List of stereo games
21 replies to this topic
#1 davidcalgary29 OFFLINE
davidcalgary29
  • 6,279 posts
Posted Sat Dec 2, 2017 9:29 PM
I was browsing an old document written by Craig Nelson in which he stated that (aside from Klax and parts of Xenophobe), the list of games using stereo was essentially unknown. Has anyone compiled a complete list now? I always thought parts of Toki were in stereo, too.
#2 sage OFFLINE
sage
    Dragonstomper
  • 994 posts
Posted Sun Dec 3, 2017 1:43 AM
yes I checked quiet some games for Stereo wen doing the stereo and attenuation sound patch for handy core. But I guess I lost it.
Was quiet easy to check, as I just had to look for each rom in the emulator if the register(s) were accessed.
#3 bhall408 OFFLINE
bhall408
    Star Raider
  • 60 posts
Posted Thu Jan 31, 2019 3:09 PM
This is a pretty old topic...
Did such a list ever end up getting created?
If not, I'll work one up and share it.
A related/side topic, is how many lynx home-brews end up designing for stereo?
Is there any down side to always enabling/allowing stereo in an emulator? (vs giving a choice to always force mono, even if game uses stereo)
#4 sage OFFLINE
sage
    Dragonstomper
  • 994 posts
Posted Thu Jan 31, 2019 3:16 PM
yes.
lost it.
ask the developers. but i guess all that use the modplayer at least might use attenuation registers for music (lynx 2 stereo feature)
yes, it sound better. anyway, there is no way to "allow" it in the emulator. either you use a fixed emulator core or not.
#5 bhall408 OFFLINE
bhall408
    Star Raider
  • 60 posts
Posted Thu Jan 31, 2019 3:56 PM
yes.
lost it.
OK, I'll work it up then (have started a google sheet).
While I'm at it, figured I'd track which require rotation (Gauntlet, etc) and which support comlynx.
As to sound in emulators, what I meant, is there a user experience reason that you'd reasonably want to disable (or force to be mono).
I'm not saying there is a case, but I could imagine stereo being done so poorly you'd rather it be off/mono when playing. I've seen this in very early stereo pop music recordings.
#6 sage OFFLINE
sage
    Dragonstomper
  • 994 posts
Posted Thu Jan 31, 2019 4:40 PM
Define "Stereo game".
initializisng teh register does not really mean that its used as part of the game-play. Klax uses it for the music, does that count?
#7 bhall408 OFFLINE
bhall408
    Star Raider
  • 60 posts
Posted Thu Jan 31, 2019 5:19 PM
Unless the register had been previously used for something else (by Lynx I or early Lynx II, before stereo support), then seeing it initialized at least means the title was "aware" that it existed.
Could be worth noting which support it for music and which for game play, but I guess I was thinking binary -- either the title took advantage of it, or it didn't.
Edited by bhall408, Thu Jan 31, 2019 5:20 PM.
#8 sage OFFLINE
sage
    Dragonstomper
  • 994 posts
Posted Thu Jan 31, 2019 7:42 PM
so? then all games which use an updated version of the epyx tools set it up to a default value without actually using. would call that a stereo game. but sure. classify as you want.
#9 bhall408 OFFLINE
bhall408
    Star Raider
  • 60 posts
Posted Fri Feb 1, 2019 6:11 PM
Well, from a player point of view, I'd think you'd want to know which games actually used stereo, which may just require playing them all, or a fancier static analysis than just seeing if the register was touched at all.
From an emulator point of view, I guess you just support stereo and call it a day.
#10 Serguei2 OFFLINE
Serguei2
    Dragonstomper
  • 785 posts
Posted Sat Feb 2, 2019 8:33 PM
Lemmings is in stereo.
#11 bhall408 OFFLINE
bhall408
    Star Raider
  • 60 posts
Posted Fri Feb 15, 2019 11:04 PM
I'm not done, but so far here are the ones I consider "stereo" (as in they make use of it which you can notice with headphones on)
Battle Wheels
Dirty Larry: Renegade Cop
KLAX
Lemmings
Lynx Diagnostic
RoadBlasters
Robo-Squash
Robotron: 2084
Xenophobe
Of those, Robotron probably sounds the best!
Edited by bhall408, Fri Feb 15, 2019 11:05 PM.
#12 davidcalgary29 OFFLINE
davidcalgary29
  • 6,279 posts
Posted Sat Feb 16, 2019 10:26 AM
Lexis?
#13 bhall408 OFFLINE
bhall408
    Star Raider
  • 60 posts
Posted Sun Feb 17, 2019 3:42 PM
Lexis?
Are you sure?
I have trouble with that one, because it hangs/won't start in the emulator I have that does stereo (OpenEmu) and will play (but not in stereo) in the others. I have a cart coming that I got on eBay, but it hasn't arrived yet.
#14 Songbird OFFLINE
Songbird
  • 1,596 posts
Posted Sun Feb 17, 2019 10:42 PM
Ponx uses stereo: you can hear the ball bouncing from side to side while it pans across the speakers. That was implemented all the way back in 1999 but I was (and am) very happy with the result. :)
Remnant also uses stereo, as you have left/right lasers firing from your ship.
I want to say CyberVirus also supports stereo, but I'd have to play it again to confirm...
#15 davidcalgary29 OFFLINE
davidcalgary29
  • 6,279 posts
Posted Mon Feb 18, 2019 2:56 PM
Are you sure?
No -- it's been a long time since I played this one (hence the question mark). :)
#16 bhall408 OFFLINE
bhall408
    Star Raider
  • 60 posts
Posted Mon Feb 18, 2019 3:29 PM
Thanks for the additional data Carl..
I've added Ponx & Remnant as supporting stereo.
If you get a chance to check out CyberVirus, let me know and I can add that too.
#17 bhall408 OFFLINE
bhall408
    Star Raider
  • 60 posts
Posted Mon Feb 18, 2019 3:30 PM
OK -- if anyone can confirm this (Lexis doing stereo sounds), I'm happy to add it to the list. If not, I'll get around to it once I have a way to check it out myself.
#18 Songbird OFFLINE
Songbird
  • 1,596 posts
Posted Mon Feb 18, 2019 6:25 PM
Confirmed: CyberVirus supports stereo. So does SFX, but only during the title screen music.
Lexis does not support stereo, and neither does Champ Rally or Loopz.
#19 bhall408 OFFLINE
bhall408
    Star Raider
  • 60 posts
Posted Mon Feb 18, 2019 6:37 PM
Thanks for clearing up Lexis...
For extra credit, if you could survey your games as to how many players can play "locally" (on 1 device, for example there could be a chess game that supports 2 players where you pass the device back and forth, or similar) as well as via ComLynx (2-N devices), I'm tracking that too.
#20 Songbird OFFLINE
Songbird
  • 1,596 posts
Posted Tue Feb 19, 2019 9:39 PM
Really need a separate thread for multiplayer support, but here are the details on Songbird games:
CGE 5th Anniversary: 1 player
Championship Rally: 4 players via comlynx
Crystal Mines II: Buried Treasure: 1 player, but also supports RAM download of a single level
CyberVirus: 1 player
Lexis: 1 player
Loopz: 2 players via comlynx
MegaPak: 8 players via "pass the device" for High Roller mini-game. Other mini-games are 1 player.
Ponx: 2 players on one Lynx, where player 1 uses joypad and player 2 uses the buttons
Remnant: 1 player
SFX: 1 player
#21 sage OFFLINE
sage
    Dragonstomper
  • 994 posts
Posted Tue Feb 19, 2019 10:30 PM
the (hidden) bonus game in lynx reloaded features 4 players on one unit.
#22 davidcalgary29 OFFLINE
davidcalgary29
  • 6,279 posts
Posted Tue Feb 19, 2019 10:32 PM
Othello is unique in that one player can use the LGSS cart while another uses an Othello cart.
