The barf-o-matic
beer recommended
4 replies to this topic
#1 ramidavis OFFLINE
ramidavis
    Chopper Commander
  • 119 posts
Posted Sat Nov 11, 2017 5:42 PM
How to enjoy this program:
[BARF program attached. Remove the .bin ending, its a tifile from classic99]
1. Grab a beer
2. Open classic99 and paste the following program
3. If you want a endless loop, change line 7 to 7 RESTORE, otherwise the program will (eventually) end.
4. Run it
5. Enjoy your beer
:D
Character data was generated by (ab)using random.org.
Spoiler
Edited by ramidavis, Sat Nov 11, 2017 6:27 PM.
#2 digdugnate OFFLINE
digdugnate
  • 1,791 posts
Posted Sat Nov 11, 2017 6:05 PM
ha, thats pretty neat.
#3 --- Ω --- OFFLINE
--- Ω ---
    HexaCoreRunner
  • 12,840 posts
Posted Sat Nov 11, 2017 6:09 PM
I'll have to give this a shot.
#4 ramidavis OFFLINE
ramidavis
    Chopper Commander
  • 119 posts
Posted Sat Nov 11, 2017 7:20 PM
If anyone is interested, here is a sort of "behind the scenes" of the creation of this.
First off, using the link in the first post, i told it to generate 16384 random bytes, and copied that all to a text file.
I keep doing this about 6 or 7 times, and random.org informs me i have used my quota for random data generation for the day, so i decide to call it good enough. ;)
Now, i have huge list of random bytes, separated by spaces 16 bytes to a line.
I am running linux and using gedit, so the next step was to get rid of the white-space.
I used gedit's search-and-replace to first replace all 'space' characters with nothing (leave the "replace with" field empty).
Next, i did the same process for the newlines, by replacing the character "\n" with nothing (leaving the "replace with" field empty again).
The result was huge string of data with no newlines, no spaces.
Now i just needed to chop it up into 16 character hunks...
And for that, i had to do some bash-foo 8)  (bash is the linux command line environment for those wondering).
The attached text file contains probably the longest single linux command ever.(in case you want the command without all my data: echo "HUGE AMOUNT OF DATA HERE" | fold -w16 | paste -sd'\n' - > out.txt)
After running that command, out.txt contained exactly what i needed: 16-digit hex codes, 1 per line.
Another search and replace, this time replacing "\n" with "\nDATA ".
Now i had premade data statements, minus line numbers.
I fired up classic 99 in my windows xp virtual machine, issued a NUM 1,1 command and let it take as much as it could from the clipboard. Turns out it ran out of memory around the 458th entry or so, so started over, only copying the first 400.
A RES command, a simple loop added, followed by another RES, and we are all done. :)
Edited by ramidavis, Sat Nov 11, 2017 7:29 PM.
#5 --- Ω --- OFFLINE
--- Ω ---
    HexaCoreRunner
  • 12,840 posts
Posted Sat Nov 11, 2017 7:29 PM
Interesting... but not what I thought it was gonna be.
I figured it was going to be something to do with 100 bottles of beer on the wall since you named the thread Barf-O-Matic.  :grin:
