Problem with my Mcwill mod for Game Gear
Gamegear Mcwill Game Gear Mod problem help fix scale
6 replies to this topic
#1 GameGear1909 OFFLINE
GameGear1909
    Combat Commando
  • 3 posts
Posted Sat Nov 18, 2017 9:34 AM
First of all, Hello everyone, i'm new in this forum. :)
Recently I've bought a Mc will mod for Game Gear and I have a problem:
When I press 1 and 2 buttons at the same time, the screen change its scale. Normally this only happens when you press 1, 2 and start button too at the same time.
Does anyone know if it's possible to fix it?, becouse is a bit annoying because some games needs to press 1 and 2 bottons at the same time.
Thank you in advance.
#2 mobiusstriptech OFFLINE
mobiusstriptech
    Chopper Commander
  • 192 posts
Posted Sun Nov 19, 2017 2:41 PM
It sounds like you have bridge or you soldered to the wrong point for Start.
#3 GameGear1909 OFFLINE
GameGear1909
    Combat Commando
  • 3 posts
Posted Mon Nov 20, 2017 1:45 PM
Thank you for your answer.
I post some pictures about it, just in case someone could help me.
Thank you in advance again
Edited by GameGear1909, Mon Nov 20, 2017 1:49 PM.
#4 mobiusstriptech OFFLINE
mobiusstriptech
    Chopper Commander
  • 192 posts
Posted Mon Nov 20, 2017 2:18 PM
Button 2 is connected on the wrong side of the cap. Switch the wire on c30 to the other side of that cap and give it a shot.
#5 GameGear1909 OFFLINE
GameGear1909
    Combat Commando
  • 3 posts
Posted Tue Nov 21, 2017 12:27 PM
Yes mate!!! You were right!!
I did what you say and it's fixed, so I want to thank you very much for your help. :)
#6 mobiusstriptech OFFLINE
mobiusstriptech
    Chopper Commander
  • 192 posts
Posted Tue Nov 21, 2017 12:34 PM
Yeah not a problem. Glad that fixed it. I need to take better pictures of both 1ASIC and 2ASIC models and make a slightly easier to follow guide for people doing the McWills screens. I have seen others run into similar issues before.
#7 cowdog360 OFFLINE
cowdog360
    Moonsweeper
  • 286 posts
Posted Fri Jun 22, 2018 9:01 AM
I like the install you did with the wires rather than using the old LCD connector.. where did you find pinouts/instructions for those?
Thanks!
Also tagged with one or more of these keywords: Gamegear, Mcwill, Game Gear, Mod, problem, help, fix, scale
