Atari 2600 Wireless Controllers Reciever Antenna Help
4 replies to this topic
#1 Jeremy Popp OFFLINE
Jeremy Popp
    Moonsweeper
  • 338 posts
Posted Thu Oct 12, 2017 8:58 AM
I'm looking for a little help as I've recently come across a set of Atari Wireless controllers with the receiver.  Everything works, however my antenna has been broken in half at some point, and I'm missing the top half.  I'm hoping someone can do me a favor and measure the length of an original antenna as collapsed AND extended fully as this will help me find a replacement.  Thanks in advance!
#2 nick3092 OFFLINE
nick3092
    Space Invader
  • 44 posts
Posted Fri Oct 13, 2017 8:04 AM
If someone doesnt beat me to it, Ill try and remember to measre mine when I get home from work tonight.
#3 nick3092 OFFLINE
nick3092
    Space Invader
  • 44 posts
Posted Fri Oct 13, 2017 3:53 PM
Its about 4.25 inch collapsed and 18 inch extended. Thats from the tip to the bottom of elbow when bent at 90 degrees. Like in your picture.
Edited by nick3092, Fri Oct 13, 2017 4:00 PM.
#4 Jeremy Popp OFFLINE
Jeremy Popp
    Moonsweeper
  • 338 posts
Posted Mon Oct 16, 2017 7:10 AM
Perfect, thank you so much. Now the hunt is on to find a suitable replacement.  I'll be sure to post if/where/when I find one for future reference.
#5 Jeremy Popp OFFLINE
Jeremy Popp
    Moonsweeper
  • 338 posts
Posted Tue Oct 31, 2017 8:18 AM
https://www.amazon.c...?tag=60002a1-20
I found a really close replacement here.  For future reference, if the link doesn't work, here are the details:
7 Section Telescopic Aerial Antenna FM RADIO ANTENNA
Manufacturer: TS
ASIN: B073FNS7R6
Section :7 sections
First Section Diameter:7mm
Extended length:450MM
Hight quality Material: Brass
Fit for Radio ,DAB
Collapse length: 97mm
The tip is not exactly the same, but the sizing for everything is amazingly close.  I had to keep the base because it has a connector that I've never seen before.  However, taking out the one Phillips screw at the hinge and replacing with this one was easy.  I did add an extra washer because the new one is slightly thinner where it connects.  Once collapsed, it will even snap into it's resting clip and looks original.
Thanks again for your help nick3092
