Can't get Casette Programs to load via Smartphone or Computer.
CoCO 1 Tandy TRS-80 Casette CLOAD CLOADM RUN
3 replies to this topic
#1 RockyRaccoon OFFLINE
RockyRaccoon
    Chopper Commander
  • 106 posts
  • Classic Gaming Raccoon
Posted Thu Dec 21, 2017 8:42 PM
Hello! I recently got a CoCo 1 and have been trying to get it load programs via a Cassette cable I bought off Ebay.
Here's how it goes:
I load the .wav file onto the device. I get the wav files from here: http://www.colorcomp...assettes/Games/
I connect the device via the cable to the device.
I type 'CLOAD' (or CLOADM, as applicable) and then that little prompt in the corner comes up. I press play. It blinks. It gets the correct name of the program. It appears to be loading. The recording stops. The little light blinks: 'OK' it says.
Now when I type 'Run', nothing happens.
I type 'List' and there's no program loaded.
It's like it wasn't loading anything at all. :-/.
What's going on? How can I potentially fix it?
I've tried various volume levels but that doesn't seem to matter. I KNOW it's loading /something/ because it's detecting the name of the program while it loads. :-/.
#2 RockyRaccoon OFFLINE
RockyRaccoon
    Chopper Commander
  • 106 posts
Posted Thu Dec 21, 2017 11:45 PM
I can't edit this, whoops but I will add:
I have typed 'AUDIO ON' and confirmed that the devices will play through the TV great, so the cable is ostensibly fine.
#3 jhd OFFLINE
jhd
  • 1,841 posts
Posted Fri Dec 22, 2017 10:41 AM
I used a cassette-based Coco for many years (I never upgraded to disk), and I have never encountered this problem. Weird.
I would suggest increasing the volume, but since it is reading the header information/file title, that is probably not the problem.
It shows S in the top-left corner of the screen while searching the tape, followed by an F when it eventually finds your title.
There is also the SKIPF command that will check that a file is written to tape correctly, but will not load it into memory. (The EDASM+ cartridge thoughtfully renames this command VERIFY.)
You have probably tried this, but for a machine language program, uses EXEC to start it.
#4 RockyRaccoon OFFLINE
RockyRaccoon
    Chopper Commander
  • 106 posts
Posted Fri Dec 22, 2017 4:34 PM
Hey jhd.
Basically, I'm the ultra noob. X3. I thought it was 'RUN' for both types. I loaded a program and typed 'EXEC' and that worked. Go Munchman and Color Invaders working, which were my two test programs.
Thank you for your patience. X3 Whoops!
Also tagged with one or more of these keywords: CoCO 1, Tandy, TRS-80, Casette, CLOAD, CLOADM, RUN
