The (RND*command questions x infinity<<16) Help Thread
46 replies to this topic
#1 Clint Thompson OFFLINE
Clint Thompson
  • 4,419 posts
  • Kiss Reality Goodbye.
Posted Thu Dec 14, 2017 2:20 AM
1. I don't see any examples of making the sprite blink and I've tried a few things but can't seem to get it working. Is this function actually working and if so, could someone post an example? Is there a way to set the time for blinking, or amount of times it will blink, etc?
2. Without setting up a counter, is there a way to scale a sprite directly adding 1 or subtracting 1 from an object and have it remain? As for example, I want to press 3 and have it scale a sprite by 1 (from 32 to say 33, 34 and so on) and stay that way, and same for subtracting or is a counter actually required? or another example, if sprite A hits sprite B, sprite A will increase +1,+1 every single time?
3. I'm wanting to flip a sprite and have it animate the motion of moving left or right instead of just simply flipping. Would having the same sprite animation contain the frames for moving left or right be the best way to do this? Say IF I press left, it will call frames 12-16 to play and then resume as normal and flip the other way around if so? Playing the primary frames 1-4 for example and then calling beyond that for left or right? Or have others simply created a separate sprite for doing something like this? (which seems like it would be more difficult but may be required)
#2 omf ONLINE
omf
    Dragonstomper
  • 787 posts
Posted Thu Dec 14, 2017 2:53 AM
1, you would need to handle this yourself, i do not believe there is any functionality to do this automatically
2, you could probably add or subtract 1to the scale sections of the object list.  NOTE: scaling objects leaves the collision box as it is. you need to scale that separately.  use my list editor for the correct scaling values
3 you would need to control this manually, setting the gfxbase to the required address to the frame you want, there are a few examples of this going around, if you wan find any then i can provide something
#3 CyranoJ ONLINE
CyranoJ
    RAPTOR Wrangler
  • 5,700 posts
  • reBOOTed
Posted Thu Dec 14, 2017 4:11 AM
1. Make a sprite, add an extra blank frame to the end. set max_frame to 1 (0+1) and use anim_spd to set the blink rate.
2. No, there are no auto-scale commands in the API. I'll put it on the list if I can think of a reasonable way to do so.
3. Keep all your animates a set number of frames... so, eg 0-7 moving left, 8-15 moving right, 16-23 turning left, 24-31 turning right. Set your max_frame to 7 (for 8 frames in this example) and then change the gfx_base pointer to an offset into the sprite :)
#4 Sporadic OFFLINE
Sporadic
    Dragonstomper
  • 537 posts
  • Probably RB+ing
Posted Thu Dec 14, 2017 4:43 AM
Instead of using a variable as a counter you could just read the current scale value into a variable, add 1 to it and then set the scale again.
Eg.
dim currentsize as integer
currentsize = rlist[fishobject].scale_x
currentsize = currentsize + 1
rlist[fishobject].scale_x = currentsize
(you want to add checks to make sure currentsize doesn't go below 0 and above 255 though).
It would be more efficient to just maintain the currentsize variable yourself though and just set the size when required though (saves reading its size each time you need it).
However if you want to be ultra lazy you could do;
rlist[fishobject].scale_x = rlist[fishobject].scale_x + 1
but that wouldn't allow you to test the 0 and 255 limits of the scale property.
#5 Clint Thompson OFFLINE
Clint Thompson
  • 4,419 posts
Posted Thu Dec 14, 2017 9:50 AM
Great, thanks for the info guys!
I just saw the command for blink listed so thought it was something I could use but understood.
Also, I don't want to lazy it up with the sprite scaling of fish for example but also don't want to over complicate it if it's not exactly necessary since the whole idea is to get bigger as you eat more fish. I'm guessing a rgetobj value and IF x=200 (or more) then do this or do that check could work in place somehow. No real added need for sprite x increase or decrease, just wanted to make sure there wasn't something simple already implemented in place that I am missing before I go the other route though I do like the idea of add and then set based on current value, that seems like it would work for what I want to do as a quick test.
#6 Clint Thompson OFFLINE
Clint Thompson
  • 4,419 posts
Posted Thu Dec 21, 2017 1:46 AM
Looking for some more suggestions on controls please so I'm not making a choppy looking, shit game.
I currently have the controls setup to move the fish either 1 or 2 x,y based on D-pad input using xadd or yadd followed by a 0 stop so the fish doesn't endlessly roll one way or the other. What I would like to know is if there's a far better way at doing this so it's more fluid-like? (the puns really are terrible and not intentional) It doesn't seem too bad right now but I can tell when moving at an angle up or down when going left and right that it seems a little jaggy in motion, which is expected I guess since it's probably moving up then left and going back and forth really quickly. I think I tried doing a IF left and up THEN do these two at the same time but I'm not sure if it just didn't work or didn't matter, which brings me here for suggestions on the best way to do it.
Right now I know you can add a delay between moves if using a sub routine but feel that may be causing problems and that there may be another command or function to use for this? That way say I press right then release, the fish doesn't come to a complete halt but slows down and then drifts even slower for a few seconds. The problem with delay is that it's only giving me the speed of the update so it's either slow at 1 or faster at 2 with no in-between or below 1. Apologize if this is super amateurish but again, I'm doing my best at the programming stuff since it's not really my area to begin with as much as graphics and music is my thing.
Appreciate any help.
#7 CyranoJ ONLINE
CyranoJ
    RAPTOR Wrangler
  • 5,700 posts
  • reBOOTed
Posted Thu Dec 21, 2017 2:13 AM
You don't need to use xadd/yadd - you can directly add the values to sprite_x, sprite_y.
#8 Sporadic OFFLINE
Sporadic
    Dragonstomper
  • 537 posts
  • Probably RB+ing
Posted Thu Dec 21, 2017 3:34 AM
I'd say, don't use DELAY(x) in your movement commands.  You instead need to use sub pixel values.
eg. to move 1 pixel you currently do something like;   sprite_x = sprite_x + (1<<16)
If you want to move 1 and 1/2 pixels per frame then you should use; sprite_x = sprite_x + (1<<16)+32768
If you want to move 1/2 a pixel per frame then you should use; sprite_x = sprite_x + 32768
The coordinates are fixed point numbers - you shouldn't need to fully understand this though for basic movement with a few pointers...
The 1<<16 is your whole number (or whole pixel) - so 5<<16 would be 5 pixels etc etc.
1<<16 = 65536 (1 whole pixel)
Therefore, 32768 = half a pixel, 16384 = quarter of a pixel, and so on.  If you add a quarter of a pixel to the sprite_x each frame then it'll take 4 frames to move 1 pixel and hence look much smoother than other methods.
There is a slight complication when using negative values.  You must go to the next whole pixel value lower and then add the fractional pixel on.
Eg. To move -1.5 pixels you would do;
sprite_x = sprite_x - (-2<<16)+32768.  You cannot just subtract the 32768 from the (-1<<16) IIRC.
In the rB+ install folder and in "/website/tutorial1-2.html" you will see a larger write up about this.
Now for example, you could just do sprite_x = sprite_x + 8192 when DPAD_Right is held down.  This will add an 8th of a pixel on to the fishes current position and hence slowly speed up.  If you then do sprite_x = sprite_x - 8192 for left, the fish should gradually slow down and then move left.    This is just off my head pseudo code FYI.
Hope this helps a bit...
Edited by Sporadic, Thu Dec 21, 2017 3:38 AM.
#9 Clint Thompson OFFLINE
Clint Thompson
  • 4,419 posts
Posted Thu Dec 21, 2017 8:35 AM
Yeah, I don't know why I did it that way in the end...
Excellent, thank you! Will hopefully get some time to test it all out this weekend.
Edited by Clint Thompson, Thu Dec 21, 2017 8:35 AM.
#10 Sporadic OFFLINE
Sporadic
    Dragonstomper
  • 537 posts
  • Probably RB+ing
Posted Thu Dec 21, 2017 8:49 AM
Just had another thought;
If you want the fish to keep drifting when the player isn't holding a direction then you do want to use the xadd/yadd values instead of altering the sprite_x/y values directly.  Just don't zero the x/yadd values out each frame.  then raptor will keep the fish moving in the direction you have set.
If you use sprite_x/y (as I detailed in previous post) , you must add a value on every frame otherwise the fish will just stop moving.
So it depends how you want it to behave.
Edited by Sporadic, Thu Dec 21, 2017 8:52 AM.
#11 Clint Thompson OFFLINE
Clint Thompson
  • 4,419 posts
Posted Thu Dec 21, 2017 6:46 PM
Now I know why I did it that way in the end. When I press right, instead of the fish moving right it completely re-positions the fish to the original rapint coordinates and then doesn't actually move right but for whatever wonky reason using x/y_add does it just fine?
When you say "something like this" I need verbatim for what exactly it needs to be since I couldn't get the = to work at all, so maybe that's my issue too. I tried multiple things and it just failed to compile. Sorry for what may seem obvious isn't clear to me.
Here is what I'm doing but it's just not right:
SUB right
RSETOBJ(orangefish, R_sprite_flip, R_is_flipped)
RSETOBJ(orangefish, R_sprite_x,R_sprite_x+2<<16)
END SUB
Should I be using something other than RSETOBJ?
#12 Sporadic OFFLINE
Sporadic
    Dragonstomper
  • 537 posts
  • Probably RB+ing
Posted Thu Dec 21, 2017 7:05 PM
SUB right
END SUB
rlist[orangefish].sprite_x = rlist[orangefish].sprite_x + (2<<16)
Or
rlist[orangefish].sprite_x += (2<<16)
Start using rlist[] instead of rget / rset. It allows you to write the commands much easier.
Your line above , using those commands should be;
RSETOBJ(orangefish, R_sprite_x,RGETOBJ(orangefish, R_sprite_x)+2<<16)
Which as you can see is much harder to write.
Sorry I'm brief here, off to sleep now
Edited by Sporadic, Thu Dec 21, 2017 7:06 PM.
#13 ggn OFFLINE
ggn
  • 1,453 posts
Posted Fri Dec 22, 2017 2:53 AM
This is wrong, as Sporadic pointed out. R_sprite_x is just a variable with a fixed value ( 8 ). So what your code does is setting the attribute R_sprite_x of object orangefish to value R_sprite_x+2>>16, which is 8+65536=65544.
Instead you need to get current value using rget or rlist and then add 1<<16 or -1<<16.
Hope this makes things more clear!
Edited by ggn, Fri Dec 22, 2017 4:25 AM.
#14 Clint Thompson OFFLINE
Clint Thompson
  • 4,419 posts
Posted Sat Dec 23, 2017 1:23 AM
These are the errors I get when I use either RLIST function exactly as you have written out:
As:
Attached File  error1.png   19.78KB   0 downloads
or as:
Attached File  error2.png   17.35KB   0 downloads
and if I use this:
I press right, it sets the fish over 2 pixels but does not continue to push the fish left or right the longer you hold the button, even though the fish was in an entirely different location. That's why I used xadd and yadd, because it would continue to roll and keep going, not just move this object a few pixels from it's current location.
#15 Sporadic OFFLINE
Sporadic
    Dragonstomper
  • 537 posts
  • Probably RB+ing
Posted Sat Dec 23, 2017 2:20 AM
As:
or as:
and if I use this:
Sorry my bad, I think you just want rlist[orangefish].x
I can't remember where there is a list of the variable names to put on the end. I'll look later or maybe ggn has one. (It might even be in the forum or in the /docs/ install folder either in the quickstart or change log file)
The rget/set version above would have to get called every frame (loop) to keep the fish moving, so yes, stick with xadd etc, it's easier.
Edited by Sporadic, Sat Dec 23, 2017 2:22 AM.
#16 ggn OFFLINE
ggn
  • 1,453 posts
Posted Sat Dec 23, 2017 12:11 PM
rlist members are:
obj
active
x
y
xadd
yadd
flip
width
height
vbox
hbox
gfxbase
framesz
framedel
curframe
maxframe
animloop
wrap
timer
track
colchk
scaled
scale_x
scale_y
CLUT
animspd
bytewid
tracktop
was_hit
coffx
coffy
remhit
bboxlink
hitpoint
damage
flash
gwidth
rmotion
rmcurfrm
rmfrm
As shown in the quickref guide ;)
Edited by ggn, Sat Dec 23, 2017 12:12 PM.
#17 Clint Thompson OFFLINE
Clint Thompson
  • 4,419 posts
Posted Sat Dec 30, 2017 3:50 AM
Bandwidth:
Sick and brain dead, I've fired up the Jag again and want to understand and clear up any confusion regarding the objects being built on-screen and how it affects performance or *could* regarding active vs inactive, as I've seen it written that just because something is inactive doesn't mean it's still not on the screen. With that said and for further clarification:
If X object is at 200,200 and I set it to inactive, it's no longer being processed by the OP at this point correct? or no?
Edited by Clint Thompson, Sat Dec 30, 2017 3:54 AM.
#18 Sporadic OFFLINE
Sporadic
    Dragonstomper
  • 537 posts
  • Probably RB+ing
Posted Sat Dec 30, 2017 4:05 AM
Inactive objects are not processed by the OP. As far as I know, Raptor culls them. CJ will probably verify this
#19 CyranoJ ONLINE
CyranoJ
    RAPTOR Wrangler
  • 5,700 posts
  • reBOOTed
Posted Sat Dec 30, 2017 4:19 AM
Correct, at the next VI interrupt (50Hz PAL/60Hz NTSC) the object will disappear from the screen.
It *IS* technically still in the list, however the last active object prior to it has its link pointer set to skip over it. This is why it is imperative that the first and last objects in the list are always active.
The RAPTOR API will also not do any processing on inactive objects (eg, x_add/y_add/animation/collision detection, etc)
Hope that helps :)
#20 Clint Thompson OFFLINE
Clint Thompson
  • 4,419 posts
Posted Thu Jan 4, 2018 10:51 PM
I've been messing with this for hours now and it's really pissing me off.
Trying to get the collision to work on an object that is acting as a laser and only being displayed for a few moments but it's not working. I set up a xadd, +5 to make sure the detection actually works and force the object as active and it works as seen below:
but if I do it the way I *want* it to work, it doesn't do shit:
I've removed the DIM titling in case I was messing something up, I've tried different things just to make sure I've got the right object (and it's not hard since I don't have very many), first and last image is active... have even tried adding it to the subroutine for when you press left or right hoping that might work but nothing
Any suggestions please....
IF RHIT(4,4,6,6)<>-1 THEN
RSETOBJ(4,R_sprite_xadd,+5<<16)
DELAY(1)
ENDIF
That works if I keep the laser object active. Does hit collision not work on objects that are inactive at first and later enabled?
Edited by Clint Thompson, Thu Jan 4, 2018 10:52 PM.
#21 ggn OFFLINE
ggn
  • 1,453 posts
Posted Fri Jan 5, 2018 12:15 AM
I'm stabbing in the dark here but here's a couple:
- delay(1) will halt all your program for one vertical blank. I'm not sure if that's a good idea, ideally I'd expect you have a single delay(1) or vsync call in your main loop.
- You don't seem to be resetting was_hit attribute after collision. Try inserting a [b]RSETOBJ(4,R_sprite_was_hit,1)[/i] inside your if block.
- Try this: instead of making the object active and inactive, change its y coordinate to something high like 500 to make it "invisible" and then back to the original coordinate to make it "visible".
Hope any of this helps!
#22 Clint Thompson OFFLINE
Clint Thompson
  • 4,419 posts
Posted Fri Jan 5, 2018 8:27 AM
Thanks ggn, I'll give it a go this weekend.
I did try the moving coordinates completely off screen before posting this and it didn't make a difference but I don't know if I had it set to disable the object or not, though not sure that should matter. As far as displaying an image for x amount of time, in this case the laser, is there a timer example you can give to display object X for X amount of seconds as opposed to using delay, since that's probably what is messing it up if it's halting the program. Same could be for anything else that I'm wanting to slow down.
Yeah, vsync is required in main loop otherwise nothing animates I've learned... and for some reason, adding delay is the only way I could get some functions to work like the scaling but that could also explain why I have weird issues in the fish game, just don't know of another way of doing it.
#23 Clint Thompson OFFLINE
Clint Thompson
  • 4,419 posts
Posted Sat Jan 6, 2018 1:41 AM
I was toying around with moving a background via rapini.s and using the R_sprite_xadd and set it as 1... music in the background plays great, animation moves along the top of the screen fluid-like. I decide to change it to zero. Now the music is degraded and slowed down. Reverting back to making the top of the screen animate brings the quality of the music back to normal. This seems completely backwards in regards to performance, so my question is what would cause a static image to degrade the quality of the music AND slow it down but the moment you animate it to shift right, everything clears up perfectly?
#24 Clint Thompson OFFLINE
Clint Thompson
  • 4,419 posts
Posted Sat Jan 6, 2018 2:16 AM
So a little further diving in:
    dc.w    10,0            ;                                     ; Put sprite this many pixels down from top of screen.                ;   R_sprite_y
    dc.w    0,$00006000                ;                                     ; How many pixels will this sprite move automatically in x?            ;   R_sprite_xadd
    dc.w    0,0                ;                                     ; How many pixels will this sprite move automatically in x?            ;   R_sprite_xadd
I found the way to make the animation move far slower and exactly what I wanted.... however, if I go any slower then it's back to degraded audio performance again and slowed down music. If I change 0,$00006000 to 0,$0001000 then total performance hit. Why is that? What's happening in the background as a result of slowing down an animation that would also slow down the music or make it sound worse?
#25 ggn OFFLINE
ggn
  • 1,453 posts
Posted Sat Jan 6, 2018 5:40 AM
This is very weird. What raptor does internally is take whatever value R_sprite_x has and add R_sprite_xadd. That's all to it. It really doesn't care much what increment you give it, 0 to max highest or lower number. So if I were you I'd rule out completely that this is the cause of your problems.
How are you testing this by the way? Real hardware or VJ?
Reply to this topic
