Mr Robot Posted November 10, 2017 Share Posted November 10, 2017 Could someone help me find out what value these four capacitors are? I'm trying to install a stereo Pokey and the previous owner of my 800XL (which turned out to be quite the frankentari) has recapped it, using huge tantalum caps that are so big I cannot get the pokey board to seat without a liftoff; if I use a liftoff I can't get the case to close so I need to change the caps. Thanks! Quote Link to comment Share on other sites More sharing options...
Level42 Posted November 10, 2017 Share Posted November 10, 2017 Can't you fold them to one side ? Quote Link to comment Share on other sites More sharing options...
ivop Posted November 10, 2017 Share Posted November 10, 2017 I'd say, just desolder them and read the Cxx number underneath. Then check the schematics and see what value they should be. Quote Link to comment Share on other sites More sharing options...
Level42 Posted November 10, 2017 Share Posted November 10, 2017 (edited) Or you have a look at Sam's computer facts for the 800XL, see they are in sections I23 and J23, look them up in the table, which shows they are C63 to C66. Then you check the schematics in the same document, look in the area of POKEY and find they are all .047 caps. http://www.atarimania.com/documents/Atari_800XL_Sams_Computerfacts_Technical_Service.pdf Edited November 10, 2017 by Level42 4 Quote Link to comment Share on other sites More sharing options...
Mr Robot Posted November 10, 2017 Author Share Posted November 10, 2017 Can't you fold them to one side ? Nope, one leg is soldered to the board so tight they hardly move, then the other leg is stretched to the other hole. For the next cap the positions are reversed. :/ 1 Quote Link to comment Share on other sites More sharing options...
Mr Robot Posted November 10, 2017 Author Share Posted November 10, 2017 Or you have a look at Sam's computer facts for the 800XL, see they are in sections I23 and J23, look them up in the table, which shows they are C63 to C66. Then you check the schematics in the same document, look in the area of POKEY and find they are all .047 caps. http://www.atarimania.com/documents/Atari_800XL_Sams_Computerfacts_Technical_Service.pdf That's exactly what I was after, thanks! 2 Quote Link to comment Share on other sites More sharing options...
mechanerd Posted December 4, 2017 Share Posted December 4, 2017 I supposed one could just clip the caps off, leaving the pins to remain on the pcb intact, then move them to another area with wire wrap as needed to make the whole thing fit. I mean this would Frankenstein the board even more so. But at least you could identify the caps with the markings or an LCR meter. I had to do similar hacks on PC motherboards with the bad batch of electrolytics out there in 2004-2007. It was the devil to order the exact size to replace, so put the cap on a pair of wires going to the spot where they belong. Hot glue them in place and forget it about it.I was able to restore 5 or so Socket 478, socket 7, and several Nvidia graphics cards (PNY mostly). 1 Quote Link to comment Share on other sites More sharing options...
