Atari 1010 not loading cassettes
16 replies to this topic
#1 haightc OFFLINE
haightc
    Chopper Commander
  • 120 posts
Posted Tue Nov 7, 2017 12:25 AM
From what I can tell my player is playing cassette okay.    I've cleaned the head, but no tapes will load.   I always get a 130 error, what should I be looking for to get this player working?
#2 baktra OFFLINE
baktra
    Moonsweeper
  • 429 posts
Posted Tue Nov 7, 2017 1:21 AM
Hello,
you didn't describe what you have exactly tried.
I believe the first step is to check if the data recorder can read its own recordings. Please refer to this post to see how to do it with ATARI BASIC.
You report that you see ERROR 130. This  is a "nonexistent device" error. Ensure you are using the C: device. Or did you mean ERROR 138 or ERROR 143?
Also, ensure that you are loading the software on the tape properly.
  • Machine language programs (most games) are loaded by booting from tape: Hold START+OPTION during cold start of the computer (or power up)
  • Atari BASIC programs saved with CSAVE command are loaded by the CLOAD command.
  • Atari BASIC programs saved with SAVE"C:" command are loaded by LOAD"C:" or RUN"C:" commands
  • Atari BASIC programs saved with LIST"C:" command are loaded by ENTER"C:" command.
#3 haightc OFFLINE
haightc
    Chopper Commander
  • 120 posts
Posted Wed Nov 8, 2017 12:41 AM
The error I am getting is 140 not 130, I mis-remembered.  if I advance a little further sometimes I'll get an error 143 (at line 0).   Counter ticks away, hard to know if tape speed is correct though.    I am loading a basic program, specifically conversational french, so it would be CLOAD.
#4 JoSch OFFLINE
JoSch
    Moonsweeper
  • 427 posts
Posted Wed Nov 8, 2017 2:15 AM
I had something like that with my 1010 and XC12, until I renewed the belts. After that, all the problems were gone.
But before you rush to buy the belts, do the tests, baktra detailed.
#5 baktra OFFLINE
baktra
    Moonsweeper
  • 429 posts
Posted Wed Nov 8, 2017 2:49 AM
Yes CLOAD it is, also according to the instructions manual for the software.
There are few measures you can take to narrow down the problem:
  • Try the experiment with recording to a new blank tape. This way you determine if the problem is the data recorder or the cassette. Maxell UR90 or products of the National Audio Company should be around in USA.
  • Try inserting a standard music cassette with pre-recorded music and entering POKE 54018,52. Then use your ears to determine any anomalies (fluctuations of speed/pitch). This will reveal obvious mechanical problems (motor, loose belt)
  • Use cassette adapter. If there is a mechanical problem, but the electronics are OK, you should be able to load data using the cassette adapter. Use attached WAVE file.
#6 baktra OFFLINE
baktra
    Moonsweeper
  • 429 posts
Posted Wed Nov 8, 2017 6:57 AM
I forgot to mention that the WAVE file holds a machine language program. So boot it from tape by holding START when powering-up the computer. Presence or absence of the BASIC cartridge has no effect on the program.
Edited by baktra, Wed Nov 8, 2017 6:58 AM.
#7 haightc OFFLINE
haightc
    Chopper Commander
  • 120 posts
Posted Tue Nov 14, 2017 12:40 AM
Well doing POKE with an audio tape gives regular sounding playback. I think I have an old casette desk in my garage so I guess the next step would finding some new cassette and recording the file. I don't have a cassette adapter anymore, but I think that might be a good idea to try.
#8 haightc OFFLINE
haightc
    Chopper Commander
  • 120 posts
Posted Sat Nov 18, 2017 12:57 AM
Using a cassette audio adapter I was able to load the test program.     I found FLAC copies of the conversation french cassettes online and was able to load them via adapter.   These cassette need a real tap played and unfortunately my audio cassette deck is dead so I'll need to pick up another one and record the files to fresh tape.    I am a little surprised all the tapes in the pack fail to load.    The real test will be new tapes next.
#9 _The Doctor__ OFFLINE
_The Doctor__
  • 3,806 posts
Posted Sat Nov 18, 2017 11:02 AM
fast forward and rewind the tapes all the way a few times... I have found there are often tight and loose spots in a tape, this can cause failure to load. after your done the tape plays more smoothly and often works just fine after that..
#10 haightc OFFLINE
haightc
    Chopper Commander
  • 120 posts
Posted Tue Nov 21, 2017 11:24 PM
My old tape deck sadly doesn't work, I tried to hit up a few thrift shop put only one had one and they want $50 for it as is.  I might try couple others, but I might have better luck waiting for someone to be given one away.   I have an SIO2PC, it look AspeQT can emulate a CAS I am not sure if it can use a FLAC file.    Any other good ways getting a audio file back onto a real cassette, that doesn't involve going out and buying a tape deck?
#11 _The Doctor__ OFFLINE
_The Doctor__
  • 3,806 posts
Posted Tue Nov 21, 2017 11:54 PM
generally you need a tape deck to record audio to a tape...
#12 baktra OFFLINE
baktra
    Moonsweeper
  • 429 posts
Posted Wed Nov 22, 2017 12:28 AM
If you have a SIO2PC, then you can use one of the disk to cassette copiers. E.g. Nudmehi's boot cassette maker. It is a program that takes a .xex file from diskette and writes it to cassette, so all you need is the 1010. AspeQt supports only .cas files for imperfect 1010 emulation.
#13 _The Doctor__ OFFLINE
_The Doctor__
  • 3,806 posts
Posted Wed Nov 22, 2017 2:20 PM
I only use the cassette for 2 track, that's data + audio titles, every thing  else where possible has been moved to disk or solid storage...
#14 haightc OFFLINE
haightc
    Chopper Commander
  • 120 posts
Posted Sun Nov 26, 2017 6:34 PM
Well I picked up a cassette deck and recorded the FLAC to cassette.   Sadly the cassette doesn't load, audio doesn't sound as good as the FLAC but that shouldn't be to surprising.    I don't recall the audio sounding bad from the original cassette, so maybe I'll try dubbing the original.    There is a a recording gain adjustment, so this maybe a factor.   Also I'll try cleaning the tape heads on the deck and see if that helps.     I am trying to record on a brand new Maxwell UX90, possibly new media isn't well suiting for this application?
#15 _The Doctor__ OFFLINE
_The Doctor__
  • 3,806 posts
Posted Sun Nov 26, 2017 8:19 PM
It has been my experience that normal bias tape properly tensioned at 30 (15 minutes/side), 60 (30 minutes/side), or 90 (45 minutes/side) work best.. high bias and metal tapes are Not the way to go for most data-cassette players..
#16 baktra OFFLINE
baktra
    Moonsweeper
  • 429 posts
Posted Mon Nov 27, 2017 1:36 AM
Contemporary Maxell UR90 tapes work perfectly with Atari data recorders. though they are low-end.
I recorded many of them with a tape deck, programs load flawlessly (both standard records and those east and central European turbo systems).
I would guess the cassette deck has recording level indicators (VU meters, recording meters)  that indicate the recording level. The test16k.wav file is a stereo file. Verify that the indicator for the right channel shows almost constant high level, while left channel indicates no signal or almost no signal. The best option is to record with a recording level that ensures the meters are very close to the red area, but not in the red area.
#17 _The Doctor__ OFFLINE
_The Doctor__
  • 3,806 posts
Posted Mon Nov 27, 2017 9:18 AM
unless your doing a dual track recording... with audio on one track and data on the other... then you need both left and right hovering in that realm
