Foebane Posted November 18, 2017 Share Posted November 18, 2017 I would like to move all my Altirra.ini settings to the Registry (no .ini file) without having to set everything up from scratch (the last time I deleted my .ini file it resetted to defaults). So, is there a way of doing that, easily? Quote Link to comment Share on other sites More sharing options...
Foebane Posted November 18, 2017 Author Share Posted November 18, 2017 Never mind. I couldn't find the answer so simply decided to set everything up from scratch, from the registry. Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted November 18, 2017 Share Posted November 18, 2017 The simple answer is to delete the ini while Altirra is still running...When you then close it down it will look for the ini, not find it and save its settings to the registry.. 3 Quote Link to comment Share on other sites More sharing options...
Foebane Posted November 19, 2017 Author Share Posted November 19, 2017 The simple answer is to delete the ini while Altirra is still running...When you then close it down it will look for the ini, not find it and save its settings to the registry.. I salvaged the .ini file and tried it. I think it's worked, but it's hard to tell since I set it up again just yesterday. Quote Link to comment Share on other sites More sharing options...
