ndary Posted October 24, 2017 Share Posted October 24, 2017 Hi, Maybe this topic has been covered before, if so i would appreciate if some one could direct me to the correct thread. I did the simple A/V Composite Mod that is show in the following document on a 4 Switch PAL ATARI 2600 : http://www.coolretroprojects.com/atari_2600_av_mod_installation_guide.pdf The Problem is that not on every TV i see a picture, on one TV i see the image clear and fine, and on another i get no image at all!?!?! I installed the same A/V Composite Mod on a 6 Switch Atari 2600 and this machine can show the image on all TV's?? very strange??? I replace the RCA Cables, tried another Composite Mod PCB, even tried another ATARI 4 switch console and got the same result, on two 6 Switch Atari 2600 that i tested the video is shown on all TV's but on three ATARI 4 Switch console the video is show on some TV fine and on the other shows as "NO SIGNAL" did any one heard about this phenomena? 1 Quote Link to comment Share on other sites More sharing options...
EvoMikeUK Posted October 24, 2017 Share Posted October 24, 2017 Hi, Maybe this topic has been covered before, if so i would appreciate if some one could direct me to the correct thread. I did the simple A/V Composite Mod that is show in the following document on a 4 Switch PAL ATARI 2600 : http://www.coolretroprojects.com/atari_2600_av_mod_installation_guide.pdf The Problem is that not on every TV i see a picture, on one TV i see the image clear and fine, and on another i get no image at all!?!?! I installed the same A/V Composite Mod on a 6 Switch Atari 2600 and this machine can show the image on all TV's?? very strange??? I replace the RCA Cables, tried another Composite Mod PCB, even tried another ATARI 4 switch console and got the same result, on two 6 Switch Atari 2600 that i tested the video is shown on all TV's but on three ATARI 4 Switch console the video is show on some TV fine and on the other shows as "NO SIGNAL" did any one heard about this phenomena? I find this mod very unstable and unreliable across models and tvs myself. I did it on one Junior which refused to work outright. Its a crude hack. Might be worth investing in a different mod. Quote Link to comment Share on other sites More sharing options...
Swami Posted October 24, 2017 Share Posted October 24, 2017 Hi, Maybe this topic has been covered before, if so i would appreciate if some one could direct me to the correct thread. I did the simple A/V Composite Mod that is show in the following document on a 4 Switch PAL ATARI 2600 : http://www.coolretroprojects.com/atari_2600_av_mod_installation_guide.pdf The Problem is that not on every TV i see a picture, on one TV i see the image clear and fine, and on another i get no image at all!?!?! I installed the same A/V Composite Mod on a 6 Switch Atari 2600 and this machine can show the image on all TV's?? very strange??? I replace the RCA Cables, tried another Composite Mod PCB, even tried another ATARI 4 switch console and got the same result, on two 6 Switch Atari 2600 that i tested the video is shown on all TV's but on three ATARI 4 Switch console the video is show on some TV fine and on the other shows as "NO SIGNAL" did any one heard about this phenomena? Here is a similar thread concerning a similar mod on a ColecoVision. I also discuss my experience with a 2600 Junior modded with the basic AV board. Even when a picture appears on a CRT, it often doesn't fill the whole screen and there is an odd blocky black border on one or more sides. I understand there are components missing from this board which stabilize the signal many CRTs are sensitive to. http://atariage.com/forums/topic/270374-retrofixes-cv-mod/ Quote Link to comment Share on other sites More sharing options...
ndary Posted October 24, 2017 Author Share Posted October 24, 2017 can it be that the video signal level in the 4 switch is lower then the 6 switch? and that's is the reason for the problem? Quote Link to comment Share on other sites More sharing options...
ndary Posted October 25, 2017 Author Share Posted October 25, 2017 I swapped out the 2.2k with a 4.7k ohm resistor and the 3.3k with a 6.8k ohm resistor, now the image is shown in the screen i could not see before but the picture is very blury Quote Link to comment Share on other sites More sharing options...
SignGuy81 Posted October 25, 2017 Share Posted October 25, 2017 yes, the video signal is too weak for some TVs to recognize. A composite video signal should be 1Vpp but it isn't with the mod. Some TVs will accept it anyway but others will not. Quote Link to comment Share on other sites More sharing options...
SignGuy81 Posted October 26, 2017 Share Posted October 26, 2017 (edited) http://atariage.com/forums/topic/264563-no-picture-composite-mod/ You will see I ran into same issue as you, in trying to get a stronger signal I also introduced more ghosting. I was going to return to that awhile back but never got around to it. I am so tired when I get off work and then have so much stuff that has to be done on the weekends plus want to relax some from work I hardly ever get around to doing things I set out to do. Edited October 26, 2017 by SignGuy81 Quote Link to comment Share on other sites More sharing options...
hizzy Posted October 26, 2017 Share Posted October 26, 2017 i will co-sign the electronic sentimentalities board. It's really good. Quote Link to comment Share on other sites More sharing options...
Osgeld Posted October 26, 2017 Share Posted October 26, 2017 the strength of the signal is "louder" on 6 switch models, with my av amp's i usually use a 1.5k pulldown to the input of the driver (a ths or fms component video buffer) where as the 6's I have to lower it to 1k, so more of the signal gets sent to ground and even then the old 6 switch models like to ghost more than newer ones, or like the one on my desk now, which is a heavy sixer guts in a light six case (which happens) is even worse and I am plonking at it trying to get it clean Quote Link to comment Share on other sites More sharing options...
simon.plata Posted November 3, 2017 Share Posted November 3, 2017 I swapped out the 2.2k with a 4.7k ohm resistor and the 3.3k with a 6.8k ohm resistor, now the image is shown in the screen i could not see before but the picture is very blury I had same problem with my AV mod. The problem was the coupling impedance and a 150pF capacitor not removed from the board. I decided to design my own video amplifier and it Works well. First I tried with a simple one stage design. Clear and Sharp image but not ful brightness. Then I tried with a two stage and I'm happy with the results. Attached the scree pictures of an CRT TV and a LED TV. If you are interested in try this circuit just let me know and I will post the schematics. 1 Quote Link to comment Share on other sites More sharing options...
