7800 not booting, weird display / sound
59 replies to this topic
#26 tep392 ONLINE
tep392
  • 2,917 posts
Posted Thu Dec 7, 2017 4:19 PM
Did you give the cartridge port a good cleaning?
#27 AtariLeaf OFFLINE
AtariLeaf
    Epic Godlike Canadian
  • 10,542 posts
Posted Thu Dec 7, 2017 5:30 PM
Sounds like one of the main chips might be going out but I'm no expert.
#28 SignGuy81 OFFLINE
SignGuy81
  • 1,455 posts
Posted Thu Dec 7, 2017 5:37 PM
The title is "7800 not booting, weird display / sound" yet I see know mention of the sound issue in the posts.  Also the first post with the videos I'm not seeing the audio cable connected to the TV, just the video cable.  Can you describe what it is doing with the sound, or give us a video as well with the audio connected.
#29 Osgeld OFFLINE
Osgeld
  • 4,736 posts
Posted Thu Dec 7, 2017 6:11 PM
in theory a 7805 is good for 25 volts ... course cause of the heat dissipation you would have to draw very little current, or bolt it to an ingot
#30 Nmitchn47 OFFLINE
Nmitchn47
    Space Invader
  • 27 posts
Posted Fri Dec 8, 2017 8:03 AM
Yes, one of the first things I tried. Used both a cartridge to clean and a credit card with a cleaning swab soaked in rubbing alcohol. Slot was not dirty at all. All pins look to be in place and not bent.
This was before I knew the NTSC versions didn't have a boot screen. And yes, the first two videos didn't have the audio cable attached as I was more worried with the game loading. Audio from both jacks of the AV mod are good.
Good to hear. That would be bad since I replaced all the larger electrolytic capacitors.
#31 Nmitchn47 OFFLINE
Nmitchn47
    Space Invader
  • 27 posts
Posted Fri Dec 8, 2017 8:07 AM
Here are two vidoes that I uploaded this morning of the 7800 running a 2600 game and what is doing with a 7800 game. I got Venture to work this morning surprisingly. So it seems (3) 2600 games are working with a few presses of the power button. Take note of the different sounds and screens that are shown with the 7800 Dark Chamber game inserted. Each time I press the power button is something different.
https://youtu.be/v0mZLunxCH0
https://youtu.be/Zb92OU8_hoM
#32 DrVenkman OFFLINE
DrVenkman
  • 2,812 posts
  • Back off, man! I'm a scientist.
Posted Fri Dec 8, 2017 3:39 PM
Have you seen the heatsink on a 7800? :P
#33 Nmitchn47 OFFLINE
Nmitchn47
    Space Invader
  • 27 posts
Posted Fri Dec 8, 2017 3:52 PM
Before I cracked open the system, I had never seen one so large for a 9v setup. :o
#34 Nmitchn47 OFFLINE
Nmitchn47
    Space Invader
  • 27 posts
Posted Fri Dec 8, 2017 3:58 PM
I'm following the 7800 repair flowchart and it says to check a low depression on some of the pins. How would one go about doing so?
#35 -^CrožBow^- OFFLINE
-^CrožBow^-
  • 5,497 posts
  • Collector of Fine Atari and Sega Antiquities!
Posted Fri Dec 8, 2017 4:45 PM
And yet the 7805 in the 7800 is prone to failure more often than the 2600s 7805 regulators....go figure.
I think the largest heatsink assembly for a 7805 would go to the either the 5200 as it has two of them each with their own large heatsink, or possible the heatsink used on the Genesis model 1, although those heatsinks have two 7805s attached.
#36 SignGuy81 OFFLINE
SignGuy81
  • 1,455 posts
Posted Fri Dec 8, 2017 5:06 PM
Can you take a pic zoomed in on the cartridge port so we can see the pins.
#37 Osgeld OFFLINE
Osgeld
  • 4,736 posts
Posted Fri Dec 8, 2017 5:32 PM
if you flip the board over there's a couple screws holding the cart guide, take those out and it should come free, then you have a clear view of the connector
#38 AtariLeaf OFFLINE
AtariLeaf
  • 10,542 posts
Posted Fri Dec 8, 2017 8:15 PM
Would a flaky power switch cause these issues? Seems to take a few presses to get a game going.
#39 Osgeld OFFLINE
Osgeld
  • 4,736 posts
Posted Fri Dec 8, 2017 10:27 PM
could be, in the video the LED fires right up though (which is on the 5 volt side of the power on circuit)
Edited by Osgeld, Fri Dec 8, 2017 10:28 PM.
#40 cbrown319 OFFLINE
cbrown319
    Combat Commando
  • 1 posts
Posted Sat Dec 9, 2017 11:55 PM
I’m having a similar issue with my 7800. I was playing it just fine, and switched games and never could get it running again. Anyone have a link listing troubleshooting steps? Thanks
Sent from my iPhone using Tapatalk
#41 Osgeld OFFLINE
Osgeld
  • 4,736 posts
Posted Sun Dec 10, 2017 4:26 PM
just an update on mine, got parts in sometime last week, dropped in a new 74LS32 and a 74LS174, and had already replaced the 4013 and now it boots all the time every time
I got a couple of each so if the OP wants to pay for postage and is willing to solder some chips I don't really need the extra's now
#42 Jinks OFFLINE
Jinks
  • 4,219 posts
Posted Sun Dec 10, 2017 8:21 PM
How manay different games have you tried?
All games clean?
The 7800 hates being dirty.
#43 Nmitchn47 OFFLINE
Nmitchn47
    Space Invader
  • 27 posts
Posted Mon Dec 11, 2017 8:17 AM
#44 Nmitchn47 OFFLINE
Nmitchn47
    Space Invader
  • 27 posts
Posted Mon Dec 11, 2017 8:24 AM
Tested it after the regulator didn't work, working good.
#45 Nmitchn47 OFFLINE
Nmitchn47
    Space Invader
  • 27 posts
Posted Mon Dec 11, 2017 8:25 AM
Osgeld, I would be hugely interested in whatever leftovers you might have. PM me and I'll forward payment via Paypal. :)
#46 -^CrožBow^- OFFLINE
-^CrožBow^-
  • 5,497 posts
Posted Mon Dec 11, 2017 8:36 AM
Looking at the first pic, have you verified that those nicked traces about a centimeter from the lower right of the cart port are good? hard to tell in the pic if they are fully intact or not and I believe those traces comes from the rightmost pins off the cart port. Those pins would only be used by 7800 games.
#47 Nmitchn47 OFFLINE
Nmitchn47
    Space Invader
  • 27 posts
Posted Mon Dec 11, 2017 8:45 AM
After looking back on the picture again, you might be on to something. I'll check them out later today.
#48 DrVenkman OFFLINE
DrVenkman
  • 2,812 posts
Posted Mon Dec 11, 2017 11:14 AM
The heatsink on the 1200XL is pretty ginormous - also two 7805's, but in that machine, the heatsink also helps the 12V rectifier; what a silly power system design that system has: 9VAC from the wall, rectified to 12VDC, then stepped down by two 7805s to 5VDC. What kind of grass were those guys on? And why they didn't just spec a 9VDC power supply I'll never know.
#49 Nmitchn47 OFFLINE
Nmitchn47
    Space Invader
  • 27 posts
Posted Mon Dec 11, 2017 6:42 PM
Surprised I didn't see this before but everything checked good with a continuity test on both ends of the traces for all three. Also no shorting between traces. Double checked continuity at the slot pins and motherboard while I was it. The cartridge guide had a sharp edge on the bottom plastic where it was pressing down on the motherboard and digging into the traces. Poor molding of the piece back in the day. Someone before me may have bashed the game in the slot figuring it would help fix it.
#50 Nmitchn47 OFFLINE
Nmitchn47
    Space Invader
  • 27 posts
Posted Tue Dec 12, 2017 9:49 AM
All games clean?
Crossbow, Dark Chambers, Pole Position 2, Ms Pac Man and Centipede
