libc library for GCC
8 replies to this topic
#1 insomnia OFFLINE
insomnia
    Star Raider
  • 78 posts
Posted Mon Nov 13, 2017 10:09 PM
This is a libc implementation which is mostly compliant with the c89 standard. I've been working on this for a while as part of a disk-based OS for the TI, but this can still be used as an independent library.
I chose this standard since more recent ones mainly add support for wide characters, complex floating-point data types and other stuff which is probably not useful for a TI99/4a system.
All of the functions commonly used in stdio.h have been implemented, but there are two unresolved symbols: console_write and console_read. These are intended to provide text-based screen output and keyboard input respectively. In my OS project, these are provided by device drivers, but Tursi's libti99 would be better for anyone intending to use the stdio functions.
Hopefully this library is useful for someone. Feel free to do whatever you want with this.
#2 TheMole OFFLINE
TheMole
    Dragonstomper
  • 766 posts
Posted Tue Nov 14, 2017 9:20 AM
This is cool. Do I understand correctly that I "just" have to provide my own console_write and console_read implementations as per these function prototypes in order to use this?
size_t console_write(struct FILE_t *f, const unsigned char *buf, size_t size);
size_t console_read(struct FILE_t *f, unsigned char *buf, size_t size);
Also: super interested in learning more about the OS you're working on, would love to read more about that!
#3 insomnia OFFLINE
insomnia
    Star Raider
  • 78 posts
Posted Tue Nov 14, 2017 10:55 PM
Yup, that's pretty much it. However, those functions are only needed if you want to use the functions in stdio.I would recommend string-oriented functions like sprintf and sscanf instead, That way you could decouple file IO, screen manipulation and keyboard handling from text operations.
The OS I'm working on is intended to be written from scratch, support multitasking, be Posix-compliant, and not use anything from the existing TI console. It should run on unmodified hardware, and only need a cart for the core OS and an expansion box for the disk drives and 32K expansion memory.
Right now, I've got about 40% of the code written. A lot of the core functionality is done, but I got stuck on writing the floppy driver and finalizing a disk format. I want to be able to supports directories, links, and long filenames. Unfortunately, it's easy to get stuck in a cycle of feature-creep and early optimization.
After hitting that roadblock, I started working on a decompiler. That takes a binary image as input and outputs high-level pseudocode. That's pretty far along too, but still needs a lot of work.
I haven't kept my blog up to date since my time to work on TI stuff has been limited lately. I should probably pick that back up and do more documentation for the stuff I've written so far.
#4 TheMole OFFLINE
TheMole
    Dragonstomper
  • 766 posts
Posted Wed Nov 15, 2017 3:45 AM
Makes sense, although I was mostly thinking about how this could be helpful in the process of porting existing applications.
#5 TheMole OFFLINE
TheMole
    Dragonstomper
  • 766 posts
Posted Wed Nov 15, 2017 3:47 AM
Yes... yes you should pick that back up, for sure :)
Edited by TheMole, Wed Nov 15, 2017 3:48 AM.
#6 RickyDean OFFLINE
RickyDean
    Dragonstomper
  • 711 posts
Posted Wed Nov 15, 2017 6:36 AM
I would like to suggest the route of going the Petit fat way:
http://elm-chan.org/.../00index_p.html
I was thinking of pursuing a like venture, down the road
#7 TheBF OFFLINE
TheBF
    Moonsweeper
  • 458 posts
Posted Wed Nov 15, 2017 7:35 AM
This sounds like something that would be useful for this:
http://atariage.com/...-ide-interface/
#8 insomnia OFFLINE
insomnia
    Star Raider
  • 78 posts
Posted Sat Nov 18, 2017 4:33 PM
Accidentally hit submit, actual content here in a bit...
Edited by insomnia, Sat Nov 18, 2017 4:43 PM.
#9 insomnia OFFLINE
insomnia
    Star Raider
  • 78 posts
Posted Sun Nov 19, 2017 5:09 PM
OK, actual content time.
I was originally going to make this long-winded explanation about how console_read and console_write should be implemented, but thought a bit and decided to just implement demonstration code andbe done with it.
So I've attached a demo that shows a working example with printf and getchar. The user code is pretty simple and the back end screen and keyboard code is relatively quick. This should be a decent base for something more interesting, or a port of a text-mode program.
The only thing I failed to mention is that file IO is not working yet. That's where I got stuck. Again, Tursi's libti99 would be a great starting point. I shoould probably look into that.
Anyway, let me know if there are any problems or missing features,
BTW, the blog has been reactivated and I'll make sure it gets updated.
