Detecting Joystick button press with CALL KEY(0,A,B)
LASooner
Is there a way to detect a Joystick button press using CALL KEY 0? I'm using the whole keyboard for other aspects of the game, and there seems to be a noticeable performance drop when I use two CALL KEY commands just to detect JOY 1's button being pressed.
Edited by LASooner
RXB has a command CALL IO that scans the keyboard CRU bits and can detect on a REAL TI99/4A up to 4 keys pressed at same time and report different values for each of two variables.
You get two values and by interpreting each value you get to see all the keys being pressed.
CALL KEY in RXB is much more advanced than Basic or XB:
CALL ONKEY in RXB that has an IF X THEN ON GOTO line-number,line-number,line-number.............so on
Now this RXB demo only really works on a REAL TI99/4A as Emulator do not duplicate the CRU on keyboards accurately.
Also this RXB Demo only detects keys FCTN, CTRL, SHIFT, ENTER and Space Bar though it could have been set up to detect more keys I simplified it.
100 DISPLAY AT(1,1)ERASE ALL:"THIS PROGRAM CHECKS FOR     UNUSUAL KEYS BEING PRESSED, EVEN IF MORE THEN FOUR KEYS ARE BEING PRESSED AT ONCE"
110 CALL IO(2,16,3,A,B) :: IF A=18 AND B=255 THEN 110 ELSE CALL HPUT(24,3,RPT$(" ",30),24,24,STR$(A)&" "&STR$(B))
120 IF A=146 THEN CALL HPUT(24,3,"FUNCTION KEY")ELSE IF B=191 THEN CALL HPUT(24,3,"CONTROL KEY")ELSE IF B=223 THEN CALL HPUT(24,3,"SHIFT KEY")
130 IF B=251 THEN CALL HPUT(24,3,"ENTER KEY")ELSE IF B=253 THEN CALL HPUT(24,3,"SPACE BAR")ELSE IF B=254 THEN CALL HPUT(24,3,"PLUS/EQUAL KEY")
140 GOTO 110
Without the direct access available in RXB, no. Modes 3,4, and 5 scan the main keyboard but omit the joystick port (and 0 defaults to 5). Only modes 1 and 2 scan the joystick port (as well as half the keyboard).
That has more to do with how PC keyboards work than emulators. ;)
Well, it does work on MAME in the sense that multiple keys can be detected (until, as Tursi implied, the keyboard rollover (https://en.wikipedia.org/wiki/Rollover_(key) ) is exceeded). When I press Ctrl + Enter + Plus, I get a 186 from CALL IO in B (binary 10111010, i.e. three 0 indicating three pressed keys).
However, I am a bit puzzled about the IO output. I suppose it reads up to 16 bits into the two variables, starting with the LSB of the second variable. But why does FCTN change variable A? The FCTN line is CRU bit 7, so it should affect the 5th bit from the right, hence in B.
BTW, here is RXB 2015 as an RPK.
rxb_2015.rpk
Edited by mizapf
Part of the issue I assume is two variables are 16 bits and CRU is only 12 bits, I do not right justify the bits so unfilled bits may be in the wrong locations in RXB CALL IO
Still, what I don't understand is why in RXB in MAME the FCTN key appears somewhere else. For that reason, your program from above does not detect FCTN, and the polling loop is exited every time (because A != 18). The following assembly language program delivers the reaction at the proper place.
*  TOOL FOR READING THE 9901 LINES
*  MICHAEL ZAPF
       DEF  RUN
       REF  VMBW,VWTR
TEXT   TEXT 'READING THE 9901 LINES'
RUN    CLR  R0
       BL   @SETADR
       LI   R2,960
       LI   R1,>2000
CLEAR  MOVB R1,@>8C00
       DEC  R2
       JNE  CLEAR
       LI   R0,>01F0
       BLWP @VWTR
       LI   R0,>07B1
       BLWP @VWTR
       LI   R0,>0078
       LI   R1,TEXT
       LI   R2,22
       BLWP @VMBW
       LI   R4,>0020
       LI   R12,>0024
       CLR  R5
       LDCR R5,3
       CLR  R12
START  LI   R0,>01E0
       BL   @SETADR
BACK   STCR R1,0
       LI   R2,16
LOOP1  SRL  R1,1
       JOC  ITS1
       LI   R3,>3000
       JMP  PRDIG
ITS1   LI   R3,>3100
PRDIG  MOVB R3,@>8C00
       DEC  R2
       JNE  LOOP1
       XOR  R4,R12
       JEQ  START
       LIMI 2
       LIMI 0
       JMP  BACK
SETADR ORI  R0,>4000
       SWPB R0
       MOVB R0,@>8C02
       SWPB R0
       MOVB R0,@>8C02
       RT
       END  RUN
*  MICHAEL ZAPF
       DEF  RUN
       REF  VMBW,VWTR
RUN    CLR  R0
       BL   @SETADR
       LI   R2,960
       LI   R1,>2000
       DEC  R2
       JNE  CLEAR
       LI   R0,>01F0
       BLWP @VWTR
       LI   R0,>07B1
       BLWP @VWTR
       LI   R0,>0078
       LI   R1,TEXT
       LI   R2,22
       BLWP @VMBW
       LI   R4,>0020
       LI   R12,>0024
       CLR  R5
       LDCR R5,3
       CLR  R12
START  LI   R0,>01E0
       BL   @SETADR
BACK   STCR R1,0
       LI   R2,16
LOOP1  SRL  R1,1
       JOC  ITS1
       LI   R3,>3000
       JMP  PRDIG
ITS1   LI   R3,>3100
       DEC  R2
       JNE  LOOP1
       XOR  R4,R12
       JEQ  START
       LIMI 2
       LIMI 0
       JMP  BACK
SETADR ORI  R0,>4000
       SWPB R0
       MOVB R0,@>8C02
       SWPB R0
       MOVB R0,@>8C02
       RT
       END  RUN
On real iron the CALL IO works fine and even detects both CTRL, FCTN and SHIFT keys on different CRU addresses.
After all you can pick which key line per CRU to scan.
My original CRU KEY SCAN using CALL IO in RXB 2001 I demoed at the Chicago Faire could detect which FCTN/SHIFT/CTRL key you pressed left or right side of SPACE BAR.
Of course this DEMO was huge as it had to do more then 5 different CRU scans and a ton of IF A=value THEN show key.
Do you think the CALL IO values are wrong?
Edited by RXB
I'm not sure what's wrong. In fact, if I do a CALL IO(2,16,3,A,B) in RXB 2015 (on MAME), I get A=86 and B=255 when no key is pressed, and this differs from 18 and 255 as you seem to expect in your program.
18 = (00010010)
86 = (01010110)
I have two extra ones, and I'd like to find out where they come from.
FCTN is A=146 in your program, and here I get A=214.
146 = (10010010)
214 = (11010110)
The same here: My result differs by the byte 0x44 = (01000100)
Can you say what CRU bits correspond to these ones?
18 = (00010010)
86 = (01010110)
146 = (10010010)
214 = (11010110)
Yea in Classic99 using CALL IO(2,16,3,A,B) I get
A=95 and B=255 from just edit mode or program mode?
When I wrote the programs to check keys I just did a test program of
100 CALL IO(2,16,3,A,B)
110 PRINT A,B
120 CALL KEY("",0,K,S)
130 GOTO 100
What is get is most keys are A=95 and B=255
FCTN 3 - A=223 B=255
FCTN 5 - A=223 B=255
FCTN 6 - A=223 B=255
` - A=223 B=255
~ - A=223 B=255
- - A=92 B=254
_ - A=223 B-251
= - A=95 B=254
+ - A=95 B=222
DEL - A=223 B=255
TAB - A=223 B=247
[ - A=223 B=191
{ - A=223 B=223
] - A=223 B=255
} - A=223 B=255
\ - A=223 B=255
| - A=223 B=255
; - A=223 B=255
" - A=223 B=255
ENTER- A=95 B=251
SPACE- A=95 B=253
ARROWS all A=223 B=255
I never considered the values they are supposed to show, guess I should look into why these are returned?
Could you show me the source code of the IO subprogram?
RXB GPL Source:
RXBIO  CALL SPNUM1       * IO
IOAGN  CALL GETNUM       * TYPE 0-6
       CHE  >07,@FAC1
       BS   ERRBV
       ST   @FAC1,@VARY
       CALL SUBLP3       * ADDRESS/
       CASE @VARY        * BITS/BYTES
       BR   SOG
       BR   SOV
       BR   CRUI
       BR   CRUO
       BR   CSW
       BR   CSR
       BR   CSV
SOG    I/O  0,@FAC
       BR   IODONE
SOV    I/O  1,@FAC
       BR   IODONE
CRUI   CALL CRUSET
       I/O  2,@VAR4
       XML  PGMCHR
       CALL SNDER
       CALL CLRFAC
       ST   @VAR0,@FAC1
       CALL CIFSND       * VARIABLE1
       CHE  >09,@VARY
       BS   CRUI16
       BR   IODONE
CRUI16 XML  PGMCHR
       CALL SNDER
       CALL CLRFAC
       ST   @VAR1,@FAC1
       CALL CIFSND       * VARIABLE2
       BR   IODONE
CRUO   CALL CRUSET
       CALL SUBLP3       * VARIABLE1
       DCHE >0100,@FAC
       BS   ERRBV
       CHE  >09,@VARY
       BS   CRUO16
       ST   @FAC1,@VAR0
       BR   CRUO8
CRUO16 DST  @FAC,@VAR0
       CALL SUBLP3       * VARIABLE2
       DCHE >0100,@FAC
       BS   ERRBV
       ST   @FAC1,@VAR1
CRUO8  I/O  3,@VAR4
       BR   IODONE
CSW    CALL CSLOAD
       I/O  4,@VAR4
       BR   IODONE
CSR    CALL CSLOAD
       I/O  5,@VAR4
       BR   IODONE
CSV    CALL CSLOAD
       I/O  6,@VAR4
IODONE CEQ  >B3,@CHAT
       BS   IOAGN
       BR   LNKRTN
CRUTMP DST  @FAC,@VAR4
       DCLR @VAR5
       DCLR @VAR0
       RTN
CRUSET CZ   @FAC1
       BS   ERRBV
       CHE  >11,@FAC
       BS   ERRBV
       ST   @FAC1,@VARY
       CALL SUBLP3       * CRU-ADDRESS
       CALL CRUTMP
       ST   @VARY,@VAR5
       RTN
CSLOAD CALL CRUTMP
       DST  @FAC,@VAR5
       RTN
* SPNUM1 ROUTINE             *
SPNUM1 CEQ  LPARZ,@CHAT       Should be "("
       BR   ERRSYN
       RTN
STRFCH XML  PGMCHR
       XML  PARSE
       BYTE RPARZ
       RTN
STRGET CALL STRFCH
       CEQ  >65,@FAC2
       BR   ERRSNM      * STRING NUM MISMATCH
       RTN
NUMFCH CALL STRFCH
       CEQ  >65,@FAC2
       BS   ERRSNM      * STRING NUM MISMATCH
       RTN
CFIFCH XML  CFI
       CEQ  >03,@FAC+10
       BS   ERRBV       * NUMERIC OVERFLOW
       RTN
GETNUM CALL SUBLP3
       CEQ  >B3,@CHAT
       BR   ERRSYN
       RTN
ROWCOL CALL GETNUM
       DCGT 24,@FAC
       BS   ERRBV
       DDEC @FAC
       ST   @XPT,@MNUM
       ST   @FAC1,@YPT
       CALL GETNUM
       DCGT 32,@FAC
       BS   ERRBV
       DDEC @FAC
       ST   @FAC1,@XPT
       RTN
NGOOD  XML  PGMCHR
NGOOD1 CHE  >80,@CHAT
       BS   ERRSYN         * ?
       CALL SNDER
       CEQ  >65,@FAC2
       BR   ERRSNM         * STRING NUMBER MISMATCH
       DST  >001C,@FAC
       DST  @SREF,@FAC4
       DST  @BYTES,@FAC6
       BR   SNDASS
SNDER  XML  SYM
       XML  SMB
       XML  VPUSH
       RTN
CIFSND XML  CIF
SNDASS XML  ASSGNV
       RTN
GETLP  ST   @CB,@VAR0
       ST   @CB,@VAR1
       SUB  OFFSET,@VAR1
       ST   @VAR1,V@0(@STRPTR)
       DINC @STRPTR
       RTN
PUTLP  ST   V@0(@FAC4),@VAR0
       ADD  OFFSET,@VAR0
       DINC @FAC4
       RTN
HFMT   FMT
       DATA >E000
       FEND
       RTN
VFMT   FMT
       DATA >E000
       BYTE >9E
       FEND
       RTN
SUBLP3 CALL NUMFCH
       CALL CFIFCH
       RTN
CLRFAC CLR  @FAC
       MOVE 7,@FAC,@FAC1
       RTN
Here is an updated version of my 9901 query tool. You can see the effects of different key presses. (Note that in MAME, this will only work with the "emulated keyboard", not with the "natural keyboard", which is a known limitation of the natural keyboard.)
I can't make sense of the IO subprogram output, but I cannot tell where the problem is. The FCTN key should be found at CRU bit 7 in mode 0 (8th digit from the left in the upper (long) row). Try to transfer the attached source code to your real computer. Accordingly, this line should be queried with a CALL IO(2,1,7,A), but this does not work. On the other hand, a CALL IO(2,1,8,A) correctly detects the Shift key.
I checked your IO source code, but I could not find any (obvious) error. Unfortunately, it is virtually impossible to debug GPL with MAME (because it cannot know that there is a virtual machine inside the TI).
*  MICHAEL ZAPF
       DEF  RUN
LABEL  TEXT 'MODE='
RUN    CLR  R0
       BL   @SETADR
       LI   R2,960
       LI   R1,>2000
       DEC  R2
       JNE  CLEAR
       LI   R0,>01F0
       BL   @SETREG
       LI   R0,>07B1
       BL   @SETREG
       LI   R0,>0078
       LI   R1,TEXT
       LI   R2,22
       BL   @SETADR
TL0    MOVB *R1+,@>8C00
       DEC  R2
       JNE  TL0
       LI   R0,>0168
       LI   R1,LABEL
       LI   R2,5
       BL   @SETADR
TL1    MOVB *R1+,@>8C00
       DEC  R2
       JNE  TL1
       LI   R3,>3000
       LI   R4,>016D
TL2    MOV  R4,R0
       BL   @SETADR
       MOVB R3,@>8C00
       AI   R4,40
       AI   R3,>0100
       CI   R3,>3800
       JNE  TL2
       CLR  R4
LOOP1  LI   R12,>0024
       LDCR R4,3
       MOV  R4,R4
       JNE  KEYB
       LI   R0,>0170     FIRST LINE
       BL   @SETADR
       BL   @SHOWCR
       DATA >0000,16
       BL   @SHOWCR
       DATA >0020,16
       LI   R5,>0173
       JMP  LOOP2
KEYB   BL   @SHOWCR
       DATA >0006,8
LOOP2  AI   R5,40
       MOV  R5,R0
       BL   @SETADR
       AI   R4,>0100
       ANDI R4,>0700
       LIMI 2
       LIMI 0
       JMP  LOOP1
* SHOWCR: SHOW CRU BITS ACCORDING TO DATA
H30    BYTE >30
H31    BYTE >31
SHOWCR MOV  *R11+,R12
       MOV  *R11+,R1
       MOV  R11,R10
       STCR R2,0
       CI   R1,8
       JHE  SHOWLP
       SRL  R2,8
SHOWLP SRL  R2,1
       JNC  ITS0
       MOVB @H31,@>8C00
       JMP  ITS1
ITS0   MOVB @H30,@>8C00
ITS1   DEC  R1
       JNE  SHOWLP
       MOV  R10,R11
       RT
SETADR ORI  R0,>4000
       JMP  S1
SETREG ORI  R0,>8000
S1     SWPB R0
       MOVB R0,@>8C02
       SWPB R0
       MOVB R0,@>8C02
       RT
       END  RUN
