zzip Posted December 7, 2017 Share Posted December 7, 2017 I recently pulled out my Lynx and noticed a bunch of cartridges will give an "Insert Cartridge" message when inserted, while others work. Is there something I can do? Clean the contacts? (if so how?) Quote Link to comment Share on other sites More sharing options...
BadPricey Posted December 8, 2017 Share Posted December 8, 2017 Try using an eraser. Gently rub in the directions of the contacts so not to damage them. Wipe them off after with a dry cloth towel before putting them in your Lynx. I think some have used rubbing alcohol but I haven't. Rgds BadPricey Quote Link to comment Share on other sites More sharing options...
+karri Posted December 8, 2017 Share Posted December 8, 2017 Electronics cleaning is often done with https://en.wikipedia.org/wiki/Isopropyl_alcohol In Finland you get it from any pharmacy. I believe it is cleaner than rubbing alcohol. Sometimes rubbing alcohol is ethanol plus some added bitterants to make it undrinkable. And sometimes it is just isopropyl alcohol. Check the bottle for C3H8O. Quote Link to comment Share on other sites More sharing options...
tbb033 Posted December 8, 2017 Share Posted December 8, 2017 Check the bottle for C3H8O. Sounds like a droid from Star Wars! Quote Link to comment Share on other sites More sharing options...
Igor Posted December 18, 2017 Share Posted December 18, 2017 I've had good success with DeOxit. Here's a blog post I wrote about it - https://www.igorkromin.net/index.php/2017/11/19/using-deoxit-to-repair-old-game-catridges/ Quote Link to comment Share on other sites More sharing options...
zzip Posted December 19, 2017 Author Share Posted December 19, 2017 Thanks for the replies, I didn't notice I had any until now. Some of the replies are suggesting I clean the carts, and I will try that, but I was assuming that the contacts in the Lynx itself might be the problem.. how can I clean those? Is there something I can safely stick in the cart slot that would help? Or do I need to disassemble it? Quote Link to comment Share on other sites More sharing options...
BadPricey Posted December 19, 2017 Share Posted December 19, 2017 Some carts work, some don't. I would suggest it is cart related and not slot. Not sure how you'd clean that? Quote Link to comment Share on other sites More sharing options...
zzip Posted December 29, 2017 Author Share Posted December 29, 2017 I cleaned the carts with isopropyl alcohol, but that didn't do anything. Then I tried not inserting the carts all the way. The games started working! I found that if push the cart all the way in, but then pull it back less than a millimeter, it will usually work. Almost like the contacts aren't properly aligned with the cart slot. But why would it develop a problem like that if it's just been sitting in a closet? Quote Link to comment Share on other sites More sharing options...
+karri Posted December 29, 2017 Share Posted December 29, 2017 Most likely some pins have been bent inside the cart connector. I looked inside my lynx and straightened two pins with a dentists tool. Quote Link to comment Share on other sites More sharing options...
