How does one do horizontal scrolling
4 replies to this topic
#1 VGAGuy OFFLINE
VGAGuy
    Space Invader
  • 33 posts
  • Avid Bankswitcher
Posted Fri Oct 20, 2017 1:16 AM
I am sort of porting Irritating Stick to the 2600, but I can't figure out how to get scrolling to work.
I looked at Princess Rescue's code, but I can't figure out how it loads the level and then scrolls it.
I would like it to be as simple as possible, due to my low programming skill.
Also, any name ideas?
Thanks,
VGAGuy
#2 Gemintronic OFFLINE
Gemintronic
    Jason S. - Lead Developer & CEO
  • 8,877 posts
Posted Fri Oct 20, 2017 8:29 AM
Not an example but the source of my Great Giana Sisters homage is here:
http://atariage.com/...ed/?hl= santuci
Talks to get Black Forest Games blessing kinda stalled so it was a no go. But, I think it's one of the very few side scrolling batari basic engines out there.
#3 Lewis2907 OFFLINE
Lewis2907
    Chopper Commander
  • 189 posts
Posted Fri Oct 20, 2017 9:52 AM
Gemintronic,
I am trying to get the below to work so you scroll left and right. It will jerk left and that's about it. I understand some of the code, but no where near an expert. Also I tried to go up to 32kSC to have the banks and extra memory to work and it loaded, but failed to scroll etc. If I can get this to work it will open some doors up on games. Thanks again for any information you can provide.
print_screenright
if counter{0} then return
if player1x < 13 then gosub warp_object
player1x = player1x - 4
if !halfbit then halfbit = 1: goto start_print else halfbit = 0 : worldx = worldx + 1
if change = 32 then worldx = rand*16 : change = 0 else change = change + 1
start_print
column = screens[worldx]
if column{7} then pfpixel 0 7 on else pfpixel 0 7 off
if column{6} then pfpixel 0 6 on else pfpixel 0 6 off
if column{5} then pfpixel 0 5 on else pfpixel 0 5 off
if column{4} then pfpixel 0 4 on else pfpixel 0 4 off
if column{3} then pfpixel 0 3 on else pfpixel 0 3 off
if column{2} then pfpixel 0 2 on else pfpixel 0 2 off
if column{1} then pfpixel 0 1 on else pfpixel 0 1 off
if column{0} then pfpixel 0 0 on else pfpixel 0 0 off
tempvar = pfscroll(0, 8, 255, 0)
return
#4 hloberg OFFLINE
hloberg
    Dragonstomper
  • 691 posts
Posted Fri Oct 20, 2017 12:58 PM
what kernel are you using? it's easy in standard kernel, impossible in multi-sprite, hard but doable in DPC+
here is the code I use in DPC+
rem scroll section
  scrldly=scrldly+1: if scrldly<23 then goto _bp3 else scrldly=1: rem this slows down the scroll
  if pfread(0,20) then t1=1 else t1=0 : rem read 1st pixiel in rows 20 & 19 which are the only 2 rows I scroll
  if pfread(0,19) then t5=1 else t5=0
  for t2=1 to 32
     if pfread(t2 ,19) then t3=1 else t3=0 : rem loop check left to right and move the pixels
     t4=t2-1 : if t3=0 then pfpixel t4 19 off else pfpixel t4 19 on
    if pfread(t2 ,20) then t3=1 else t3=0
     t4=t2-1 : if t3=0 then pfpixel t4 20 off else pfpixel t4 20 on
  next
 if t5=0 then pfpixel 31 19 off else pfpixel 31 19 on : rem do last pixels on right
 if t1=0 then pfpixel 31 20 off else pfpixel 31 20 on
with the DLC+ kernel you read each pixel then redraw it to the left
_bp3
here is standard kernel
 scldly=scldly+1 : if scldly> 30 then pfscroll left : scldly=0 : rem ignore player1x = player1x - c : rem pfscroll does the trick. i scrolls the whole screen i
with standard kernel you do a pfscroll, much easier. I'm looping the playfield in bot examples.
multi-sprite can not be scrolled as it flip images on the playfield.left-right
hope that helps.
#5 Gemintronic OFFLINE
Gemintronic
  • 8,877 posts
Posted Fri Oct 20, 2017 3:17 PM
Gemintronic,
So far that engine scrolls like the original Super Mario Brothers so no backtracking to the left.
I was hesitant to provide a link to my 4-way scrolling engine out as it's more complicated. Also, it uses a TON of CPU time. But, if he's just scrolling in a new screen it might work.
http://atariage.com/...ata-want-4-way/
