Retrofixes CV Mod
9 replies to this topic
#1 polyex ONLINE
polyex
    Chopper Commander
  • 124 posts
Posted Tue Sep 26, 2017 9:51 AM
Installed the Retrofixes Colecovision Mod and I am getting distortion on the top of the screen. The problem is only with certain games like Bump N Jump, and Arctic Adventure among others. I have ordered some new cables hoping that will clear it up. Anyone else had this problem?
IMG 20170925 135653
index
#2 towmater OFFLINE
towmater
    Moonsweeper
  • 485 posts
Posted Tue Sep 26, 2017 8:29 PM
Probably a corny suggestion, but have you tried a longer RCA cable to see if attenuating the signal slightly effects the tearing?
#3 polyex ONLINE
polyex
    Chopper Commander
  • 124 posts
Posted Wed Sep 27, 2017 8:17 AM
Yes, I tried a couple cables I had laying around with lengths of between 6 and 15 feet.
#4 Swami ONLINE
Swami
  • 1,188 posts
Posted Wed Sep 27, 2017 1:13 PM
Did you try a different TV? I have seen some AV mods do weird things to CRT screens. I had an RCA CRT that played my ColecoVision AV mod fine but got scrambled signal (but good sound) with my Atari 2600 junior AV mod. On my other CRTs: pasasonic 29" and sharp 27", the CV AV mod also played fine but Atari Junior mod had this blocky black border around it, but had otherwise good signal and sound. Both were fine on the Vizio 32" LCD.
#5 imstarryeyed OFFLINE
imstarryeyed
    Moonsweeper
  • 353 posts
Posted Wed Sep 27, 2017 3:27 PM
That picture looks like a classic SYNC issue.  Screens on my arcade games look that way when the sync wires are not connected correctly. I am not sure how this little board works but if it uses sync then I would imagine that it uses either CSYNC which is composite sync or just composite signal with SYNC.
I can only guess but I think it looks like this version needs CSYNC which can be stripped out of the Composite signal.  Many many arcade games and consoles games need CSYNC but some can live with Composite, others need just Composite sync without the composite signal.
If you are tech enough you can get a Sync stripper chip and wire it up and strip out the composite.  This of course is just a suggestion based on a screenshot.  If I get some more time I will look up that board you bought and how it works and see if I can make heads or tails of it.
Hope this gives you at least a lead to lookup some stuff..
#6 Bmack36 OFFLINE
Bmack36
    Moonsweeper
  • 321 posts
Posted Wed Sep 27, 2017 6:18 PM
What points did you use to connect your wires to?
Edited by Bmack36, Wed Sep 27, 2017 6:18 PM.
#7 polyex ONLINE
polyex
    Chopper Commander
  • 124 posts
Posted Tue Oct 3, 2017 3:13 PM
It was 12volt , video and ground from the rf "board"
#8 polyex ONLINE
polyex
    Chopper Commander
  • 124 posts
Posted Tue Oct 3, 2017 3:14 PM
I picked up another CRT ($5, can't have too many), and it looks ok on that TV.
#9 Swami ONLINE
Swami
  • 1,188 posts
Posted Tue Oct 3, 2017 5:12 PM
Just curious. Was the second crt smaller than the first one that you had the problems with? Heard dubious theories it may have to do with higher resolution in larger TVs and the AV mod transmits a fixed resolution or the TV has some kind of processing at the edges to give crisper edges and it warps the picture.
#10 polyex ONLINE
polyex
    Chopper Commander
  • 124 posts
Posted Wed Oct 4, 2017 3:36 AM
No, the larger screen (both Emerson) worked.
