Atari ST Video Issue
7 replies to this topic
#1 fsmith2003 OFFLINE
fsmith2003
    Space Invader
  • 16 posts
Posted Fri Oct 20, 2017 2:43 PM
Hello all!  I am having an issue with my video output of my STM.  A constant pale white line scrolls from top to bottom slowly and I cannot figure out why.  I was wondering if anyone in here might have an idea of how to fix this or what is causing it?  Video link below.  The diagonal line is my camera and not actually on the screen.  Thanks!
Edited by fsmith2003, Fri Oct 20, 2017 2:44 PM.
#2 Bikerbob OFFLINE
Bikerbob
    Dragonstomper
  • 630 posts
Posted Fri Oct 20, 2017 4:11 PM
What output are you using? because you say specifially M.. are you using the modulator?
James
#3 fsmith2003 OFFLINE
fsmith2003
    Space Invader
  • 16 posts
Posted Fri Oct 20, 2017 5:13 PM
Well I'm using a custom cable that takes the monitor out port and converts it to composite. I've tried that way and with the rf port as well. Same result.
#4 Bikerbob OFFLINE
Bikerbob
    Dragonstomper
  • 630 posts
Posted Fri Oct 20, 2017 7:45 PM
Do you have a different TV or monitor to try? It seems like it could be a V - hold issue, if it was the RF.. that could be a reason, but if you say its the same either way then maybe its a monitor issue.
James
#5 fsmith2003 OFFLINE
fsmith2003
    Space Invader
  • 16 posts
Posted Fri Oct 20, 2017 8:49 PM
I've tried a couple monitors/tv's and it is still present. Seen somewhere this could be due to a faulty power supply.  I have one ordered to try out and see if that's the cause.
#6 RodLightning OFFLINE
RodLightning
    Dragonstomper
  • 670 posts
Posted Fri Oct 20, 2017 9:28 PM
I have seen a similar effect on a CRT screen during a power outage when powered by my UPS backup unit.
#7 guus.assmann OFFLINE
guus.assmann
    Moonsweeper
  • 346 posts
Posted Sat Oct 21, 2017 5:59 AM
Hello fsmith2003,
Yes, it could be a power supply issue.
In that case, replacing some caps will do just very nice.
And it's no "high tech" soldering.
Look on the site of EXXOS to get some info or parts.
BR/
Guus
#8 fsmith2003 OFFLINE
fsmith2003
    Space Invader
  • 16 posts
Posted Tue Oct 24, 2017 3:01 PM
Problem was solved with a new power supply!  Must not of been getting enough voltage from the old one.  Everything works as normal now.  Thanks for the replies!
