notwhoyouthink Posted December 22, 2017 Share Posted December 22, 2017 (edited) 1 Z=102 FOR A = 1 TO Z3 IF TEST-CONDITION=1 THEN 4 ELSE 74 Z=Z+1 !MODIFY THE LOOP LIMIT TO RUN A EXTRA TIME 5 DO SOMETHING 6 GOTO 87 DO SOMETHING DIFFERENT 8 NEXT A What i want is a loop that changes itself to run extra times if needed, based on whether a certain conditional variable is 1 or 0.I am fairly certain something like this can be done in languages like C, but is it possible in Basic/XB? Edited December 22, 2017 by notwhoyouthink Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted December 22, 2017 Share Posted December 22, 2017 The ending constraint is evaluated at the time the FOR statement is executed. I am pretty certain the stepping value is, as well. However, you can manipulate the counter variable. For instance: 10 Z=10 20 FOR A=1 TO Z 25 PRINT A 30 A=A+2 40 NEXT A This will print 1, 4, 7, then 10. And this: 10 Z=10 20 FOR A=1 TO Z 30 PRINT A 40 IF A<>5 OR Z=0 THEN 60 50 A=A-4 :: Z=0 60 NEXT A Will print 1,2,3,4,5,2,3,4,5,6,7,8,9,10 EDIT: Yes, the stepping value is evaluated at the time of FOR execution, as well: 10 Z=20 15 I=2 20 FOR A=1 TO Z STEP I 25 I=1 30 PRINT A 40 IF A<>5 OR Z=0 THEN 60 50 A=A-4 :: Z=0 60 NEXT A Prints 1,3,5,3,5,7,9,11,13,15,17,19 2 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted December 22, 2017 Share Posted December 22, 2017 You could manipulate a FOR/NEXT loop to be a DO/WHILE loop like this: 10 FOR A=-1 TO 0 20 REM DOING SOMETHING 30 REM DOING SOMETHING MORE 40 A=TESTCONDITION 50 NEXT A 0 (zero) is "false," and any non-zero value is "true," but the evaluation of a condition is -1 for "true." Therefore, setting the counter variable in 40 to a true/false -1/0 condition (more like a DO/UNTIL) will control the loop without the use of IF/THEN, GOTO, or ON GOTO. 1 Quote Link to comment Share on other sites More sharing options...
Willsy Posted December 22, 2017 Share Posted December 22, 2017 (edited) 1 Z=10 2 FOR A = 1 TO Z 3 IF TEST-CONDITION=1 THEN 4 ELSE 7 4 Z=Z+1 !MODIFY THE LOOP LIMIT TO RUN A EXTRA TIME 5 DO SOMETHING 6 GOTO 8 7 DO SOMETHING DIFFERENT 8 NEXT A What i want is a loop that changes itself to run extra times if needed, based on whether a certain conditional variable is 1 or 0. I am fairly certain something like this can be done in languages like C, but is it possible in Basic/XB? No need to modify z. For an extra blast around the loop just decrement a by one. Though what you have done looks okay to me. Both a and z will be evaluated by NEXT. Edited December 22, 2017 by Willsy Quote Link to comment Share on other sites More sharing options...
