Ishiru Posted September 25, 2017 Share Posted September 25, 2017 Hello, i recently bought a TRS-80 CoCo model 1 (the gray one) with some cartridges for a very good price, but I've no image on screen and when I do an analogic channel searching my TV can't find anything so I guess it doesn't get any signal from the TRS-80.The TRS-80's power supply does a sound when it's connected to the power (even when the power button it not on "ON"). When it's on "ON" the sound is still there but become different, I don't know if it's something normal or not. I checked the motherboard and power supply and everything seems to be OK at first sight, any melted capacitors or anything.Also something that seems weird is the hook up cable. I don't know if it's normal but the part that hook up in the TRS-80 output don't fit very well and move easily. Here is the part i'm talking about : https://drive.google.com/file/d/0B3qrqUNdYbREbUJCSnhyNE8xMUk/view?usp=sharingI also don't get why the core here is in plastic ... And here is the part i hook up to the antenna input of my TV : https://drive.google.com/file/d/0B3qrqUNdYbRER09yUERmV1JHeEU/view?usp=sharingThis cable doesn't seems to be the same as the Atari, Sega, etc ... one. The one i use for my Atari doesn't fit in the TRS-80 output.Also, i saw on the internet something about a "channel select 4-3" switch on the back of the TRS-80 Color, but i don't have that on my unit. I just have a stickers with "Channel 36" wrote on it and a kind of potentiometer under it. Does someone have a clue about how to fix it Thanks . Quote Link to comment Share on other sites More sharing options...
MarkO Posted September 25, 2017 Share Posted September 25, 2017 Your First Picture, that cable will only provide the Outside Shield... With no Center Conductor, it won't work at all... You need a Cable with plugs more like the Second Picture... MarkO Quote Link to comment Share on other sites More sharing options...
Ishiru Posted September 25, 2017 Author Share Posted September 25, 2017 (edited) Yes i was thinking the same but it's the cable i received with the TRS-80, how is it possible a coaxial cable like that does exist without copper core ? Is it the wrong cable the guy sold me with ? Also, a standard coaxial like the one i use for the Atari 130 XE, Sega, and cie doesn't work cause their core is too big to fit in the TRS-80 output, are there different diameter or something ? Which one should I buy ? Edited September 25, 2017 by Ishiru Quote Link to comment Share on other sites More sharing options...
Ishiru Posted September 27, 2017 Author Share Posted September 27, 2017 (edited) Hello, I tried with another coaxial cable that didn't fit perfectly in the TRS-80 Color output too (it moved easily), connected to on old rf antenna switch and this time my TV detected 2 channels but I had "snow" on both of them. + My tv started to blink like crazy when i was on these channels, i don't know why ... I had a signal even if the computer was on "OFF". Also, i connected a coaxial cable with F connector to the TRS-80, it seems that the original one had an RCA connector, could it be the reason why it didn't work or is it the same ? I got a little electric shoke when I touched the shied of this F connector while unpluging it. Can someone tell me which kind of Coaxial I have to use with this computer ? Is it a way to test the video output of the TRS-80 Color with a multimeter or something without breaking anything ? Edited September 27, 2017 by Ishiru Quote Link to comment Share on other sites More sharing options...
