Super Cobra Arcade
50 replies to this topic
#1 johnnywc OFFLINE
johnnywc
  • 2,008 posts
Posted Thu Nov 30, 2017 5:20 PM
Hello all,
As promised, here is the ROM for Super Cobra Arcade (both NTSC and PAL60).  If you enjoy the game and would like to purchase a full copy, please visit the Atari Age store for more details.  As always, the support is greatly appreciated!
OBJECT
The object of Super Cobra Arcade is to pilot your helicopter and traverse 10,000 miles (10 stages), avoiding or destroying numerous obstacles (tanks, rockets, UFOs, meteors, guided missiles, mines, etc.).  At the end of 10,000 miles, your mission is to capture the 'booty' (money) and carry it safely away from the enemy base.
OPTIONS
There are 4 difficulty levels: NOVICE, STANDARD, ADVANCED and EXPERT.  Move the joystick left/right to select the desired difficulty or press SELECT.  Push the joystick up or down to cycle through the different screens (title screen, score table and high scores).  Press RESET or the fire button to start a game.
CONTROL
Use the joystick controller to move your helicopter.  Press the fire button to simultaneously fire missiles (up to 3 at a time) and drop bombs (up to 2 at a time).  If the left difficultly switch is set to B (burst mode), you can hold down the button to fire up to 5 shots (3 missiles and 2 bombs).  Release and press again to fire up to 5 more shots.  If the left difficulty is in the A position, this is single shot mode (will fire up to 1 bullet and 1 bomb at a time).
2-button mode:  If you have a Sega Genesis game pad connected to the left controller port when you power on the game, the message "GAMEPAD FOUND" will be displayed briefly on the Atari Age welcome screen.  In 2-button mode, push the B button to fire missiles and the C button to drop bombs.
GAME PLAY
You start the game with 3 - 5 ships, depending on the skill level.  You earn a bonus ship at 10,000 points, 50,000 points, and every 50,000 points after that.  You also earn a bonus ship for successfully capturing the booty and carrying it to safety.
Maneuver your helicopter through the winding caverns, avoiding or destroying the enemy obstacles.  While travelling through the terrain, your ship will use precious fuel.  To replenish your supply, seek out and destroy the fuel depots.  If you run out of fuel, your helicopter will crash and you will lose a life.
  • Rockets: fire up towards your ship.  Some rockets move much quicker than others.
  • Tanks: stationary and fire bullets at your helicopter
  • Guided missiles: launch in an arcing pattern towards your ship.  Be careful; on higher difficulty levels they will 'wrap-around' the side of the screen and appear on the other side.
  • Spinning drones: Move in swirling patterns before attacking your ship.
  • Falling mines: Drop from the cavern ceiling towards your ship.
  • Roaming tanks: Move along the terrain to avoid bombs while firing bullets at your ship.
  • Meteors: Move very fast towards your ship.  They cannot be destroyed and therefore must be avoided.
  • Shadow meteors:  Similar to meteors except they 'follow' your ship.  Unlike meteors, they can be destroyed if hit 4 times.
  • UFOs:  Move in unpredictable patterns trying to ram your chopper.  On later levels, they will also fire missiles that must be avoided.
  • Maze: Navigate the tight corners of the maze while destroying fuel and avoiding rockets and tank fire.
  • Base: Once you have successfully navigated the maze, you will need to invade the enemy's base and capture the booty ($).  To do so, destroy or avoid the enemy installations and swoop down towards the booty.  Pick up the booty by 'touching' it with your helicopter and then quickly carry it up over the mountain side away to safety.  If you accidentally destroy the booty or are killed by the enemy while carrying the booty, a message will be displayed saying the you must start the base stage over and try again.
Each stage of 1,000 miles has 1 or more 'checkpoints'.  On the novice level, a faint beep is played when a new checkpoint is reached.  For every 1,000 miles traveled, a brief message is displayed marking your accomplishment.  If your ship is destroyed and you have a reserve ship, you will start at the beginning of the last checkpoint.
GAME OVER
The game ends when all ships have been destroyed and there are no more in reserve.  When the Game Over screen is displayed, you will also be presented with a option to continue the current game.  To continue a game, press the fire button before the 10 second timer expires.  The game will then continue beginning of the last stage from the previous game (not that last checkpoint) for the current level (# of bootys captured), with the score reset to 0.  You are allowed up to 5 continues.  To start a new game, you can either press RESET from the GAME OVER screen or simply wait for the game to return to the title screen after the timer has expired and then press the button or RESET.
HIGH SCORES
If the score you obtained in your game exceeds the lowest score from the high score table (top 10) for the current skill level, the HIGH SCORE table will be displayed prior to starting
If your score is greater than one of the top 10 scores for the current skill level, the high score screen will be displayed and your current score will be displayed in WHITE.
The high score table displays the top 10 scores for the current skill level.  If there is a Savekey or Atarivox plugged in the right controller port, up to 10 scores for each of the 4 levels are saved and restored.  To reset the high score table for the current skill level, press and hold the RESET button then press SELECT, then simultaneously release both buttons.  All scores will be reset to 10,000.
Have fun!
John
#2 Kosmic Stardust OFFLINE
Kosmic Stardust
    Princess Rescuer
  • 18,298 posts
Posted Thu Nov 30, 2017 9:20 PM
Thanks again for the ROM. I did download it but I got my game on preorder from the AA store so I'll be saving them for Christmas. I won't spoil it for myself. ;-)
#3 Protestari OFFLINE
Protestari
    Dragonstomper
  • 879 posts
Posted Thu Nov 30, 2017 9:28 PM
Thanks so much :)
#4 sramirez2008 OFFLINE
sramirez2008
  • 2,676 posts
  • Stella Foreva
Posted Thu Nov 30, 2017 10:24 PM
Thanks for the ROM and thanks again for signing my copy at PRGE.
#5 SoundGammon OFFLINE
SoundGammon
  • 1,359 posts
Posted Fri Dec 1, 2017 12:11 AM
Can't get it to work on Stella. Only on Melody?
#6 DirtyHairy OFFLINE
DirtyHairy
    Moonsweeper
  • 490 posts
Posted Fri Dec 1, 2017 12:54 AM
You need a recent version of Stella. Stella 5.0.2 works fine, as does 6502.ts/Stellerator (see my sig).
#7 Steel76 OFFLINE
Steel76
    Star Raider
  • 67 posts
Posted Fri Dec 1, 2017 3:56 AM
Thanks for the ROM.
This is AMAZING!
I can't wait for my cart to arrive :)
Great job!
#8 H.E.R.O. OFFLINE
H.E.R.O.
    Moonsweeper
  • 357 posts
  • New leader of the Bungeling Empire
Posted Fri Dec 1, 2017 4:15 AM
Thanks Johnny. For this & for all your games going back to the DOS days.
#9 stephena OFFLINE
stephena
  • 3,334 posts
  • Stella maintainer
Posted Fri Dec 1, 2017 8:50 AM
Hello all,
Please provide the following info, so I can get the ROM properties updated for Stella, and have it in the next (upcoming) release.  Note that this is the entry for "Lady Bug", so I assume the info will follow the same pattern:
"Cartridge.MD5" "adfbd2e8a38f96e03751717f7422851d"
"Cartridge.Manufacturer" "Champ Games"
"Cartridge.ModelNo" "CG-01-N"
"Cartridge.Name" "Lady Bug (NTSC)"
"Cartridge.Rarity" "Homebrew"
"Console.RightDifficulty" "A"
"Display.Phosphor" "YES"
#10 atarifan88 OFFLINE
atarifan88
    Dragonstomper
  • 941 posts
  • Enjoying 8 bit gaming in HD!
Posted Fri Dec 1, 2017 11:00 AM
You had me at "your mission is to capture the 'booty'!"  :lol:  Thanks for sharing the ROM!
#11 johnnywc OFFLINE
johnnywc
  • 2,008 posts
Posted Fri Dec 1, 2017 11:29 AM
Hi Stephen,
Here is the Stella info for Super Cobra Arcade (NTSC & PAL):
"Cartridge.ModelNo" "CG-04-N"
"Cartridge.Name" "Super Cobra Arcade (NTSC)"
"Display.Phosphor" "NO"
"Cartridge.ModelNo" "CG-04-P"
"Cartridge.Name" "Super Cobra Arcade (PAL60)"
I thought there was something I added for Scramble that said it supported 2-button Genesis gamepad (I don't recall the Stella property); could you add the same for Super Cobra Arcade?
Thanks!
John
#12 stephena OFFLINE
stephena
  • 3,334 posts
  • Stella maintainer
Posted Fri Dec 1, 2017 1:07 PM
OK, I'm about to add this in a moment.  I added a note about Genesis controller (just like with Scramble), but do not enable it by default.  I also turned on phosphor, since this ROM is using 30Hz flicker.
#13 johnnywc OFFLINE
johnnywc
  • 2,008 posts
Posted Fri Dec 1, 2017 1:46 PM
Sounds good!  I'm not sure about the phosphor; if we set it to enabled by default for Scramble then it should be consistent for Super Cobra.  Personally I play it on Stella with phosphor off since the scrolling looks better with it disabled IMO.
Thanks!
John
#14 AW127 OFFLINE
AW127
    Moonsweeper
  • 333 posts
Posted Fri Dec 1, 2017 2:04 PM
WOW, Thanks for the good game and especially for the PAL60 version. :thumbsup:
#15 save2600 OFFLINE
save2600
  • 15,372 posts
Posted Fri Dec 1, 2017 4:35 PM
Still waiting for my copy from the AA Store to show up, so was nice to be able to play the game just now via the Harmony cart. Congrats on another brilliant release and thank you for the ROM! :love:
#16 Rom Hunter ONLINE
Rom Hunter
    VCS Games Archivist
  • 8,953 posts
  • Obtainer of Rare Antiquities
Posted Fri Dec 1, 2017 4:39 PM
My God, it's even better than Scramble.
What a superb game.
Thanks for sharing this masterpiece, John!
8)
#17 Nathan Strum OFFLINE
Nathan Strum
  • 8,263 posts
  • Enjoying a sandwich
Posted Fri Dec 1, 2017 4:53 PM
If you want a real shock... play this back-to-back with Parker Bros.' version. :D
#18 save2600 OFFLINE
save2600
  • 15,372 posts
Posted Fri Dec 1, 2017 5:22 PM
I just did. Nearly completed the game, but sheer boredom took hold and turned it off. I was getting especially irritated by the fact that your bombs and missiles alternate when firing. Missed a lot of targets trying to play it "cool" and picking off shots, but doesn't work that way. lol
That said, I really think and always thought Parker Bros. version of the game was/is pretty good for what it is. Especially for the time, but John's version simply wastes it in every respect. So much so, don't think I'll ever play the original again. :)
-edit-
And yes... I'll have some more free time this winter, so plan on playing more and promise to submit some reviews - I swear! :lol:
#19 SpiceWare OFFLINE
SpiceWare
    Draconian
  • 12,553 posts
  • Medieval Mayhem
Posted Fri Dec 1, 2017 5:31 PM
A great way to say thanks is to add your reviews.  Same goes for other games ;)
#20 Tarzilla OFFLINE
Tarzilla
  • 2,100 posts
  • Huh?
Posted Fri Dec 1, 2017 5:35 PM
Doh! Can you fix the mis-spelling in mine?
zones just the the arcade
should be:
zones just like the arcade
#21 Albert OFFLINE
Albert
  • 35,109 posts
Posted Fri Dec 1, 2017 5:37 PM
should be:
Not sure what you mean, looks okay to me.   :ponder:
 ..Al
#22 Tarzilla OFFLINE
Tarzilla
  • 2,100 posts
  • Huh?
Posted Fri Dec 1, 2017 5:43 PM
 ..Al
  :lolblue:   :thumbsup:
#23 Swami OFFLINE
Swami
  • 2,492 posts
Posted Fri Dec 1, 2017 9:54 PM
Thank you!
#24 H.E.R.O. OFFLINE
H.E.R.O.
    Moonsweeper
  • 357 posts
Posted Sat Dec 2, 2017 3:59 AM
Well, upgrading Stella on PC worked for me (apparently wasn't on the latest version) but doesn't work with either Atari 2600 emulator on Android (2600 emu or Retroarch) so no Cobra-in' on the go for now.
I played it for an hour yesterday and COULD NOT STOP it was so good. Thanks again, Johnny.
#25 Thomas Jentzsch OFFLINE
Thomas Jentzsch
    Thrust, Jammed, SWOOPS!, Boulder Dash, THREE·S, Star Castle
  • 23,865 posts
  • Always left from right here!
Posted Sat Dec 2, 2017 6:57 AM
At least on my monitor both look better with phosphor enabled (blend = 50).
And I cannot see any issue with scrolling. What have you been noticing here?
Edited by Thomas Jentzsch, Sat Dec 2, 2017 6:57 AM.
