Filler plate wanted
atrax27407
What kind of issues did you have? Was the filler plate not substantial enough?
The opening on the TI's disk bay is actually a little wide if you want the filler plate to be flush with the drive. I suppose I could have used some shims but that would look ugly. I also could have super glued the faceplate to the Lotharek, but that was too permanent for me. Since I did not want to have a crappy look or something that could not easily be undone I went for the drawer.
I originally wanted to go with just a face plate too, but found mounting issues to be a problem. I eventually went with one of
<< THESE >> and it works great. I did however install a larger screw in the side to prevent the drawer from opening.
It's pretty solid and has worked out great.
There are several similar/cheaper versions. I usually look for a USA source.
