Skunkboard stuck on erase?
8 replies to this topic
#1 Starcat OFFLINE
Starcat
  • 1,018 posts
Posted Sun Oct 22, 2017 4:51 AM
Hello folks,
it's been a while that I used my skunk v2 to upload roms to cart space. For some reason the erase screen (rainbow bars on the Jag) seems to go on forever.
On the PC end using jiffi, it doesn't get pase the erase part which is supposed to take about 9 secs.
I'm using windows 7 and I have a usb hub only for the skunk connected to a usb 2 port, so it should get enough power.
Any ideas what might be wrong or how to fix this?
Cheers
#2 Starcat OFFLINE
Starcat
  • 1,018 posts
Posted Wed Oct 25, 2017 10:41 PM
I'm in contact with Tursi. Seems to be a rare problem, possibly damaged as it didn't have the power mod yet.
#3 neo_rg OFFLINE
neo_rg
    Moonsweeper
  • 373 posts
Posted Thu Oct 26, 2017 3:43 AM
I have and old rev2 that just red screens when it boots up. It's not the contacts and there is no obvious chip damage. It was like that when I got it new.
#4 UHATEIT OFFLINE
UHATEIT
    Dragonstomper
  • 573 posts
Posted Thu Oct 26, 2017 4:22 PM
I have had rare instances in which regardless of booting and hitting reset, the Jag screen comes up and then turns red and stays even after hitting the reset a bunch. But once taking the cart out and reinserting it then it's fine.
Ad for your rainbow screen lasting forever, I have not seen that, but have seen the black screen with yellow flickering last for a long time!
I am having a problem with some of the roms working. Raiden is an example, no matter how many times I load it, after it is done, the screen just goes to blue. Any of you have that issue? Even after retrying and resetting and re inserting the cart no matter how many times I flash it I get the same result. I have had some that at the end of the flashing it turns blue then quickly pops over to the working Jaguar screens and the game starts, but Raiden and a few others I can't remember just seem to turn the screen blue and will never load. Could that be a rom specific issue?
#5 Matthias OFFLINE
Matthias
  • 1,171 posts
Posted Fri Oct 27, 2017 8:59 AM
Apparently Raiden doesn't switch on the video system when it is started, Atari knew about this and had to change the VLM start code to handle this problem. See Cart.S and CDBoot1.s in the VLM-sources.
Kind regards
Matthias
#6 UHATEIT OFFLINE
UHATEIT
    Dragonstomper
  • 573 posts
Posted Fri Oct 27, 2017 9:30 AM
Kind regards
Matthias
whoa sorry I am lost, what is it I need to look for? I have to use SkunkGUI as my command prompt screens just aren't pulling up with my laptop. Even after flashing the Raiden rom and then eventually unplugging the cart and reloading it again into the Jaguar it still won't start.
Edited by UHATEIT, Fri Oct 27, 2017 12:42 PM.
#7 CyranoJ ONLINE
CyranoJ
  • 5,544 posts
  • RAPTOR in LOCAL
Posted Fri Oct 27, 2017 4:43 PM
Here's one I prepared earlier.
Attached File  Raiden-SkunkFixed.rom   2MB   105 downloads
This has been a public service broadcast on behalf of the skunkboard party.
#8 UHATEIT OFFLINE
UHATEIT
    Dragonstomper
  • 573 posts
Posted Fri Oct 27, 2017 5:35 PM
attachicon.gifRaiden-SkunkFixed.rom
You are the man! Worked like a charm! I was surprised there are a couple that I noticed that were like that.
Also BTW props to you on all the ST games you ported over as well. I saw your name on the front screen of Solomon's Key. That one is addicting (and hard too!)
#9 rdemming OFFLINE
rdemming
  • 1,224 posts
Posted Sat Nov 11, 2017 2:06 PM
Thanks for the fixed "NTSC" version.
But you could have saved yourself the trouble  :P  because Atari had a second Raiden release (J9005E instead of J9005) that fixes the video issues and also displays "correctly" on PAL systems. The J9005 version displays the screen too much at the top because it does not take into account the extra screen lines of PAL video while J9005E version the screen is centered vertically or uses the extra PAL screen lines. The J9005E version is attached.
Below some screenshots with the J9005 version left and the J9005E version on the right both running on PAL.
Also the games "Evolution Dino Dudes" and "Crescent Galaxy" had a "non-E" and a "PAL fixed E" release.
Robert
