how many CPU cycles in a scanline?
22 replies to this topic
#1 sanny OFFLINE
sanny
    Chopper Commander
  • 200 posts
Posted Thu Nov 9, 2017 6:48 AM
Hi,
I've got two questions, which might be related.
The Altirra manual in section 2.3 states that there are 114 CPU cycles per scan line.
I've written a test program which disables Antic, DMA, and everything. Then it changes the background color register while the screen is displayed.
This test program needs to consume 105 cycles per scan line, otherwise the display gets distorted.
This is my first question. Is the Altirra manual wrong, or where do I lose the 9 (114-105) cycles?
For the second question look at the attached screen shot.
I expected the vertical bars to be evenly spaced.
I'm doing this in the program
; this should give evenly spaced horizontal bars
; but somehow that's not the case !??
        CYCLES  33
        STX     COLBK   ; 4 cycles (37)
        STA     COLBK   ; 4 cycles (41)
        STX     COLBK   ; 4 cycles (45)
        STA     COLBK   ; 4 cycles (49)
        STX     COLBK   ; 4 cycles (53)
        STA     COLBK   ; 4 cycles (57)
        STX     COLBK   ; 4 cycles (61)
        STA     COLBK   ; 4 cycles (65)
        STX     COLBK   ; 4 cycles (69)
        STA     COLBK   ; 4 cycles (73)
        STX     COLBK   ; 4 cycles (77)
        STA     COLBK   ; 4 cycles (81)
        STX     COLBK   ; 4 cycles (85)
        STA     COLBK   ; 4 cycles (89)
        STX     COLBK   ; 4 cycles (93)
        STA     COLBK   ; 4 cycles (97)
        STX     COLBK   ; 4 cycles (101)
        STA     COLBK   ; 4 cycles (105) -> 105 cycles total
This is for one display line. The code is repeated a few times to get "bars".
On the right half of the screen this looks like expected. But on the left half, the bars are thicker and the space between them is also larger. Can someone explain this effect to me? Maybe my missing cycles are somehow consumed by these bigger bars and spaces btw. them.
Attached are a precompiled exe and the (cc65) source code.
regards,
chris
#2 flashjazzcat ONLINE
flashjazzcat
  • 13,012 posts
Posted Thu Nov 9, 2017 6:53 AM
DRAM refresh still happens even if you disable DMA, and that consumes 9 cycles most of the time. I'm guessing that'll explain the uneven bar spacing too.
Edited by flashjazzcat, Thu Nov 9, 2017 6:54 AM.
#3 Xuel OFFLINE
Xuel
    Dragonstomper
  • 638 posts
Posted Thu Nov 9, 2017 11:06 AM
I second what flashjazzcat said. You can see all refresh and DMA cycles in Altirra by pressing Shift-F8. If you do that when DMA is completely disabled you see the following pattern:
Notice that the positions of the DRAM refresh cycles correspond to the area where your bars are distorted.
Maybe you could even out the bars by intermixing ST* ABS, ST* ABS,Y and STA (ZP),Y instructions to adjust the width by one or two cycles at opportune moments since those take 4, 5 and 6 cycles respectively. You could also get 7 cycles if you force a page boundary to be crossed.
Edited by Xuel, Thu Nov 9, 2017 11:07 AM.
#4 _The Doctor__ OFFLINE
_The Doctor__
  • 3,765 posts
Posted Thu Nov 9, 2017 11:14 AM
I think he wants to get as much out of each line as possible and wants to know how to get it all. so what is the answer 105 yes? and we are losing 9 instead of 8? why is there a difference pal/ntsc?    covering the bases here...
Edited by _The Doctor__, Thu Nov 9, 2017 11:15 AM.
#5 Xuel OFFLINE
Xuel
    Dragonstomper
  • 638 posts
Posted Thu Nov 9, 2017 11:28 AM
There's no difference in the number of cycles per line between PAL and NTSC. When DMA is disabled, DRAM refresh always consumes 9 cycles. The only time refresh takes fewer cycles is on "badlines" where some of the refresh cycles are blocked by character set index lookups depending on the width of the screen and the HSCROL status. See the timing diagrams in the Altirra Hardware Reference Manual for precise timings.
#6 Heaven/TQA OFFLINE
Heaven/TQA
  • 10,560 posts
Posted Thu Nov 9, 2017 1:34 PM
Interesting so the claim 114 cycles for code is wrong?
#7 emkay ONLINE
emkay
  • 9,026 posts
  • What's up?
Posted Thu Nov 9, 2017 3:32 PM
As I wrote in an other thread...
#8 sanny OFFLINE
sanny
    Chopper Commander
  • 200 posts
Posted Thu Nov 9, 2017 4:53 PM
Yes, that was the reason for my question.
Thanks for you answers.
Now I know there's nothing wrong with my program and that there are only 105 cycles available per scan line.
#9 Stephen OFFLINE
Stephen
  • 6,717 posts
  • A8 Gear Head
Posted Thu Nov 9, 2017 5:00 PM
#10 _The Doctor__ OFFLINE
_The Doctor__
  • 3,765 posts
Posted Thu Nov 9, 2017 7:19 PM
ah but debates about what can be done with badlines or re working the the systems might surface  .....
#11 pirx OFFLINE
pirx
    Moonsweeper
  • 399 posts
Posted Fri Nov 10, 2017 3:23 AM
apparently a scam line
#12 Rybags OFFLINE
Rybags
  • 15,412 posts
Posted Fri Nov 10, 2017 3:56 AM
There's 114.  A cycle is a cycle whether it's stolen or not.  The exact cycles lost will vary depending on graphics mode, if HScrolling going on etc.
This thread needs some hipster jokes...
Edited by Rybags, Fri Nov 10, 2017 3:58 AM.
#13 MrFish OFFLINE
MrFish
  • 4,415 posts
Posted Fri Nov 10, 2017 8:05 PM
Technically, no cycle was stolen here.
#14 flashjazzcat ONLINE
flashjazzcat
  • 13,012 posts
Posted Sat Nov 11, 2017 2:48 AM
Precisely. The cycle pictured is not stolen, but nor is it usable. We're talking about usable cycles, of which there appear to be 105 at most. :)
#15 Sheddy OFFLINE
Sheddy
    Dragonstomper
  • 689 posts
Posted Sat Nov 11, 2017 3:36 AM
Never were truer words spoke. Nothing stolen, but you could get pumped up thinking you had the whole 114. Bit of a let down, but we just have to handle it.
Wheely a shame
..ok, not proud of that last one...
#16 flashjazzcat ONLINE
flashjazzcat
  • 13,012 posts
Posted Sat Nov 11, 2017 3:50 AM
Thanks for that rider.
#17 Sheddy OFFLINE
Sheddy
    Dragonstomper
  • 689 posts
Posted Sat Nov 11, 2017 3:57 AM
I could go on, but I'm tired now
Edited by Sheddy, Sat Nov 11, 2017 4:01 AM.
#18 Irgendwer OFFLINE
Irgendwer
  • 1,284 posts
Posted Sat Nov 11, 2017 4:01 AM
That brings up the question how to disable the refresh if static RAM is used (there are some memory extensions with SRAM) - not that "fragmenting the platform" is a good thing, just for the sake of it...?
#19 Rybags OFFLINE
Rybags
  • 15,412 posts
Posted Sat Nov 11, 2017 4:06 AM
Not a lot of point really, you'd end up with an incompatible system.
I suppose in doing it you'd get a "poor man's accelerated" machine with a blistering 9% or so performance increase.
The logic involved would simply be taking /REF and /HALT from Antic.  Whenever /REF is active, override /HALT to bring it high as seen by the CPU.
But the problem is you'd also need to isolate the address bus since Antic is outputting a row address for the refresh.
So the poor man's accelerator ends up being more complex/costly than a rich man's one.
Edited by Rybags, Sat Nov 11, 2017 4:06 AM.
#20 emkay ONLINE
emkay
  • 9,026 posts
  • What's up?
Posted Sat Nov 11, 2017 4:44 AM
This really looks like most cycles were stolen at a bad line.
#21 MrFish OFFLINE
MrFish
  • 4,415 posts
Posted Sat Nov 11, 2017 12:03 PM
I understand what the discussion's about. My comment was meant to be humorous.
#22 flashjazzcat ONLINE
flashjazzcat
  • 13,012 posts
Posted Sat Nov 11, 2017 1:32 PM
I know dude... so was mine. :)
#23 emkay ONLINE
emkay
  • 9,026 posts
  • What's up?
Posted Sat Nov 11, 2017 3:17 PM
Saving CPU cycles ? Just let Antic do scrolling, shuffling Data around, let the screen shake ...
