My 8-bit Games Porting to 7800 in the works
101 replies to this topic
#26 Synthpopalooza OFFLINE
Synthpopalooza
  • 1,472 posts
Posted Fri Nov 24, 2017 10:22 PM
I found a way to record videos with the ProSystem emulator. I have to use a program like OBS Studio to make a recording.
https://youtu.be/AiHu6VFEJTs
This is an early Work-in-Progress. I am trying to see how many animated objects I can have onscreen at once. They will be moving around once I figure out more stuff.
One helpful hint: MARIA DMA goes by zones. So the fewer objects you have in a horizontal zone, the better. This means you can also split things vertically and not use up a lot of DMA.
Edited by Synthpopalooza, Fri Nov 24, 2017 10:22 PM.
#27 peteym5 OFFLINE
peteym5
  • 2,378 posts
Posted Sat Nov 25, 2017 7:38 AM
I am trying something similar to what has been done on the 8-bit that is checking how many objects that are in each horizontal zone. If more than like 8 are present, 1 or more will start "sitting out" each frame. Which ones sit out rotates. If 11 objects are in the zone, objects numbered 3,5,8 will sit out one frame, next frame be like 1,4,7, etc. This causes a flickering effect, but it should not be as noticeable as it was on the 8-bit since the 7800 allows more to be put in each horizontal zone.  Plus the objects will be moving that also draws less attention to the flickering. Also many of my games had 16 sprites at the most on the screen. Delta Space Arena is an exception where it was having 20 sprites on screen at once for the 8-bit, and the 7800 is being tested with 24 sprites. Looking to do a little extra with the 7800 version.
Some games can have sprites going anywhere on the screen, and to have extra logic to check if too many are in a zone can be tedious.
There are a few games in my inventory I still need to figure out how set up on the 7800. Like Surround'Em and Tempest Elite. Those used bitmapped line drawing modes (graphics 7, graphics 15) on the 8-bit. These need 8k RAM or more. Bitmap modes in RAM means you can set any bit/nibble for the pixel to a desired color anywhere on the screen. 7800 4K RAM is a problem I need to work around. One ideal is make a character set with many different line angles in the character tiles. Another ideal is make a low res mode with characters to simulate pixels on or off.
Edited by peteym5, Sat Nov 25, 2017 7:39 AM.
#28 peteym5 OFFLINE
peteym5
  • 2,378 posts
Posted Sat Nov 25, 2017 2:06 PM
Here is a Video showing the latest work in progress for Amok Bots, Delta Space Arena, Laser Blast X, Putt 18, and Venture. It took me awhile to figure out a way to multiplex 8 sprites within a horizontal zone. Keep in mind I am forcing more sprites than usual to one horizontal zone, so for the most part, you will not likely see much flickering with my games ported onto the 7800. Some games have the character set written over several times in the background. This is to test to see how many sprites can be displayed over a background. The Multiplexing manager routine prevents crashes or the graphics becoming corrupted if too many sprites are displayed in the same horizontal zone.
#29 gambler172 OFFLINE
gambler172
  • 3,318 posts
  • none
Posted Sat Nov 25, 2017 6:30 PM
Hi Petey
and when will all these games be available?
greetings Walter
#30 peteym5 OFFLINE
peteym5
  • 2,378 posts
Posted Sat Nov 25, 2017 7:15 PM
I am hoping to get one of the games figured out by the end of the year. We make a little progress everyday experimenting with programming, setting up graphics, new subroutines. I am able to bring over some programming from the games 8-bit counter part involving opponent AI and movements. Also setting up a character/tile mapped screen is similar to what I did on the 8-bit also. What I am currently doing is keeping Delta Space Arena as the first game I develop something for, and if the other games I am working on can use new programming, I copy and paste stuff over.
Now Video61 has an EPROM burner that is attached to an 800XL and need the 6 byte binary header. Anyone know what the start address will be and what I would need to change with a .A78 file to burn a game onto an EPROM?
#31 Jin OFFLINE
Jin
    Solar Striker
  • 3,056 posts
Posted Sun Nov 26, 2017 3:49 AM
Thanks for the update videos, I'll be following this thread like a hawk to observe the progress on Venture. :) It does make me curious how the programmer/s of Robotron 2084 for the 7800 managed to cram dozens upon dozens of sprites on screen at once with no flicker.
#32 Cousin Vinnie OFFLINE
Cousin Vinnie
  • 1,138 posts
Posted Sun Nov 26, 2017 9:09 AM
bravo! keep up the hard work
#33 AtariLeaf ONLINE
AtariLeaf
    Epic Godlike Canadian
  • 11,165 posts
Posted Sun Nov 26, 2017 9:46 AM
There's a couple of games here, maybe three that I would be interested in as physical releases. This is great stuff.
#34 RevEng OFFLINE
RevEng
    Bit Player
  • 5,073 posts
Posted Sun Nov 26, 2017 11:28 AM
For a 32k game, the start address is 0x8000/32768. If this is based on 7800basic, then you just need to burn the BIN file it also produces. The A78 file is identical to the BIN file except it has a 128 byte header tacked on the front, which provides hints to emulators as to what cart hardware (and other hardware) should be emulated.
Not sure about this 6 byte binary header for the 800XL.
#35 peteym5 OFFLINE
peteym5
  • 2,378 posts
Posted Mon Nov 27, 2017 6:29 PM
I put together an animated demo of multi-plexing animated sprites and moving objects in more than 8 directions. This is a non-playable demo to show everyone what I am developing for the games.
There are 2 demos, One with only 24 sprites moving around, Two with 32 sprites moving around. I also notice there is hardly any flickering of sprites needing to be turned off if too many are inside one horizontal zone. I believe the 7800 can get as many as 10 on a single line vs 2 player/missile sprites on the 2600 vs 4 player/missile sprites on the 8-bit/5200. They are also multi-colored and can have various width without stretching them 2x or 4x width. The 5200/8-bit can do mulicolored sprites at the cost of overlaying 2 player sprites on top of each other to make a 3rd color that is the OR value of the 2 player color registers.
I am aware there is some random flickering sprite parts with trying to move 32 objects around.  Probably some sore of limit with the Maria DMA. Most games do not need that many objects moving around.
#36 davidcalgary29 OFFLINE
davidcalgary29
  • 5,970 posts
Posted Tue Nov 28, 2017 11:36 PM
Please tell me that you have plans to port Tempest Elite to the 7800 :).
#37 peteym5 OFFLINE
peteym5
  • 2,378 posts
Posted Sat Dec 2, 2017 5:00 AM
I am considering Tempest game as a future project, but want to do some of the smaller and simpler games first. Doing Tempest on the 7800 and drawing the webs is not easy due to not having bitmapped graphics modes and line drawing. We can look into constructing webs with a tile/character mapped screen, it may end up with some gaps between the web edges and the lane separators, but at least it will be something.
I have quickly made up a PNG file that can make a font to draw lines at many different angles.
Edited by peteym5, Sat Dec 2, 2017 5:54 AM.
#38 Lynxpro OFFLINE
Lynxpro
  • 3,688 posts
Posted Sun Dec 3, 2017 12:29 PM
Mmmm. Tempest Elite....on the 5200.... Like with A8 Space Harrier, do you need a 1MB ROM first in order to make the conversion possible?
#39 Lynxpro OFFLINE
Lynxpro
  • 3,688 posts
Posted Sun Dec 3, 2017 12:30 PM
Because GCC did the port *and* created the 7800.
#40 peteym5 OFFLINE
peteym5
  • 2,378 posts
Posted Sun Dec 3, 2017 1:32 PM
I never ported Tempest to the 5200 since someone already is doing it. I am looking to see what I can do with existing resources on the 7800 and keeping it to a 128K ROM.
#41 Lynxpro OFFLINE
Lynxpro
  • 3,688 posts
Posted Sun Dec 3, 2017 2:15 PM
Really???  Is that an official answer that *someone* IS actively porting it to the 5200 right as we speak? I'd love to report that back to the 5200 group on Facebook if that's 100 mo-cent correct.
I hope the port fully uses the CX53 Trak-Ball Controller like Keithen Hayenga's 5200 Tempest did. If so, Dan Kramer will be over the moon about that.
And...there are those on the 5200 that would also love if the A8 option to use a 2600 Driving Controller was preserved in the port. Sure, an adapter is necessary but those MasterPlay clones are popular in 5200Land.
#42 peteym5 OFFLINE
peteym5
  • 2,378 posts
Posted Sun Dec 3, 2017 3:24 PM
The 5200 Tempest is not even my program. Some people took the original program that Atari started many years ago and managed to finish it.  I holding off on porting Tempest Xtreme/Tempest Elite because the 5200 also has restricted RAM availability. We are also waiting word on larger bank switching cartridges before making a decision to go forward.
Anyway, I am not sure the 2600 Driving Controller can be hooked up to the 5200, because the 5200 controller port has a different number of pins and use 2 analog values for the position of the joystick.  The 7800 can do Paddles, Driving Controller, and Trackball just like the 8-bit.
#43 peteym5 OFFLINE
peteym5
  • 2,378 posts
Posted Wed Dec 6, 2017 11:37 AM
Here is a work in progress pics from Delta Space Arena development. I am working on the sections that do "Procedural Screen Set Ups" that set up the screen from a series of instructions. Like draw a horizontal like at (4,8) of 5 characters with character #10. Can compact many screens into a short piece of data around 30 to 40 bytes instead of trying to save screens that are  over 1000 bytes. Thats how I get hundreds of screens stored on cartridges 16K to 128K in size.
Data looks like this....
ARENA03
   .byte HLN+SET,10,16,9,10, HLN,16,15,10, VLN+SET,2,15,10,5, VLN,25,10,5, CHR,15,9,1, CHR,25,9,1, CHR,15,15,1, CHR,25,15,1, CHR,15,12,3, CHR,25,12,3,   0
ARENA04
   .byte HLN+SET,10,10,7,5, HLN,10,9,21, HLN,10,15,21, HLN,10,17,5,  HLN,26,7,5, HLN,26,17,5,  VLN+SET,2,15,8,9,  VLN,25,8,9
   .byte CHR,15,12,3, CHR,25,12,3, CHR,10,8,3, CHR,10,16,3, CHR,30,8,3, CHR,30,16,3, CHR,10,7,1, CHR,15,7,1,  CHR,25,7,1, CHR,30,7,1
   .byte CHR,10,9,1, CHR,15,9,1,  CHR,25,9,1, CHR,30,9,1, CHR,10,15,1, CHR,15,15,1,  CHR,25,15,1, CHR,30,15,1
   .byte CHR,10,17,1, CHR,15,17,1,  CHR,25,17,1, CHR,30,17,1, 0
#44 Inky OFFLINE
Inky
    Gobs of money!
  • 25,787 posts
  • Meh
Posted Wed Dec 6, 2017 1:03 PM
https://atariage.com...t_detail&p=1036
#45 scobb OFFLINE
scobb
    Moonsweeper
  • 333 posts
Posted Wed Dec 6, 2017 9:43 PM
This is great news - thanks!
Scott
#46 peteym5 OFFLINE
peteym5
  • 2,378 posts
Posted Thu Dec 7, 2017 6:59 AM
That 5200 Tempest is made by different programmers and I have no connection to. Sold through the AtariAge store, not from Video61 and AtariSales. Tempest Xtreme and Tempest Elite was constructed from scratch. I have not even started anything for Tempest 7800 yet.
#47 DrSidneyZweibel OFFLINE
DrSidneyZweibel
    Dragonstomper
  • 507 posts
Posted Thu Dec 7, 2017 8:28 AM
I'd like to know more about the 7800 Venture port. any other screenshots for that besides the title screen (which looks great).
#48 peteym5 OFFLINE
peteym5
  • 2,378 posts
Posted Thu Dec 7, 2017 9:22 AM
I just started porting the data Venture programming needs to draw each screen.  Currently I am working on the procedure to draw tile (aka graphic characters) based screens that are made up of little images. Each image as a value, (0 being blank space, 1 red square, 2 brick wall, 3 lower rectangle, etc) and this procedure draws screens based on data. [Draw a series of the brick image starting at 5,5 and make it 5 images wide] I have used this frequently on the 8-bit and working on a standardized way of doing it on the 7800 across several games. Putt 18 Miniature Golf also draws the screens for each hole using this method also.
  • Jin likes this
#49 Jinks ONLINE
Jinks
  • 4,532 posts
Posted Thu Dec 7, 2017 6:30 PM
Ya know how arcade venture zooms in each room once accessed. That would be fn stellar if the 7800 version did that.
Probably that feature alone would make it the best console version ever.
#50 peteym5 OFFLINE
peteym5
  • 2,378 posts
Posted Fri Dec 8, 2017 11:35 AM
Here is an early WIP pic of Venture screen. Did draw the border that will be used in the map rooms.  I am undecided about using 160 multicolored sprites, or switch to 320 higher-res sprites, but mono-colored.
