my start with RB+ - barbarian project- need help
177 replies to this topic
#26 ggn OFFLINE
ggn
  • 1,433 posts
Posted Thu Nov 9, 2017 1:45 AM
The first object in rapinit.s is called "text/particle layer" for a reason :). All print commands actually write to that layer. As long as you have that layer active you'll get transparent text on screen. If for some reason you don't want to use that mechanism you'll have to write your own text printing functions that write on other objects.... which is not really recommended :)
So the question is: does print not work for you with the 4 scenarios? Does it work for 1 only and not for the rest? More details please!
  • F.L likes this
#27 F.L OFFLINE
F.L
    Chopper Commander
  • 120 posts
Posted Thu Nov 9, 2017 2:00 AM
Ok !
Yes it's for the 4 scenaries : to write the score of players and the time of each round.
I must remember everithing is a sprite with jaguar
I have an idea. I will make a "hole" at the right place in the 4 scenaries for seeing the text ! ;)
#28 Sporadic OFFLINE
Sporadic
    Dragonstomper
  • 516 posts
  • Probably RB+ing
Posted Thu Nov 9, 2017 2:03 AM
You can move the particle text layer to the bottom of the list. Then the text will appear above everything else. You must make sure you have an active object at the top though.
Edited by Sporadic, Thu Nov 9, 2017 2:03 AM.
#29 F.L OFFLINE
F.L
    Chopper Commander
  • 120 posts
Posted Thu Nov 9, 2017 4:46 PM
in rapinit i have moved particle text layer behind my first scenary and now i can write on it, thanks. but i have a problem with the 3 others....
Well you could define all the sprites as raptor objects but as you say it'll be a LOT of work! Also it will slow down raptor processing a bit, and we can't have that!
One way to slow down your animations is to change the sprite_animspd property (either in rapinit.s or at runtime). This will make the animation slow down by frames. So if your screen displays at 60fps then you can make your animation run at 30fps, 15fps and so on. But that won't work if you want your animation to update at, say, 40fps.
So here's another way of doing this. Here's a spritesheet from nyandodge, zoomed up x4:
Each frame is 32 pixels wide by 11 pixels high. We can use this to our advantage! If you know the address of the first frame it's very easy to find the address of the second. Basically you need to add height * ( width * no_of_bits_per_pixel ) / 8 to your address. So in the above example our picture is 4 bits per pixel so we need to add 11*(32*4)/8=176 bytes. The third frame is then 176*2 bytes from the start, etc etc. So you can keep a frame counter and when it reaches 40 calculate and set the sprite's gfxbase and set it using rsetobj (or rlist which is recommended).
Hope I didn't screw up the maths above and that it helps you :)
i am still stuck on the adress of the second frame of a sprite sheet....
for the example nyancat, each frame is 176 bytes
so if i want to display the second frame of the nyancat, i must do
DIM frame1%
frame1=RGETOBJ(1,R_sprite_gfxbase)
rsetobj(1,R_sprite_gfxbase,frame1+(176) )
it is correct ?
for my 4 background, i want to use a sprite sheet.it is a good idea ?
each frame is 320*200. in rapinit i load an image of 320*800
each frame does 200*(320*4)/8 = 32000 bytes
but when i do +(32000) to my background , it makes glitches...at screen ???
i must have not understand something....
it is a better idea to swap my 4 background ?
#30 sh3-rg OFFLINE
sh3-rg
  • 3,396 posts
  • doge + tie = dothemath
Posted Thu Nov 9, 2017 4:56 PM
it is correct ?
Edited by sh3-rg, Thu Nov 9, 2017 4:57 PM.
#31 ggn OFFLINE
ggn
  • 1,433 posts
Posted Fri Nov 10, 2017 12:41 AM
DIM frame1%
it is correct ?
I just tested the following in nyandodge:
- In rapinit.s change sprite_maxframe to 0 in the player's sprite
- In nyandodge.bas add the following lines outside the main loop:
dim frameno as int
frameno=0
- Inside the main loop (immediately after the DO instruction) add the following lines:
    frameno=(frameno+1) band 7
    rsetobj(1,R_sprite_gfxbase,(int)strptr(BMP_PLAYER)+176*frameno)
And that gives me control over the animation. Notice the (int)strptr() in there - that gives the address of the object.
Well, there are glitches and there are glitches :), so what do you mean when you say "glitches"?
I'm not sure if using a spritesheet for your backgrounds is a good idea - your backgrounds are 320x200 and the viewscreen can be 320x240 or 320x256. So I would guess that if you place the object on screen you'd see some lines from other maps as well! So probably 4 different objects that have their active attributes changed is probably better.
#32 F.L OFFLINE
F.L
    Chopper Commander
  • 120 posts
Posted Fri Nov 10, 2017 8:16 AM
yes, differents objects with active attributes is better. i have done this first time.
but i cant write on them.
i have moved particle/text layer after them and i can write on only the scenary just before the text layer,
and the other scenaries before this one are not visible... it's strange
something strange too, the position of my text is not the same if i launch the rom with project tempest or virtual jaguar
project tempest is 4 pixels bottom
wich emulator is 100% working like the real hardware ?
Edited by F.L, Fri Nov 10, 2017 8:38 AM.
#33 Shamus OFFLINE
Shamus
    Dragonstomper
  • 666 posts
  • Moo, er, Roar!
Posted Fri Nov 10, 2017 9:35 AM
No emulator works 100% like real hardware, but VJ (for all its faults, which are many) is closer than PT IMNSHO. :)
#34 F.L OFFLINE
F.L
    Chopper Commander
  • 120 posts
Posted Fri Nov 10, 2017 5:54 PM
hello
good news !  i have understand how to manage the adress of a spritesheet and it works good :thumbsup:
i have updated the zip, now all the background and their trees are displayed like this !
bad news : despite all my efforts, i dont become to write text of my background...
like sporadic have said to me, i moved the text layer, but it seems it works if only one simply background is before.
if a spritesheet is before, or if i swap the gfx_base, there are glitches on the screen..?
so, for writing my text, i have open an hole in my backgrounds. its not beautiful but and it works too ;)
enough coding for tonight
good night :sleep:
Edited by F.L, Fri Nov 10, 2017 5:54 PM.
#35 ggn OFFLINE
ggn
  • 1,433 posts
Posted Sat Nov 11, 2017 2:44 AM
Ok, so I spent a little time with your problem so here's my solution: this sets the 4 backdrops as objects 0-3, the text layer in object 4 and flips between the backdrops. The easiest way to make an object disappear that I could think about is to set its y coordinate to some high value. So I set the invisible objects to (0,700) and the visible ones to (0,16). This is really not a big performance hit on the OP because it simply checks the current scanline number it draws with the y coordinate of each object. Since it goes from 0 to 255 (roughly) the invisible objects aren't processed after a small check.
Anyway, hope this helps you :).
Edited by ggn, Sat Nov 11, 2017 10:21 AM.
#36 F.L OFFLINE
F.L
    Chopper Commander
  • 120 posts
Posted Sat Nov 11, 2017 8:08 AM
Ok, i will try this !
A very big thanks to all your help, if i do cartridges of the game, i will give you one :)
#37 CyranoJ OFFLINE
CyranoJ
    RAPTOR Wrangler
  • 5,609 posts
  • reBOOTed
Posted Sat Nov 11, 2017 8:35 AM
it is correct ?
Can you post the spritesheet and a screenshot of it glitched, because a single object and changing the gfxbase should work.
#38 F.L OFFLINE
F.L
    Chopper Commander
  • 120 posts
Posted Sat Nov 11, 2017 12:56 PM
Yes it works like this.
In my rom you can see it.
The glitches came from the moving of text layer
Today i have no time to test the code of ggn, maybe tomorrow
Edited by F.L, Sat Nov 11, 2017 12:57 PM.
#39 ggn OFFLINE
ggn
  • 1,433 posts
Posted Sat Nov 11, 2017 1:20 PM
Hey, if there not many customers, there is better support :)
#40 F.L OFFLINE
F.L
    Chopper Commander
  • 120 posts
Posted Sun Nov 12, 2017 3:24 AM
i have tried your background example, i like when an example is clear like that, i understand quicklly !
i will use that for my next update of the rom
in my precedent release,  i was using the same method than you for hiding my backgrounds, exept that i did x =400
maybe it was not a good method than y=700 for the hardware and it does the glitches..?
edit :
in your example your pictures are 320*200 but why you did in rapinit :
 dc.l 160*200 ; sprite_framesz
 dc.l 160 ; sprite_bytewid
and it display an image of 320*200 at screen ?.... i dont understand something :?
Edited by F.L, Sun Nov 12, 2017 3:43 AM.
#41 Welshworrier OFFLINE
Welshworrier
    Moonsweeper
  • 250 posts
Posted Sun Nov 12, 2017 4:05 AM
It's a long declaration, so allocating 32 bits per element. Your image is 16 bits per element so you require half the amount.
  • F.L likes this
#42 ggn OFFLINE
ggn
  • 1,433 posts
Posted Sun Nov 12, 2017 4:29 AM
My pictures are 4 bits per pixel and 320 pixels width. So the amount of bytes per line is (320 (pixels) * 4 (bits/pixel) ) / 8 (bits/byte) = 160 bytes.
If you understand the above, then this is easy, 160 bytes per line * 200 lines = 32000 bytes. Also if I remember correctly this variable is only used when animating sprites so it wouldn't matter even if I set it to a wrong value :).
#43 F.L OFFLINE
F.L
    Chopper Commander
  • 120 posts
Posted Sun Nov 12, 2017 4:30 AM
ok, i was declaring 2x and maybe it was because of that it was not working! :thumbsup:
  • ggn likes this
#44 sh3-rg OFFLINE
sh3-rg
  • 3,396 posts
Posted Sun Nov 12, 2017 6:41 AM
IIRC, when you're sending stuff off screen to not be displayed, it's best to use y as it'll be culled from the object list. If you use x, it'll still factor into calculations each life buffer pass it is present on in y. Also, think there's a danger it will reappear back on the other side of the screen.
#45 F.L OFFLINE
F.L
    Chopper Commander
  • 120 posts
Posted Sun Nov 12, 2017 12:23 PM
hello its  me again
with your help those days, i have done new important update of the rom ;-) :thumbsup:
try it, you will see what's new :
the 4 scenaries and their trees are here and i can write on them ;)
i have done the animation of the goblin with a sprite sheet .
this is the most difficult animation of this game to reproduce  and it works fine
now, i have all i need to do the game (exept the sound) :grin:
this week i will begin the animation of players. there is 63 animations to do.
i think it will take me a few days (weeks ?) . with those animations, the rom will quickly seems like a real game
i will gave you some news of the advancement
see ya
#46 F.L OFFLINE
F.L
    Chopper Commander
  • 120 posts
Posted Wed Nov 15, 2017 4:10 PM
hello
i have found a new method to manage my spritesheet, so the work is in good advancement but i must rename many values
now 6 animations are soon active in the beta rom
i'm happy because the animation is fluid. for the moment ,it's the most fluid animation i've done on a game console. the jaguar is very powerful !! :thumbsup:
only 49 to do ;)
see ya
Edited by F.L, Wed Nov 15, 2017 4:13 PM.
#47 F.L OFFLINE
F.L
    Chopper Commander
  • 120 posts
Posted Sun Nov 19, 2017 3:36 PM
hello
the dev is in good way
all the animations are available (some little sprites are missing) and i must down the speed of the game
i have done a video of the source and the build of the new beta rom
Edited by F.L, Sun Nov 19, 2017 3:42 PM.
#48 Sporadic OFFLINE
Sporadic
    Dragonstomper
  • 516 posts
  • Probably RB+ing
Posted Sun Nov 19, 2017 3:45 PM
Looking great! Good job :)
  • F.L likes this
#49 CyranoJ OFFLINE
CyranoJ
    RAPTOR Wrangler
  • 5,609 posts
  • reBOOTed
Posted Sun Nov 19, 2017 4:48 PM
Awesome! What's better than one Barbarian on the Jaguar? Two Barbarians on the Jaguar!
#50 F.L OFFLINE
F.L
    Chopper Commander
  • 120 posts
Posted Mon Nov 20, 2017 4:41 PM
and why not 7 barbarians on jaguar ;)
with my engine, it will be easy to do all the others.
one thing could be more cool : to have all the 7 versions in only one rom! :thumbsup:
but for the moment i will finish this one...and there is work to do :grin:
Reply to this topic
