Level42 Posted November 13, 2017 Share Posted November 13, 2017 I am interested in: 1 blue bareboard with complete BOM EXCEPT Daughterboards and Atari chips. Depending much on shipping costs to Europe. Apart from U1MB, which daughter boards will I be missing ? Quote Link to comment Share on other sites More sharing options...
+mytek Posted November 13, 2017 Share Posted November 13, 2017 I am interested in: 1 blue bareboard with complete BOM EXCEPT Daughterboards and Atari chips. Depending much on shipping costs to Europe. Apart from U1MB, which daughter boards will I be missing ? UAV and SparkFun BOB-12731 FTDI SIO2PC-USB - Michael 1 Quote Link to comment Share on other sites More sharing options...
Level42 Posted November 14, 2017 Share Posted November 14, 2017 So that's three things right Michael ? - UAV....I guess only needed if not hooking up through any of the modern video outputs ? - SIO2PC-USB, I have Lotharek's SIO connector to USB....i guess this should work on the 1088 just as well ? - not sure what the Sparkfun USB to serial is needed for ? So....if I'm not mistaking non of these are essential for the 1088XEL to run/be of use ? Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted November 14, 2017 Share Posted November 14, 2017 So that's three things right Michael ? - UAV....I guess only needed if not hooking up through any of the modern video outputs ? - SIO2PC-USB, I have Lotharek's SIO connector to USB....i guess this should work on the 1088 just as well ? - not sure what the Sparkfun USB to serial is needed for ? So....if I'm not mistaking non of these are essential for the 1088XEL to run/be of use ? Um, what modern video outputs? The Sparkfun board *is* the SIO2PC-USB interface. 3 Quote Link to comment Share on other sites More sharing options...
+mytek Posted November 14, 2017 Share Posted November 14, 2017 So that's three things right Michael ? - UAV....I guess only needed if not hooking up through any of the modern video outputs ? - SIO2PC-USB, I have Lotharek's SIO connector to USB....i guess this should work on the 1088 just as well ? - not sure what the Sparkfun USB to serial is needed for ? So....if I'm not mistaking non of these are essential for the 1088XEL to run/be of use ? The UAV is the 'standard' video output for the XEL. So unless you plan to have a Sophia or VBXE, you'll be needing this board. The SIO2PC-USB is optional, and yes the Lotharek board could be used instead, but you do loose the SIO Jack (could always plug it in after another device like a 1050 or XF551). - Michael 1 Quote Link to comment Share on other sites More sharing options...
Level42 Posted November 14, 2017 Share Posted November 14, 2017 (edited) The Sparkfun board *is* the SIO2PC-USB interface. Well I googled "SparkFun BOB-12731 FTDI" since I wasn't sure if Michael meant two separate things....and it hit me up with thishttps://www.sparkfun.com/products/12731 So I got confused. Sorry but I did not read/follow each single step in the 1088 process... Anyway all,is clear now.....I don't use SiO2PC-USB all the time with my real machines anyway so I'll be fine without it and the Lotharek plug will do for me. I'm a fan of The!cart and probably will use that the most. Has it been tested with 1088XEL already ? Ordering Lotharek U1MB directly from him is probably cheaper since I'm in Europe and i already have all the VLSI chips at hand so going with the "no daughterboards" option is my best choice also because I don't need the extra SIO2PC-USB. So the leaves only the UAV to order extra.....or SOPHiA....tough decision....I like RGB because I'm a fan of using CRT's. Edited November 14, 2017 by Level42 1 Quote Link to comment Share on other sites More sharing options...
+MacRorie Posted November 15, 2017 Author Share Posted November 15, 2017 (edited) Update posted in #1 Updated again. Edited November 15, 2017 by MacRorie Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted November 15, 2017 Share Posted November 15, 2017 UPDATE (15NOV17): Realan H80 Cases have been ordered and are in hand. Will be finalizing prices and stuff by the end of the week. Interest list has been updated. All paid baseboards have been shipped. ALL BLUE BOARDS have been spoken for. All Future requests will be with GREEN boards. NOW is the time to make sure you have the color you want. Check the list, if there needs to be a change, I need to know pretty soon! Hi MacRorie - I don’t see you have me down for a BOM +Daughterboards combo. Thanks! Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted November 15, 2017 Share Posted November 15, 2017 Ditto... Quote Link to comment Share on other sites More sharing options...
Level42 Posted November 15, 2017 Share Posted November 15, 2017 Uh....so the blue boards were all gone before my request ? Not a deal breaker just making sure you noticed my request... By the way.....you are crazy ( in the right way)for taking this on....what an insane amount of work, space and patience......THANKS !!!! Quote Link to comment Share on other sites More sharing options...
Zarxx Posted November 15, 2017 Share Posted November 15, 2017 Hi MacRorie, 1x fully assembled one with case for me please. Thanks. Quote Link to comment Share on other sites More sharing options...
+Spaced Cowboy Posted November 15, 2017 Share Posted November 15, 2017 Update posted in #1 Updated again. Hi MacRorie, Can you put me down for everything *except* the case please. I fancy making my own case Quote Link to comment Share on other sites More sharing options...
AtariNerd Posted November 15, 2017 Share Posted November 15, 2017 Uh....so the blue boards were all gone before my request ? Not a deal breaker just making sure you noticed my request... By the way.....you are crazy ( in the right way)for taking this on....what an insane amount of work, space and patience......THANKS !!!! I'll swap my blue for your green, if you want. I'm not too particular, either way. 1 Quote Link to comment Share on other sites More sharing options...
Level42 Posted November 15, 2017 Share Posted November 15, 2017 (edited) That is AWESOME THANKS !!! I'm looking into building it into a plexi/perspex case.... Maybe this one https://www.ebay.com/itm/Acrylic-Clear-Mini-ITX-HTPC-Case-with-dc-atx-160W-power-supply-I0AA-M2-P-US/222720137185?hash=item33db2797e1:g:2ioAAOSwImRYkGw6or maybe I'll make that a DIY project...I don't really like the fan holes on the right side of that one... Edited November 15, 2017 by Level42 2 Quote Link to comment Share on other sites More sharing options...
AtariNerd Posted November 16, 2017 Share Posted November 16, 2017 If I just stick with the Realan case (I've already purchased one) and not go for something else for the moment (haven't decided if I'll get the printed one offered here, yet), a couple of small things I'll probably do, is get some decorative thumb-screws (large-headed, finger-turn-able), for the top, so I can get into it easily. Also thinking of getting another, possibly clear, top, or perhaps tweaking Michael's design a little, so it's in multiple layers (might be pushing it at this thickness), having a view window in the middle and an outline, in metal, around the edge and around certain elements. And some nice little feet for the case, as well. 1 Quote Link to comment Share on other sites More sharing options...
jfultz Posted November 16, 2017 Share Posted November 16, 2017 Hi, MacRorie. You are awesome for putting this together for the community. Thanks so much. I'm interested in a bare board (any color) + complete BOM kit. Quote Link to comment Share on other sites More sharing options...
Sugarland Posted November 16, 2017 Share Posted November 16, 2017 (edited) MacRorie have you considered sending a board + complete BOM-UNASSEMBLED to 'The 8-bit guy' he asked for boards to feature on his very popular channel at the end of this video Maybe not right away but once you are ready you could get some great exposure. In that video he built a PE6502 Hobby Computer but that computer is weak as he explained. Edited November 16, 2017 by Sugarland 1 Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted November 16, 2017 Share Posted November 16, 2017 MacRorie have you considered sending a board + complete BOM-UNASSEMBLED to 'The 8-bit guy' he asked for boards to feature on his very popular channel at the end of this video Why would MacRorie send $300+ worth of rare Atari-specific stuff to a complete stranger so the stranger can make money off a video showing it? I like YouTube videos as much as the next guy but the phenomenon of people sending these guys thousands of dollars of stuff per month for free boggles my mind. 2 Quote Link to comment Share on other sites More sharing options...
Sugarland Posted November 16, 2017 Share Posted November 16, 2017 (edited) Why would MacRorie send $300+ worth of rare Atari-specific stuff to a complete stranger so the stranger can make money off a video showing it? I like YouTube videos as much as the next guy but the phenomenon of people sending these guys thousands of dollars of stuff per month for free boggles my mind. Well excuuuuuuuuse me! Edited November 16, 2017 by Sugarland Quote Link to comment Share on other sites More sharing options...
Brentarian Posted November 16, 2017 Share Posted November 16, 2017 Why would MacRorie send $300+ worth of rare Atari-specific stuff to a complete stranger so the stranger can make money off a video showing it? I like YouTube videos as much as the next guy but the phenomenon of people sending these guys thousands of dollars of stuff per month for free boggles my mind. If an 1088XEL made an appearance on 8bitGuy's web show it would definitely increase exposure and possibly bring a few more sales. I'd have to agree with Dr. Venkman though, as $300 is a lot of money. 8bitGuy did say the 1088XEL was a cool project on Facebook, so he is already aware of it. Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted November 16, 2017 Share Posted November 16, 2017 Well excuuuuuuuuse me! Cute. I got the email notification of your first reply. It was a lot more polite. 1 Quote Link to comment Share on other sites More sharing options...
+mytek Posted November 16, 2017 Share Posted November 16, 2017 Just my 2 cents... Based on the response I'm seeing here since this topic started, I doubt that MacRorie really needs any help at drumming up interest. Pretty soon he'll have to hire someone to keep up with all the orders. - Michael 7 Quote Link to comment Share on other sites More sharing options...
+MacRorie Posted November 16, 2017 Author Share Posted November 16, 2017 Uh....so the blue boards were all gone before my request ? Not a deal breaker just making sure you noticed my request... By the way.....you are crazy ( in the right way)for taking this on....what an insane amount of work, space and patience......THANKS !!!! Level42, not to worry. If Blue is absolutely essential, I reserved a few for overlap, just in case of a situation like this. If it is essential, please let me know. EVERYONE: As I have said, if you need a particular color, you HAVE to let me know. Eventually, even the reserved ones will disappear. Granted, it looks like another order will probably be made, but I am NOT doing that until I get all of this backlog solved. Thanksgiving is coming to the US soon and I *have* to get my dining table cleared. Today and tomorrow's job is to clear the dining table and put out a price list for the BOM & Assembled options. Saturday and sunday is producing more UNO and Ultimate carts, Monday & Tuesday is teaching undergraduates public speaking and Wednesday is preparing for Thanksgiving. Egads, what have I done?!?! 4 Quote Link to comment Share on other sites More sharing options...
+MacRorie Posted November 16, 2017 Author Share Posted November 16, 2017 MacRorie have you considered sending a board + complete BOM-UNASSEMBLED to 'The 8-bit guy' he asked for boards to feature on his very popular channel at the end of this video Maybe not right away but once you are ready you could get some great exposure. In that video he built a PE6502 Hobby Computer but that computer is weak as he explained. That is a cool video. I think the demand I have right now is pretty cool. However, when things cool down, that is certainly something to keep in mind! Thanks Quote Link to comment Share on other sites More sharing options...
+MacRorie Posted November 16, 2017 Author Share Posted November 16, 2017 If an 1088XEL made an appearance on 8bitGuy's web show it would definitely increase exposure and possibly bring a few more sales. I'd have to agree with Dr. Venkman though, as $300 is a lot of money. 8bitGuy did say the 1088XEL was a cool project on Facebook, so he is already aware of it. Certainly something to keep in mind . . . for later MUCH MUCH later! 2 Quote Link to comment Share on other sites More sharing options...
