Cases for the Mini-ITX based Atari 8-Bit Motherboards
ÉclaireXL 1088XEL Atari 65XE on miniITX
133 replies to this topic
#26 Lavalamp OFFLINE
Lavalamp
    Chopper Commander
  • 119 posts
Posted Fri Jan 12, 2018 1:18 PM
Original logo, and new position? Or back in centre? It didn't work in the corner...also indented the 1088XEL label...
Edited by Lavalamp, Fri Jan 12, 2018 1:34 PM.
#27 mytek OFFLINE
mytek
  • 3,092 posts
Posted Fri Jan 12, 2018 6:21 PM
If your aiming that case at the 1088XEL, then the console and reset buttons don't exist as a separate entity (F5-F8 on PS/2 keyboard). Of course you could mickey-mouse wire it in, but that would be a pita. Also not sure if the Eclaire XL or the Polish Mini-ITX projects provide a header for these buttons either  :? .
#28 Kyle22 OFFLINE
Kyle22
  • 3,719 posts
  • Call my BBS! telnet://broadway1.lorexddns.net
Posted Fri Jan 12, 2018 6:34 PM
Someone could create a custom version of the board with console keys header and XEGS keyboard port. That would be perfect for this style case.
Would it be a 1088XELGS then, or is that too long of a name?
#29 _The Doctor__ OFFLINE
_The Doctor__
  • 5,845 posts
Posted Fri Jan 12, 2018 6:35 PM
Run them across the bottom edge of the top plate slope and people can use them for whatever they wish, joy/mouse mode selection, sio2ide whatever...
#30 mytek OFFLINE
mytek
  • 3,092 posts
Posted Fri Jan 12, 2018 6:55 PM
Or maybe even 1088XEL-GM where GM = Game Machine which was usually what the console being sold by itself was known as. XEGS (XE Game System) really referred to the complete 'system' that came with the light gun and a game that could use it.
Yep that would make sense.
#31 mellis ONLINE
mellis
    Moonsweeper
  • 273 posts
Posted Fri Jan 12, 2018 7:17 PM
Ohhhhhh noooooooooooo!
I really liked where where you were headed originally, but this is going off the rails with the gigantic "1088XEL".  I would recommend finding a location where the fuji can be next to the model number (as with the 5200) or on opposite sides (left for fuji, right for model number).
Personally, I would ditch the trapezoid-shaped buttons and go with XL-style rectangles, but if I had to pick one, I'd take the trapezoid buttons over the gigantic "1088XEL" any day.
  • P1r likes this
#32 Stephen OFFLINE
Stephen
  • 7,274 posts
  • A8 Gear Head
Posted Fri Jan 12, 2018 8:11 PM
Please don't ever suggest that to a die-hard Mopar guy :)  1088 SRT maybe.
#33 AtariNerd OFFLINE
AtariNerd
  • 1,059 posts
  • For Illustrative Purposes Only.
Posted Fri Jan 12, 2018 8:54 PM
Since the top will be the part most readily modified to various tastes , maybe move the Fuji out of the way, to a more neutral place on the bottom portion, like between and beneath the joy ports. I personally liked the small 1088XEL logo, as it was before. icon_smile.gif Square buttons are a little more universal and maybe other retro hobbiests could adapt the case, with a few stylistic changes, to other systems, as well. XE style is good,too, and I think they're currently well-placed.
Doesn't the TKII handle dual k/bs? Can a circuit that outputs those discreet key values, trick it? Might be a bit wonky with timing delays..
#34 mytek OFFLINE
mytek
  • 3,092 posts
Posted Fri Jan 12, 2018 11:26 PM
Yes the 2nd PS/2 port is available on an internal header, so yes some sort of board could be created and plugged into it to translate switch closures to PS/2 speak for those functions. Anything is possible assuming someone puts the time and effort into it.
#35 foft ONLINE
foft
    Dragonstomper
  • 780 posts
Posted Sat Jan 13, 2018 2:38 AM
I only included consol on my own early prototype. There is a gpio header though so if doing a custom case would be best to wire them up. This case looks great. Would need a cart slot and pbi slot though:)
#36 Lavalamp OFFLINE
Lavalamp
    Chopper Commander
  • 119 posts
Posted Sat Jan 13, 2018 5:28 PM
I prefer this design, the label is now optional, you have an inset area to place one if wanted. The 5 front panel buttons could be removed and a single custom panel fitted if preferred. added some mounts for boards, but unsure how high to make these. Factors I guess would be
height of preferred button (recommendations?) + thicknesses of PCB (2mm?) + Impact point on under side of button
Underneath:
Edited by Lavalamp, Sat Jan 13, 2018 6:14 PM.
#37 _The Doctor__ OFFLINE
_The Doctor__
  • 5,845 posts
Posted Sat Jan 13, 2018 6:18 PM
Really starting to shape up looking good
name plate to the left side please :) angle relationship of buttons and name plates should be more alike... slightly
if we're going for the gusto'
Hidden knock out for sio2sd or other screen above 5 buttons... if not removed top looks unblemished but if you look underneath you will see the outline and material is less in the grooves
Edited by _The Doctor__, Sat Jan 13, 2018 6:48 PM.
#38 AtariNerd OFFLINE
AtariNerd
  • 1,059 posts
Posted Sat Jan 13, 2018 6:54 PM
Edited by Standard User, Sat Jan 13, 2018 6:59 PM.
#39 _The Doctor__ OFFLINE
_The Doctor__
  • 5,845 posts
Posted Sat Jan 13, 2018 6:57 PM
 cart port.... left side 1200XL style? rear 130XE style? top XL style?   If it's on the top we need cart door flaps...
if the name tag were to the left and just above the bend would that be better and keep the slant face cleaner for you standard user?
Edited by _The Doctor__, Sat Jan 13, 2018 7:00 PM.
#40 AtariNerd OFFLINE
AtariNerd
  • 1,059 posts
Posted Sat Jan 13, 2018 7:08 PM
(I had edited my comment while you were commenting, so our convo looks a bit discombobulated. Sorry about any confusion.) It's looking overall well to me at this point, so not too worried about it. I can be too finicky, sometimes.. Just curious to see what he comes up with, with the cart port,now. Then I'll opine again. icon_mrgreen.gif
#41 AtariNerd OFFLINE
AtariNerd
  • 1,059 posts
Posted Sat Jan 13, 2018 7:14 PM
And AtariAge is back. :D (Was down on my end.)
#42 Kosmic Stardust OFFLINE
Kosmic Stardust
    Princess Rescuer
  • 18,140 posts
Posted Sat Jan 13, 2018 7:57 PM
No cart ports? :sad:
Seems the XEGS is still the best way to play those dusty old 8-bit cartridges...
#43 gozar OFFLINE
gozar
    Dragonstomper
  • 925 posts
Posted Sun Jan 14, 2018 10:20 AM
My opinion would be to put the cart port between the joystick ports, if that’s possible.
It would be cool to have the supports for a SSD in case someone wants to put a PC ITX board in the case.
#44 MEtalGuy66 OFFLINE
MEtalGuy66
  • 2,774 posts
  • If it aint broke, fix it anyway!
Posted Sun Jan 14, 2018 11:18 AM
When you apostraphize a plural, it really looks dumb. That's a 3rd grade level grammar mistake.
#45 DrVenkman OFFLINE
DrVenkman
  • 3,603 posts
  • Back off, man! I'm a scientist.
Posted Sun Jan 14, 2018 11:40 AM
I spent most of two decades literally writing and communicating for a living. I understand your point. But the guy also gave us this and made the whole project open and transparent as essentially a gift to the community. Perhaps some linguistic shortcomings are not worth not getting your knickers in a twist over. Just a suggestion.
#46 mytek OFFLINE
mytek
  • 3,092 posts
Posted Sun Jan 14, 2018 1:03 PM
Did I miss something? Just a bit confused about what Metalguy is referring to.
#47 Lavalamp OFFLINE
Lavalamp
    Chopper Commander
  • 119 posts
Posted Sun Jan 14, 2018 1:23 PM
I probably should have started my own thread for this project...
added a breakaway panel for SIO LCD and Cartridge Port
#48 mytek OFFLINE
mytek
  • 3,092 posts
Posted Sun Jan 14, 2018 2:25 PM
That's looking real nice :)
No reason to start a new thread, since this one was aimed at alternative Mini-ITX cases, which your design certainly qualifies for.
#49 mytek OFFLINE
mytek
  • 3,092 posts
Posted Sun Jan 14, 2018 2:47 PM
Oh wait a minute... You meant to say apostrophize didn't you :)
Well it looks like we both need some help with the English language :). But getting back to what you were pointing out, I'll have to see if Albert can make that suggested correction to this Topic's title. So Albert if you read this, please go ahead and do that.
Thank you,
- Michael
  • P1r likes this
#50 Lavalamp OFFLINE
Lavalamp
    Chopper Commander
  • 119 posts
Posted Sun Jan 14, 2018 3:02 PM
Can someone give me the measurements for Lotharek's SIO LCD Panel and the position of the PCB its on, and PCB size and mounting holes? I need to make sure that cut out is correct and it has suitable mount points, Cheers.
Edited by Lavalamp, Sun Jan 14, 2018 3:06 PM.
  • P1r likes this
Also tagged with one or more of these keywords: ÉclaireXL, 1088XEL, Atari 65XE on miniITX
