+arcadeshopper Posted October 24, 2017 Share Posted October 24, 2017 (edited) https://github.com/hartator/wayback-machine-downloader Wayback Machine Downloader Download an entire website from the Internet Archive Wayback Machine. InstallationYou need to install Ruby on your system (>= 1.9.2) - if you don't already have it. Then run: gem install wayback_machine_downloader Tip: If you run into permission errors, you might have to add sudo in front of this command. Basic UsageRun wayback_machine_downloader with the base url of the website you want to retrieve as a parameter (e.g., http://example.com): wayback_machine_downloader http://example.com How it worksIt will download the last version of every file present on Wayback Machine to ./websites/example.com/. It will also re-create a directory structure and auto-create index.html pages to work seamlessly with Apache and Nginx. All files downloaded are the original ones and not Wayback Machine rewritten versions. This way, URLs and links structure are the same as before. Edited October 24, 2017 by arcadeshopper 4 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted October 25, 2017 Share Posted October 25, 2017 Thanks. Might need this to recover my website which disappeared with a hard drive crash. 1 Quote Link to comment Share on other sites More sharing options...
