expanded video, there is a possibility to create an add-on ROM for the motherboard containing the extra executable code of the Tutorvision and it would be a Tutorvision.
#108 stupus OFFLINE
stupus
  • 2,125 posts
  • pixel obcessed yeti
Posted Sat Oct 7, 2017 12:27 PM
so some could have some of the chips but not display the unique font?
I know the couple super pro systems I saw had the special font showing...but your saying some might be partial tutorvisions?
The other test is play worm whomper and if the small black worms show up as a cluster of dots then you have (I guess at least some) tutorvision chips.
And I agree who knows what they would have stuck in what for repairs and even individual owners swapping parts.
There definitely has to be very few of these though or somebody at some point over the last 30+ years would have noted the special chips.
Edited by stupus, Sat Oct 7, 2017 12:28 PM.
#109 stupus OFFLINE
stupus
  • 2,125 posts
Posted Sat Oct 7, 2017 12:31 PM
So the tutorvision uses a special grom too right? Because all fonts in all games on the tutorvision I believe use the new font set....so the tutorvisions probably cant display the original font set, right?
#110 nanochess ONLINE
nanochess
  • 5,797 posts
Posted Sat Oct 7, 2017 12:37 PM
Right :) unless you define it into the GRAM, but I think no game would do that.
#111 mr_me OFFLINE
mr_me
  • 3,825 posts
Posted Sat Oct 7, 2017 12:59 PM
is there a chance for Intv Systems III?
The tutorvision that Intellivision Productions has is an INTV System III.  It's not clear how/when the INTV System III and Super Pro systems manufacturing differed.
Of course there is :) We won't know until people check, and report back. You'd think with 100+ hardcore collectors here, we'd have more than 4 systems tested so far.
I think more than four systems have been tested only a few tutorvision boards (INTV 1988) have been found.
I could write a small program loadable in LTO-Flash that could check if your system is a Super Pro one, mainly writing to the extra GRAM.
The test would fail if the GRAM disable jumper has been connected.
It's possible, probably unlikely, that they made an old grom that fit the new board and you have a tutorvision board displaying the old font.  We know they made an old exec to fit the new board so why not the grom.
Tutorvision cartridges will play if you have the wbexec and the old grom (at least they do in emulation).  There is nothing in the grom that tutorvision cartridges need to run; only the large font will look different.
Wbexec can be tested with the csumexec.bin.
Grom can be tested with any old Mattel cartridge that uses the built-in title screen.
Gram can be tested by playing Worm Whomper, Space Patrol, maybe Ms. Pac-Man.  (keep in mind that it is possible that extra gram has been disabled by jumper)
The most important thing is the tutorvision main board (INTV 1988).  I think that can be tested by checking for the presense of the new STIC and the 160th pixel on the right of the screen (test with Tron Deadly Discs or NHL Hockey and check for symmetry).  Not sure if any older Intellivisions have this updated STIC if any does please say so.
Or you can just have a peak through the bottom vents and see if you can see the JP0-JP6 jumper block on the main board,
If you make an old grom that fits the new board the Tutorvision games should play with the old square font.  There is nothing in the new grom that Tutorvision cartridges need to play.
#112 grips03 OFFLINE
grips03
  • 3,805 posts
Posted Sat Oct 7, 2017 1:14 PM
Would be great to have the serial numbers that are not Tutorvision hardware as well.
#113 mr_me OFFLINE
mr_me
  • 3,825 posts
Posted Sat Oct 7, 2017 1:34 PM
I have a question.
Does anyone have an INTV System III or Super Pro System, made in the USA, with a serial number greater than A031500.  The serial number database says there are but I wanted to check if maybe there were some typos there,
#114 JasonlikesINTV OFFLINE
JasonlikesINTV
  • 9,579 posts
Posted Sat Oct 7, 2017 1:45 PM
My Super Pros are:
A 7229 (doesn't display fancy font)
A 11244 (doesn't display fancy font)
My System III is:
A 003168 (untested)
Edited by JasonlikesINTV, Sat Oct 7, 2017 1:46 PM.
#115 cmart604 ONLINE
cmart604
    Intellivision Hoarder
  • 12,289 posts
  • Running out of things to buy.
Posted Sat Oct 7, 2017 2:15 PM
Not even close. I'm not sure on the rarity factor (apparently for all the collectors here, almost no one has actually CHECKED :P), but I'd be surprised if more than 5-10% of Super Pros can do it.
I resemble that remark. :)
#116 Humblejack ONLINE
Humblejack
    Dragonstomper
  • 629 posts
Posted Sun Oct 8, 2017 10:26 AM
I got this pic many, many years ago off the net.  Any of you Sherlocks out there know how to hunt these down?
It would be great to dump this one also.
#117 stupus OFFLINE
stupus
  • 2,125 posts
Posted Sun Oct 8, 2017 11:26 AM
Isn't that just a regular commando game put in a tutor vision shell?
I think Kurt vendall bought a box full of the empty tutor vision shells if I remember correctly.
#118 scalpel OFFLINE
scalpel
  • 2,322 posts
Posted Sun Oct 8, 2017 3:05 PM
I would like to buy these 3 (or 4 ^^) games
This story/discovery is AMAZING !!!  :)  :thumbsup:  :thumbsup:  :)
#119 the1hatman OFFLINE
the1hatman
  • 1,229 posts
Posted Sun Oct 8, 2017 5:47 PM
Did you remove the metal rf shield or did it only have it on one side? Are you able to see that jumper block through the vents in the bottom case?
Edit: you can immediately tell it's a tutorvision board upon opening the case because it's missing the power supply daughterboard that would normally be in the lower right of the first photo.
So after all the deliberations here so far, can we say that the Super Pro System I have is a functional Tudorvision or it missing certain components to be a full version of one?
I do not have LTO Flash so I cannot preform any of the tests suggested here so far.
#120 freewheel OFFLINE
freewheel
  • 3,108 posts
Posted Sun Oct 8, 2017 5:56 PM
I'm willing to put good money that your system can play Tutorvision games. It's ironic that the one confirmed SP unit happens to be owned by someone without a flash cart, but what can you do.
(Insert obligatory plug for the LTO Flash!)
#121 stupus OFFLINE
stupus
  • 2,125 posts
Posted Sun Oct 8, 2017 6:03 PM
Did you test any regular cart to see if it show's the wb font on the title screen?
Or do you have worm whimper to see if it glitches on the small worms?
No lto needed for these.
And there are other confirmed super pro systems that are tutors. ;)
#122 mr_me OFFLINE
mr_me
  • 3,825 posts
Posted Sun Oct 8, 2017 8:40 PM
No need to do any tests since we can see it's a tutorvision mainboard and the tutorvision exec. So it's a tutorvision. Even if the extra gram were disabled it would be simple enough to enable it. It would be nice to see it play a tutorvision game.
https://docs.google....#h.htb2mb9zmtq7
According to this page two other Super Pro Systems have been found with tutorvision boards. Serial A-031118 is complete, and serial A-8644 is missing the tutorvision exec. Inellivision Productions has an INTV System III tutorvision. Intvnut has a loose tutorvision board and exec but is missing the square stic chip. Are there others?
Edited by mr_me, Sun Oct 8, 2017 9:16 PM.
#123 stupus OFFLINE
stupus
  • 2,125 posts
Posted Sun Oct 8, 2017 9:12 PM
I thought Joe had 1 that was a tutor vision. Mabe his is just the partial 1 though. And a random guy at mgc had 1 we figured out, but I don't think anyone checked if it had all the components of the tutorvision.
Joe could probably remember better than me.
I know the random guy was mad because he thought his was broken when worm whimper was glitched.....then very happy when Joe said it meant he had a tutorvision :)
Maybe that's the other documented one?
And hatman, I think you are obligated to get an lto now and throw the tutorvision roms on there and play them ;)
Very lucky guy you are!
#124 mr_me OFFLINE
mr_me
  • 3,825 posts
Posted Sun Oct 8, 2017 9:19 PM
Or he could put it up on ebay and see what it fetches.
#125 stupus OFFLINE
stupus
  • 2,125 posts
Posted Sun Oct 8, 2017 10:24 PM
Right, or he can sell it to me ;)
I would be fine with that too!
