+TheBF Posted November 20, 2017 Share Posted November 20, 2017 (edited) Will reviewing a site that had Forth running in a browser I found the source code for the snake game. I thought it be it useful for people learning Forth so I modified it to run on the TI-99 and added some features. This game can be pasted into CAMEL99 Forth. Download the current program in EA5 format file here: https://github.com/bfox9900/CAMEL99/blob/master/bin/CAMEL99 Run the CAMEL99 program and then paste the source code from the spoiler below into the Classic99 emulator window and type RUN <enter> For Turbo Forth and FB Forth users, it would not be a very difficult job to port it over but there might be a few questions that I am sure Mark, Lee or myself would be happy to respond to. (Note: CAMEL99 uses TI BASIC color values so they are off by 1 for FB-Forth and Turbo Forth) \ snake a simple game in Forth ported to CAMEL99 Forth \ DERIVED FROM: https://skilldrick.github.io/easyforth/#snake \ revised to use CAMEL99/TI-99 features HEX 83C0 CONSTANT SEED \ RAM where TI has a number incrementing in main menu 1045 CONSTANT GEN# \ GForth uses $10450405, we take the 1st 16 bits : RNDW ( -- n ) SEED @ GEN# UM* DROP 1+ DUP SEED ! ; \ : RANDOMIZE ( n -- ) SEED ! ; : RND ( n -- n') RNDW ABS SWAP MOD ; DECIMAL 500 CONSTANT MAXLENGTH \ x/y coordinate storage for the snake CREATE SNAKE-X-HEAD MAXLENGTH CELLS ALLOT CREATE SNAKE-Y-HEAD MAXLENGTH CELLS ALLOT VARIABLE SPEED VARIABLE PREY-X VARIABLE PREY-Y VARIABLE DIRECTION VARIABLE LENGTH 0 CONSTANT LEFT 1 CONSTANT UP 2 CONSTANT RIGHT 3 CONSTANT DOWN \ characters used 128 CONSTANT PREY 42 CONSTANT SNAKE 30 CONSTANT BRICK \ shape data for PREY, brick and snake chars HEX CREATE CLAY 007E , 6A56 , 6A56 , 7E00 , CREATE VIPER 3C5E , EBF7 , EBDD , 7E3C , CREATE MOUSE 0004 , 3E7B , 7FFC , 8070 , DECIMAL \ get random x or y position within playable area : RANDOM-X ( -- n ) C/L@ 2- RND 1+ ; : RANDOM-Y ( -- n ) L/SCR 2- RND 1+ ; \ create snake coordiinate arrays : ]SNAKE-X ( index -- address ) CELLS SNAKE-X-HEAD + ; : ]SNAKE-Y ( index -- address ) CELLS SNAKE-Y-HEAD + ; : DRAW ( char X Y -- ) >VPOS VC! ; : DRAW-WHITE ( x y -- ) BL -ROT DRAW ; : DRAW-SNAKE ( X Y -- ) SNAKE -ROT DRAW ; : DRAW-BRICK ( X Y -- ) BRICK -ROT DRAW ; : DRAW-PREY ( -- ) PREY PREY-X @ PREY-Y @ DRAW ; : DRAW-WALLS 0 0 BRICK 31 HCHAR 0 1 BRICK 22 VCHAR 31 0 BRICK 24 VCHAR 0 23 BRICK 31 HCHAR ; : DRAW-SNAKE LENGTH @ 0 DO I ]SNAKE-X @ I ]SNAKE-Y @ DRAW-SNAKE LOOP LENGTH @ ]SNAKE-X @ LENGTH @ ]SNAKE-Y @ DRAW-WHITE ; : INITIALIZE-SNAKE 4 DUP LENGTH ! 1+ 0 DO 12 I - I ]SNAKE-X ! 12 I ]SNAKE-Y ! LOOP RIGHT DIRECTION ! ; : PLACE-PREY ( y x -- ) PREY-X ! PREY-Y ! ; : MOVE-UP ( -- ) -1 SNAKE-Y-HEAD +! ; : MOVE-LEFT ( -- ) -1 SNAKE-X-HEAD +! ; : MOVE-DOWN ( -- ) 1 SNAKE-Y-HEAD +! ; : MOVE-RIGHT ( -- ) 1 SNAKE-X-HEAD +! ; : MOVE-SNAKE-HEAD ( -- ) DIRECTION @ LEFT OVER = IF MOVE-LEFT ELSE UP OVER = IF MOVE-UP ELSE RIGHT OVER = IF MOVE-RIGHT ELSE DOWN OVER = IF MOVE-DOWN THEN THEN THEN THEN DROP ; \ move each segment of the snake forward by one : MOVE-SNAKE-TAIL 0 LENGTH @ DO I ]SNAKE-X @ I 1+ ]SNAKE-X ! I ]SNAKE-Y @ I 1+ ]SNAKE-Y ! -1 +LOOP ; : MOVE-SNAKE ( -- ) MOVE-SNAKE-TAIL MOVE-SNAKE-HEAD ; : HORIZONTAL? ( -- ?) DIRECTION @ DUP LEFT = SWAP RIGHT = OR ; : VERTICAL? ( -- ?) DIRECTION @ DUP UP = SWAP DOWN = OR ; : TURN-UP HORIZONTAL? IF UP DIRECTION ! THEN ; : TURN-LEFT VERTICAL? IF LEFT DIRECTION ! THEN ; : TURN-DOWN HORIZONTAL? IF DOWN DIRECTION ! THEN ; : TURN-RIGHT VERTICAL? IF RIGHT DIRECTION ! THEN ; : CHANGE-DIRECTION ( key -- ) [CHAR] S OVER = IF TURN-LEFT ELSE [CHAR] E OVER = IF TURN-UP ELSE [CHAR] D OVER = IF TURN-RIGHT ELSE [CHAR] X OVER = IF TURN-DOWN THEN THEN THEN THEN DROP ; \ read key is also the delay loop since KSCAN takes 1.1 mS \ much more responsive to keys than a delay loop : READ-KEY ( -- char | 0) 0 \ false flag SPEED @ 0 DO KEY? IF NIP KVAL C@ LEAVE THEN LOOP ; : CHECK-INPUT ( -- ) READ-KEY CHANGE-DIRECTION ; : NEW-PREY PREY-X @ PREY-Y @ DRAW-WHITE RANDOM-Y RANDOM-X PLACE-PREY DRAW-PREY ; : GROW-SNAKE ( -- ) 1 LENGTH +! ; : DEAD-SNAKE ( -- ) [ SNAKE SET# ] LITERAL DUP 4 1 COLOR 250 MS 2 1 COLOR ; : HAPPY-SNAKE ( -- ) [ SNAKE SET# ] LITERAL 12 4 DO DUP I 1 COLOR 40 MS LOOP ( -- 5) 3 1 COLOR ; : SCARED-PREY ( -- ) [ PREY SET# ] LITERAL DUP 16 1 COLOR BEEP 2 1 COLOR ; : FASTER SPEED @ 10 - 10 MAX SPEED ! ; : CHECK-PREY SNAKE-X-HEAD @ PREY-X @ = SNAKE-Y-HEAD @ PREY-Y @ = AND IF SCARED-PREY HAPPY-SNAKE GROW-SNAKE FASTER NEW-PREY THEN ; : COLLISION? ( -- ? ) SNAKE-X-HEAD @ SNAKE-Y-HEAD @ >VPOS VC@ DUP BRICK = SWAP SNAKE = OR ; \ utility words for menus : WAIT-KEY BEGIN KEY? UNTIL ; : AT" POSTPONE AT-XY POSTPONE ." ; IMMEDIATE : INITIALIZE PAGE 15 SCREEN MOUSE PREY CHARDEF [ PREY SET# ] LITERAL 2 1 COLOR CLAY BRICK CHARDEF [ BRICK SET# ] LITERAL 9 1 COLOR VIPER SNAKE CHARDEF [ SNAKE SET# ] LITERAL 3 1 COLOR DRAW-WALLS INITIALIZE-SNAKE RANDOM-Y RANDOM-X PLACE-PREY 200 SPEED ! ; : PLAY ( -- ) BEGIN DRAW-SNAKE DRAW-PREY CHECK-INPUT MOVE-SNAKE CHECK-PREY COLLISION? UNTIL HONK 12 10 AT" GAME OVER" HONK DEAD-SNAKE ; DECIMAL : TITLE ( -- ) GRAPHICS 5 5 AT" THE SNAKE" 5 7 AT" Use the E,S,D,X keys" 5 8 AT" to move the snake 5 9 AT" and catch the mouse." 5 12 AT" The more he eats, 5 13 AT" the faster he goes!" 5 20 AT" Press any key to begin..." WAIT-KEY ; : RUN ( -- ) TITLE BEGIN INITIALIZE PLAY 5 13 AT" Your snake was " LENGTH ? ." Ft. long" 5 15 AT" Press ENTER to play again" KEY 13 <> UNTIL 8 20 AT" SSSSSee you later!" 1500 MS CR QUIT ; Edited November 20, 2017 by TheBF Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted November 20, 2017 Share Posted November 20, 2017 Cool little game 1 Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted November 20, 2017 Share Posted November 20, 2017 There is already a "snake" demo in TurboForth. It could be turned into a game quite easily. Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted November 21, 2017 Share Posted November 21, 2017 I will port it to fbForth 2.0 in a day or two—but, first I must fix a bug in fbForth 2.0 that I introduced to some of the sprite primitives, probably as far back as fbForth 2.0:8. I will detail the bug and its fix on my website and in the fbForth development thread by tomorrow’s end. ...lee 1 Quote Link to comment Share on other sites More sharing options...
Willsy Posted November 21, 2017 Share Posted November 21, 2017 I will port it to fbForth 2.0 in a day or twobut, first I must fix a bug in fbForth 2.0 that I introduced to some of the sprite primitives, probably as far back as fbForth 2.0:8. I will detail the bug and its fix on my website and in the fbForth development thread by tomorrows end. ...lee Bugs in cartridge software is such a pain in the ass, eh?! 2 Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted November 21, 2017 Share Posted November 21, 2017 Do I detect another build in the works? Quote Link to comment Share on other sites More sharing options...
+TheBF Posted November 21, 2017 Author Share Posted November 21, 2017 I will port it to fbForth 2.0 in a day or two—but, first I must fix a bug in fbForth 2.0 that I introduced to some of the sprite primitives, probably as far back as fbForth 2.0:8. I will detail the bug and its fix on my website and in the fbForth development thread by tomorrow’s end. ...lee If debugging is the art of removing bugs, then programming must be the art of putting bugs in. :-) It's a humbling activity, this. B 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted December 9, 2017 Author Share Posted December 9, 2017 A new version of the SNAKE with sound enhancements I have been playing with methods to do sound control without using interrupts and sound lists. I think I am getting somewhere. The spoiler has the new version with sounds. I added scraping as the snake slides, a squeak when the mouse gets eaten and nice swoosh when a new mouse materializes. I will explain the sound control words in another topic. (I have not got past 50 segments of snake length playing this myself.) \ snake a simple game in Forth ported to CAMEL99 Forth \ DERIVED FROM: https://skilldrick.github.io/easyforth/#snake \ revised to use CAMEL99/TI-99 features \ \\\\\\\\\\\ Version 3 \\\\\\\\\\\\\\\\ \ \\ snake sounds and mouse squeak \\\\\ HEX 83C0 CONSTANT SEED \ RAM where TI has a number incrementing in main menu 1045 CONSTANT GEN# \ GForth uses $10450405, we take the 1st 16 bits : RNDW ( -- n ) SEED @ GEN# UM* DROP 1+ DUP SEED ! ; : RND ( n -- n') RNDW ABS SWAP MOD ; \ ======================================= \ We use direct control of the sound chip \ rather than sound lists and a player. \ noise control words : NOISE ( n -- ) E0 OR SND! ; \ n selects the noise type \ noise envelope control : NOISE-DB ( db --) F MIN F0 OR SND! ; : NOISE-OFF ( -- ) F NOISE-DB ; : NOISE-DOWN ( speed -- ) F 2 DO I NOISE-DB DUP MS LOOP DROP NOISE-OFF ; : NOISE-UP ( speed -- ) 2 F DO I NOISE-DB DUP MS -1 +LOOP DROP ; \ channel 1 sound control words DECIMAL : f(clk) ( -- d) 46324 1 ; \ this is 111,860 as 32 bit int. \ >FCODE re-arranges freq. value nibbles (4bits) for the TMS9919 HEX : >FCODE ( 0abc -- 0cab) \ ASM would make this much faster DUP 0F AND SWAP ( -- 000c 0abc) 4 RSHIFT ( -- 000c 00ab) SWAP >< ( SWPB) ( -- 00ab 0c00) + ; : HZ>CODE ( freq -- fcode ) f(clk) ROT UM/MOD NIP >FCODE 8000 OR ; \ *TRICKY STUFF* \ Calculating the 9919 freq. code takes too long BUT we can convert frequency \ to 9919 chip code at compile time then compile as 16 bit literal number \ using this text MACRO : [HZ] ( freq -- fcode ) S" HZ>CODE ] LITERAL" EVALUATE ; \ sound channel #1 control words : FREQ! ( fcode -- ) SPLIT SND! SND! ; : ]HZ ( freq -- ) [HZ] POSTPONE FREQ! ; \ pre-compiled fcode version : HZ ( freq -- ) HZ>CODE SPLIT SND! SND! ; \ runtime calculation version : DB ( n -- ) 90 OR SND! ; : MUTE ( -- ) 9F SND! ; DECIMAL 500 CONSTANT MAXLENGTH \ x/y coordinate storage for the snake CREATE SNAKE-X-HEAD MAXLENGTH CELLS ALLOT CREATE SNAKE-Y-HEAD MAXLENGTH CELLS ALLOT VARIABLE SPEED VARIABLE PREY-X VARIABLE PREY-Y VARIABLE DIRECTION VARIABLE LENGTH 0 CONSTANT LEFT 1 CONSTANT UP 2 CONSTANT RIGHT 3 CONSTANT DOWN \ characters used 128 CONSTANT PREY 42 CONSTANT SNAKE 30 CONSTANT BRICK BL CONSTANT WHITE \ shape data for PREY, brick and snake chars HEX CREATE CLAY 007E , 6A56 , 6A56 , 7E00 , CREATE VIPER 3C5E , EBF7 , EBDD , 7E3C , CREATE MOUSE 0004 , 3E7B , 7FFC , 8070 , DECIMAL \ get random x or y position within playable area : RANDOM-X ( -- n ) C/L@ 2- RND 1+ ; : RANDOM-Y ( -- n ) L/SCR 2- RND 1+ ; \ create snake coordiinate arrays : ]SNAKE-X ( index -- address ) CELLS SNAKE-X-HEAD + ; : ]SNAKE-Y ( index -- address ) CELLS SNAKE-Y-HEAD + ; : DRAW ( char X Y -- ) >VPOS VC! ; : DRAW-WHITE ( x y -- ) BL -ROT DRAW ; : DRAW-SNAKE ( X Y -- ) SNAKE -ROT DRAW ; : DRAW-PREY ( -- ) PREY PREY-X @ PREY-Y @ DRAW ; : DRAW-WALLS 0 0 BRICK 31 HCHAR 0 1 BRICK 22 VCHAR 31 0 BRICK 24 VCHAR 0 23 BRICK 31 HCHAR ; : DRAW-SNAKE LENGTH @ 0 DO I ]SNAKE-X @ I ]SNAKE-Y @ DRAW-SNAKE LOOP LENGTH @ ]SNAKE-X @ LENGTH @ ]SNAKE-Y @ DRAW-WHITE ; : INITIALIZE-SNAKE 4 DUP LENGTH ! 1+ 0 DO 12 I - I ]SNAKE-X ! 12 I ]SNAKE-Y ! LOOP RIGHT DIRECTION ! ; : PLACE-PREY ( y x -- ) PREY-X ! PREY-Y ! ; : MOVE-UP ( -- ) -1 SNAKE-Y-HEAD +! ; : MOVE-LEFT ( -- ) -1 SNAKE-X-HEAD +! ; : MOVE-DOWN ( -- ) 1 SNAKE-Y-HEAD +! ; : MOVE-RIGHT ( -- ) 1 SNAKE-X-HEAD +! ; : MOVE-SNAKE-HEAD ( -- ) DIRECTION @ LEFT OVER = IF MOVE-LEFT ELSE UP OVER = IF MOVE-UP ELSE RIGHT OVER = IF MOVE-RIGHT ELSE DOWN OVER = IF MOVE-DOWN THEN THEN THEN THEN DROP ; \ move each segment of the snake forward by one HEX : MOVE-SNAKE-TAIL 0 LENGTH @ DO I ]SNAKE-X @ I 1+ ]SNAKE-X ! I ]SNAKE-Y @ I 1+ ]SNAKE-Y ! -1 +LOOP ; : MOVE-SNAKE ( -- ) 4 NOISE B NOISE-DB \ soft white noise MOVE-SNAKE-TAIL 9 NOISE-DB MOVE-SNAKE-HEAD D NOISE-DB NOISE-OFF ; DECIMAL : HORIZONTAL? ( -- ?) DIRECTION @ DUP LEFT = SWAP RIGHT = OR ; : VERTICAL? ( -- ?) DIRECTION @ DUP UP = SWAP DOWN = OR ; : TURN-UP HORIZONTAL? IF UP DIRECTION ! THEN ; : TURN-LEFT VERTICAL? IF LEFT DIRECTION ! THEN ; : TURN-DOWN HORIZONTAL? IF DOWN DIRECTION ! THEN ; : TURN-RIGHT VERTICAL? IF RIGHT DIRECTION ! THEN ; : CHANGE-DIRECTION ( key -- ) [CHAR] S OVER = IF TURN-LEFT ELSE [CHAR] E OVER = IF TURN-UP ELSE [CHAR] D OVER = IF TURN-RIGHT ELSE [CHAR] X OVER = IF TURN-DOWN THEN THEN THEN THEN DROP ; \ read key is also the delay loop since KSCAN takes 1.1 mS \ much more responsive to keys than a delay loop : READ-KEY ( -- char | 0) 0 \ false flag SPEED @ 0 DO KEY? IF NIP KVAL C@ LEAVE THEN LOOP ; : CHECK-INPUT ( -- ) READ-KEY CHANGE-DIRECTION ; : SWOOSH ( -- ) NOISE-OFF 5 NOISE 8 NOISE-UP 20 NOISE-DOWN ; : NEW-PREY SWOOSH PREY-X @ PREY-Y @ DRAW-WHITE RANDOM-Y RANDOM-X PLACE-PREY DRAW-PREY ; : GROW-SNAKE ( -- ) 1 LENGTH +! ; : DEAD-SNAKE ( -- ) NOISE-OFF [ SNAKE SET# ] LITERAL DUP 11 1 COLOR 250 MS 2 1 COLOR ; : HAPPY-SNAKE ( -- ) [ SNAKE SET# ] LITERAL 12 4 DO DUP I 1 COLOR 40 MS LOOP ( -- 5) 11 1 COLOR ; DECIMAL : SQUEAK ( -- ) NOISE-OFF [ 3300 ]HZ 0 DB 20 MS \ pre-computed freq. version is faster [ 2800 ]HZ 45 MS [ 2200 ]HZ 20 MS MUTE ; DECIMAL : SCARED-PREY ( -- ) [ PREY SET# ] LITERAL DUP 16 1 COLOR SQUEAK 2 1 COLOR ; : FASTER SPEED @ 5 - 5 MAX SPEED ! ; : CHECK-PREY SNAKE-X-HEAD @ PREY-X @ = SNAKE-Y-HEAD @ PREY-Y @ = AND IF SCARED-PREY HAPPY-SNAKE GROW-SNAKE FASTER NEW-PREY THEN ; : COLLISION? ( -- ? ) SNAKE-X-HEAD @ SNAKE-Y-HEAD @ >VPOS VC@ DUP BRICK = SWAP SNAKE = OR ; \ utility words for menus : WAIT-KEY BEGIN KEY? UNTIL ; : AT" POSTPONE AT-XY POSTPONE ." ; IMMEDIATE : INITIALIZE PAGE 4 SCREEN MOUSE PREY CHARDEF [ PREY SET# ] LITERAL 2 1 COLOR CLAY BRICK CHARDEF [ BRICK SET# ] LITERAL 9 1 COLOR VIPER SNAKE CHARDEF [ SNAKE SET# ] LITERAL 11 1 COLOR DRAW-WALLS INITIALIZE-SNAKE RANDOM-Y RANDOM-X PLACE-PREY 200 SPEED ! ; : PLAY ( -- ) BEGIN DRAW-SNAKE DRAW-PREY CHECK-INPUT MOVE-SNAKE CHECK-PREY COLLISION? UNTIL HONK 12 10 AT" GAME OVER" HONK DEAD-SNAKE ; DECIMAL : TITLE ( -- ) GRAPHICS 5 5 AT" THE SNAKE" 5 7 AT" Use the E,S,D,X keys" 5 8 AT" to move the snake 5 9 AT" and catch the mouse." 5 12 AT" The more he eats, 5 13 AT" the faster he goes!" 5 20 AT" Press any key to begin..." WAIT-KEY ; : RUN ( -- ) TITLE BEGIN INITIALIZE PLAY 5 13 AT" Your snake was " LENGTH ? ." Ft. long" 5 15 AT" Press ENTER to play again" KEY 13 <> UNTIL NOISE-OFF 8 20 AT" SSSSSee you later!" 1500 MS CLEAR ; 1 Quote Link to comment Share on other sites More sharing options...
