johncena1973 Posted October 20, 2017 Share Posted October 20, 2017 Hi guys, i just snatched this controller from a flea market for $7. Not a bad deal, all buttons are still intact. But the problem is the pin's piece is missing. So i cannot connect the controller the console's port, is there any ways to fix this issue ? Thanks Quote Link to comment Share on other sites More sharing options...
Bratwurst Posted October 20, 2017 Share Posted October 20, 2017 You will have to cut the plug end off and wire in a new 8-pin DIN, or preferably, find a replacement cable with the plug already molded in and wire it into the controller. I've seen this happen a few times before with TG-16 controllers (I have about 6 of them at this point). For whatever reason the glue used to hold the pins and metal hood can give out from the push and pull required to insert/remove from the system's controller port, which has quite a grip. Quote Link to comment Share on other sites More sharing options...
johncena1973 Posted October 20, 2017 Author Share Posted October 20, 2017 You will have to cut the plug end off and wire in a new 8-pin DIN, or preferably, find a replacement cable with the plug already molded in and wire it into the controller. I've seen this happen a few times before with TG-16 controllers (I have about 6 of them at this point). For whatever reason the glue used to hold the pins and metal hood can give out from the push and pull required to insert/remove from the system's controller port, which has quite a grip. Thanks a lot. Btw, do you know what brand of replacement cable do i need to find ? Quote Link to comment Share on other sites More sharing options...
Bratwurst Posted October 20, 2017 Share Posted October 20, 2017 Thanks a lot. Btw, do you know what brand of replacement cable do i need to find ? You should be able to use any cable that ends in a large 8-pin din male plug, I found some listings for you: https://www.ebay.com/itm/253144321717 https://www.ebay.com/itm/232306300637 https://www.ebay.com/itm/371957128507<- that has a female on the other end so it'd just be one really long extension at 12 feet You'd want a 6 foot cord at the minimum, or a 12 foot you could cut in two, then splice into the appropriate wires. The controller pinout can be image searched through google. I think I have a controller I never got around to mending so if you need help doing yours just send me a PM. 2 Quote Link to comment Share on other sites More sharing options...
johncena1973 Posted October 22, 2017 Author Share Posted October 22, 2017 You should be able to use any cable that ends in a large 8-pin din male plug, I found some listings for you: https://www.ebay.com/itm/253144321717 https://www.ebay.com/itm/232306300637 https://www.ebay.com/itm/371957128507<- that has a female on the other end so it'd just be one really long extension at 12 feet You'd want a 6 foot cord at the minimum, or a 12 foot you could cut in two, then splice into the appropriate wires. The controller pinout can be image searched through google. I think I have a controller I never got around to mending so if you need help doing yours just send me a PM. Could you give me a keyword about replacing this 8-pin plug for game controller on YOUTUBE ? Quote Link to comment Share on other sites More sharing options...
Bratwurst Posted October 22, 2017 Share Posted October 22, 2017 I dunno. Swap or replace controller cord repair? Quote Link to comment Share on other sites More sharing options...
