4K Short'n'Sweet game contest
403 replies to this topic
#151 Asmusr OFFLINE
Asmusr
  • 3,002 posts
Posted Sat Feb 3, 2018 2:40 AM
My game doesn't rely on any startup configuration, so no problem for me either.
#152 senior_falcon OFFLINE
senior_falcon
  • 1,333 posts
Posted Sat Feb 3, 2018 11:59 AM
Here is the loader to load 4K into the minimemory from TI BASIC.
Use Classic99 and the E/A cartridge to make and load the assembly program. Classic99 has cartrige RAM from >6000 to >7FFF so you can load and test your program there.
In the source code start with:
DEF SLOAD
DEF SFIRST
DEF SLAST
AORG  >7000
Then the program, and at the end:
SLAST
AORG >A004 plugs the last address into R2
DATA SLAST
END
>7000 is the starting address of the program.  There is a test program in the folder called MINIMEMTST.TXT and MINIMEMTST.OBJ  which does nothing but get into an endless loop at >7000 and fills the memory with >FFFF, but with the debugger you can see that the proper bytes are saved and loaded.
Assemble the usual way, then get into TI BASIC and type:
CALL INIT
CALL LOAD("DSK3.SNSLOADER.OBJ")  *load the loader 1st
CALL LOAD("DSK3.MINIMEMTST.OBJ") * then your program
CALL LOAD(-31804,160)                          *Resist the urge to use CALL LINK which writes a couple of bogus bytes into the program and will make it crash!
Now the code  at >7000 is embedded in a TI BASIC program.  Save to disk or cassette.
You can run it with a supercart like you just did in Classic99 or else insert the MiniMemory cartridge and type: OLD DSK1. or OLD CS1 and RUN.
When the program starts the TI is almost the same as when running an EA5 program:
WKSP is >83E0
large and small characters are loaded to V0900
The vdp registers are the same.  (Almost - BASIC sets some of them to use V4000 as the screen which works the same as V0000)
The program starts running at >7000
differences:
The color table at V0380 is Black on Cyan
The screen is not cleared.  This can be done by adding 15 CALL HCHAR(1,1,192,768) to the loader.
<edit> If you look at the source code for the loader you will see that I have set up the GPL stack to do the scroll routine.  The reason is that the loader uses the interrupt hook at >83C4 to start up and that might take up to 1/60 of a second.  So the scroll just gives BASIC something innocuous  to do until the interrupt can take control.
Edited by senior_falcon, Sat Feb 3, 2018 1:51 PM.
#153 Asmusr OFFLINE
Asmusr
  • 3,002 posts
Posted Sat Feb 3, 2018 12:49 PM
Thanks. This is excellent. The loader is more impressive than my game.  :)
#154 senior_falcon OFFLINE
senior_falcon
  • 1,333 posts
Posted Sat Feb 3, 2018 12:56 PM
If you want to feel better, compare your game with MINIMEMTST.  I'm pretty sure your game will be impressive, in fact I would make a large wager on it!
#155 Tursi OFFLINE
Tursi
  • 5,425 posts
  • HarmlessLion
Posted Sat Feb 3, 2018 8:22 PM
Works like a charm! Thanks so much!
#156 senior_falcon OFFLINE
senior_falcon
  • 1,333 posts
Posted Sat Feb 3, 2018 10:00 PM
Looking forward to seeing what you guys have come up with.
BTW, I'm sure it has occurred to you that you can fit two or more of these games into an 8K supercart.  (It is probably not practical to make a ROM cartridge since they probably will need to have RAM)
#157 retroclouds OFFLINE
retroclouds
  • 1,682 posts
Posted Sun Feb 4, 2018 12:53 AM
I also thought about that.
My game could be a candidate for a ROM cartridge as Im only using scratchpad RAM. Anyone else on scratchpad only?
Edited by retroclouds, Sun Feb 4, 2018 12:54 AM.
#158 lucien2 OFFLINE
lucien2
    Moonsweeper
  • 293 posts
Posted Sun Feb 4, 2018 1:52 AM
I am.
My game is finished and I still have 1000 bytes free (simple game with minimalist design). I'll add some online help.
#159 sometimes99er OFFLINE
sometimes99er
  • 4,191 posts
Posted Sun Feb 4, 2018 3:54 AM
Yes. :)
I'm trying to stick with one game only for this contest. Thought it would be something I could do in like no time. Well.  :party:
#160 senior_falcon OFFLINE
senior_falcon
  • 1,333 posts
Posted Sun Feb 4, 2018 8:07 AM
Remember that if you starting the program from the menu (Press 1 for BASIC  2 for YOURGAME) the preloaded characters are different.  EA5 loads the same characters as BASIC.  The menu only preloads the 8 pixel high large capitals and there is no lower case.
Just one more complication..................
#161 Tursi OFFLINE
Tursi
  • 5,425 posts
  • HarmlessLion
Posted Sun Feb 4, 2018 8:02 PM
Totally, I'm including a 4k ROM cart in my submission once it opens :)
#162 Vorticon OFFLINE
Vorticon
  • 3,495 posts
Posted Mon Feb 5, 2018 7:16 AM
Mine only uses the scratchpad as well.
#163 retroclouds OFFLINE
retroclouds
  • 1,682 posts
Posted Mon Feb 5, 2018 11:04 AM
Oh I see a short n sweet multicart coming. For your unexpanded TI-99/4a, no extra RAM required :-)
#164 Ksarul OFFLINE
Ksarul
  • 5,030 posts
Posted Mon Feb 5, 2018 11:05 AM
Looks like we might be able to put all of the entries into a single console-only multicart image once the contest is over, based on all of the identified entries so far being self-contained and only needing the scratch pad. Looks like @Retroclouds and I were having the same idea at the same time. . .  :)
Edited by Ksarul, Mon Feb 5, 2018 11:06 AM.
#165 Asmusr OFFLINE
Asmusr
  • 3,002 posts
Posted Mon Feb 5, 2018 1:54 PM
All except mine. [edit: I do need 4K RAM].
#166 Asmusr OFFLINE
Asmusr
  • 3,002 posts
Posted Thu Feb 15, 2018 3:06 PM
Even though registration is not required for this contest, it would be nice with a non-binding status update.
My own game is as complete as I think it will be within the limits of 4K. It requires 4K RAM, e.g. a Mini Memory, and can be loaded from tape (using Senior Falcon's loader), disk, or a 4K FG99 ROM image that loads itself into FG99 RAM. The latter is using Tursi's lz4 decompression routine to reduce the ROM size to 4K.
#167 Tursi OFFLINE
Tursi
  • 5,425 posts
  • HarmlessLion
Posted Thu Feb 15, 2018 4:22 PM
Okay... mine's ready as well. I have a 4k Mini Memory version that uses Senior Falcon's loader (the loader is >4k), as well as the object file and source to show it runs in 4k. I also have an EA#5 version (for non-Mini-Memory users with 32k) and a 4k cartridge ROM. (I didn't use the lz4 code so I'm glad someone did! ;) )
#168 palmheads OFFLINE
palmheads
    Chopper Commander
  • 205 posts
Posted Thu Feb 15, 2018 6:32 PM
I really can't wait to see what you guys have come up with - have always felt the "mini memory" environment has always been somewhat neglected. Its a really exciting development!
#169 PeteE OFFLINE
PeteE
    Chopper Commander
  • 198 posts
Posted Thu Feb 15, 2018 10:30 PM
I'm still working on mine, but am out of code space so I'm looking at moving some of the runtime data tables to the VDP memory or finding a more compact representation.  I always seem to underestimate how much space will be taken up by things.
#170 Tursi OFFLINE
Tursi
  • 5,425 posts
  • HarmlessLion
Posted Thu Feb 15, 2018 11:58 PM
hehe, so do I. I figured my base engine would take about 2k, but it was at 6k before I started optimizing ;)
#171 Tursi OFFLINE
Tursi
  • 5,425 posts
  • HarmlessLion
Posted Sat Feb 17, 2018 6:37 PM
When are we opening up the voting thread, was that Mar 1?
#172 PeteE OFFLINE
PeteE
    Chopper Commander
  • 198 posts
Posted Sun Feb 18, 2018 2:00 AM
Seems like I'm the only one left to finish, so you could potentially open voting as soon as it's ready.  I shall endeavor to complete mine by next weekend.  I was hoping to see some other still-in-progress entrants.
#173 sometimes99er OFFLINE
sometimes99er
  • 4,191 posts
Posted Sun Feb 18, 2018 4:11 AM
As indicated below, I hope it's still beginning of April. ;)
More interestingly - to me, the deadline of entries is end of March. ;)
The deadline of 3 months brings us to the end of March 2018 whereby all entries should be submitted. You do not have to register in order to participate.
At the beginning of April, a poll at AtariAge will be set up to choose the winner.
Edited by sometimes99er, Sun Feb 18, 2018 4:39 AM.
#174 sometimes99er OFFLINE
sometimes99er
  • 4,191 posts
Posted Sun Feb 18, 2018 4:32 AM
January saw me concentrating on a sports game. Now I jumped on a platformer instead.  :|
Edited by sometimes99er, Thu Mar 1, 2018 1:32 AM.
#175 digdugnate OFFLINE
digdugnate
  • 2,123 posts
Posted Sun Feb 18, 2018 5:07 AM
i can't wait to see what everyone has come up with!  i can at least participate by voting lol
