Armageddon repair and glue removal
1 reply to this topic
#1 128Kgames OFFLINE
128Kgames
  • 1,039 posts
  • Victory is mine! I am the Worrior!
Posted Sun Oct 1, 2017 3:02 PM
So this ones a two parter: finally got around to putting my Armageddon cart back together (thanks Toby!) but can't remember which side is "up" when putting the board back in, anyone have any pics or know which way is which?
Also, I need to remove the glue residue from the old cart label, whats the best way to remove it?  Alcohol?  Goo Gone?  Soap & water?
#2 rodge2001 OFFLINE
rodge2001
    Chopper Commander
  • 100 posts
Posted Fri Oct 6, 2017 1:22 AM
I think board should have side with eprom chips facing towards front of console if Im not mistaken. You can check which way is correct by inserting board by itself & if it works then it must be facing the right way.
I myself use alcohol pads & my fingernails to remove sticker residue on carts. Goo Gone can be pretty strong & sometimes leaves a permanent grayish white film on some plastic surfaces.
